Old 03-27-2019, 08:09 AM   #476
M.H. Yount
M.H. Yount's Avatar
My corner weights, with about 12 gallons in the car but no spare/jack -- LF - 858; RF - 824; LR - 640; RR - 713; 3035. Battery in the trunk, fiberglass Commandos, 8.8", alum head/cast iron block 5.0L, T5z. Get fuel load down to 4-5 gallons and she squeezes down to about 2990.
Old 03-27-2019, 10:50 AM   #477
cosbySweater
cosbySweater's Avatar
Originally Posted by doucheNozzle View Post
What’s on the front left? Turdblow?
My balance on the car is all messed up. Lol
1984 Volvo 245
1995 Porsche 993
2013 VW Passat TDI
Old 03-27-2019, 10:51 AM   #478
cosbySweater
Originally Posted by M.H. Yount View Post
My corner weights, with about 12 gallons in the car but no spare/jack -- LF - 858; RF - 824; LR - 640; RR - 713; 3035. Battery in the trunk, fiberglass Commandos, 8.8", alum block, T5z. Get fuel load down to 4-5 gallons and she squeezes down to about 2990.
Yea so I'm not that far off then. The 80e and massive turbo and piping probably don't help either
Old 03-27-2019, 11:02 AM   #479
towerymt
the real Towery
towerymt's Avatar
60/40 split, dang. That's a lotta heavy horsepower up front. Sedans are usually close to 55/45.
Old 03-27-2019, 11:52 AM   #480
cosbySweater
Yea the engine is super far forward on the car.
Old 03-27-2019, 12:10 PM   #481
84.242
sick build.
i just got my 80E in the car...is your trans cooler fan a push or pull? have you ever run it vertically in front of the core stack, or has it always been a horizontal mount?
84.242 is offline   Reply With Quote
Old 03-27-2019, 01:04 PM   #482
cosbySweater
It's always been mounted there, trans temps have never kicked the fan on. I believe I have it setup to push through
Old 03-28-2019, 08:41 AM   #483
M.H. Yount
M.H. Yount's Avatar
Almost forgot - edited above - my weights were before the LS3 swap - cast iron 5.0L/alum heads. And new/heavier mufflers in the back since then. The LS swap dropped about 20 lbs. net once all was said and done. And probably about that much added at the back with the mufflers. I need to borrow the scales again, but suspect it's right at 53/47 - 54/46 front to rear.
Old 03-28-2019, 01:24 PM   #484
cosbySweater
yea the aluminum block is a big help. if and when this thing ****s the bed im going to look at getting a aluminum block for it
Old 03-28-2019, 08:29 PM   #485
M.H. Yount
M.H. Yount's Avatar
A bigger help for you (vs LS iron block) than it was for me - thin wall/short deck 5.0L block. With exh manis, all ignition/fuel/intake, balancers, but no flywheels or accessories - 5.0L alum heads - 411 lbs; LS3 - 393 lbs. I understand there’s about 90 lbs difference between iron and alum LS blocks.
Old 03-28-2019, 08:50 PM   #486
cosbySweater
yea that sounds about right. im working on some sn95 adapters and im going to ditch the ats brakes up front, im hoping that will save some weight as well. also im going to say im willing to bet it will be another 20lbs off the back race weight due to the fact i remove the exhaust.
Old 03-28-2019, 08:55 PM   #487
cosbySweater
also i dont know if i ever posted what this car sounds like with the straight dump, so here it is.,
https://www.instagram.com/p/BrBA2RGn...on_share_sheet
Old 03-28-2019, 09:28 PM   #488
Texas240
Prius Owner
Texas240's Avatar
Not that it matters but I save a good 10lbs going back to stock calipers on my 240 with really good pads and left the Mustang Master in. Brakes stop better than the R's did.
93 245 LS Engine Swap Project
Old 03-30-2019, 06:38 PM   #489
cosbySweater
ive been spending the day messing with the car, having some weird issues where it feels like i hit a brick wall after 5200, not loosing power like before but it feels like its getting spark blow out. i was running tr6 ngks and switched to a colder plug wit a 22 gap, feels a little better but something feels off. i dont know if im blowing through the converter or what but it feels very odd. here are the plugs and a pic of the engine bay.
Old 03-31-2019, 03:24 AM   #490
RvolvoR
does it do it with the intake off?
Old 03-31-2019, 10:10 AM   #491
cosbySweater
Yep. Figured it out, to much fuel up top. Addend some timing and took out some fuel
Old 04-01-2019, 09:42 PM   #492
cosbySweater
Okay!!!! new find. Car pulls the ass down so hard during decel that the fuel pressure pulses a bit and ****s with the e85 content sensor.
Old 04-02-2019, 01:17 PM   #493
Duder
Comes with a free Frogurt
Duder's Avatar
Anti-squat?
Old 04-20-2019, 08:18 PM   #494
cosbySweater
Whelp. Let's see what happens next weekend
Old 04-21-2019, 12:45 AM   #495
RvolvoR
Time to leave the crank on the ground. Depending on how this next week goes, I might be picking up a tow rig while I’m down there instead of driving down, so I could give your ****box a hitch back home if needed...
Old 04-21-2019, 01:19 AM   #496
cosbySweater
Oh nice!!!!! That would be perfect. Luckily the track is 190 miles away from my house and I think my AAA is good for 200 miles.
Old 04-21-2019, 01:43 AM   #497
gsellstr
gsellstr's Avatar
Now if only you had a cage so we could see what it's REALLY capable of. lol
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 04-22-2019, 12:27 AM   #498
cosbySweater
The car needs to be tuned by someone that isn't me. Lol also ordered a new flex fuel sensor for it. Mine is doing some really weird stuff and I don't want to scatter the engine. I have a spare drive shaft to bring with as well because mine while being strong I just don't trust it anymore
Old 04-22-2019, 05:05 PM   #499
cosbySweater
Took out some mid range timing, upped the two-step. I can get about 6-7lbs on the two step footbrake at around 2300. That's about as much rpm as I can get out of this damn converter, I wish I had time to change it prior to Davis but it is what it is at this point. Car decided to barf out a bunch of brake fluid today at the tire shop so that was cool
Old 04-30-2019, 09:01 AM   #500
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
I still love this car lol. It's gonna be a ROCKET once you get a decent converter in it. If you can get even 10psi on the launch you're going to cut at LEAST a 1.60 60'. That's one thing I'm very excited about this year is I'll have more torque from the 5.3 and even launching at 2800 like I was before should still get me a better 60'.
Can't wait to see what our cars do this year.
Current setup - Aluminum L33/Summit Turbo Stage 2, Billet 80mm turbo, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
