Old 08-20-2020, 04:33 PM   #101
cosbySweater
cosbySweater's Avatar
I have nowhere near close to 8k on this engine. Let's feed it 30 PSI and E85 and see what happens.
Poof 280whp
1984 Volvo 245
1995 Porsche 993
2013 VW Passat TDI
Old 08-20-2020, 04:36 PM   #102
Originally Posted by cosbySweater View Post
Poof 280whp
Old 08-20-2020, 06:42 PM   #103
oldschoolvolvo
oldschoolvolvo's Avatar
Originally Posted by dl242gt View Post
I think it is Yoshifab that machines a cut down distributor for the 16v setup. That way you can remove the distributor and use the crab cap for best clearance.
Yes that is correct.
https://yoshifab.com/store/b21/23/23...tributors.html
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 08-20-2020, 09:25 PM   #104
Marvelous3
Who engineered this?
Marvelous3's Avatar
Poof 280whp
Winner winner!
Old 08-20-2020, 09:42 PM   #105
Markos Simopoulos
they do but its not hard to DIY it or go coil on plug
Markos Simopoulos is offline   Reply With Quote
Old 08-20-2020, 09:55 PM   #106
JohnMc
JohnMc's Avatar
VAG coils even fit under the stock spark plug cover.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-20-2020, 09:58 PM   #107
2turbotoys
Astro Zombie
2turbotoys's Avatar
Worth it just so you can say vag while talking about your car.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 08-20-2020, 10:01 PM   #108
JohnMc
JohnMc's Avatar
Look out, it's the VAG COPS!!!
Old 08-20-2020, 11:37 PM   #109
Miss Monika
Miss Monika's Avatar
"If I meet the man of my dreams, I hope he doesn't know about my dreams."
Miss Monika is offline   Reply With Quote
Old 08-20-2020, 11:45 PM   #110
Don't they blow out with judicious boost though?
Old 08-21-2020, 12:20 AM   #111
culberro
culberro's Avatar
Only if you get the old OEM ones from a junkyard. So basically what any TBer would do.
The updated replacement ones are a lot better. Iím waiting for Asher to come in here and tell use that they all suck.
Old 08-21-2020, 02:23 AM   #112
So the VW kids go for R8 coils because they are long and red then?
Old 08-21-2020, 12:11 PM   #113
culberro
culberro's Avatar
You talking about 1.8t or 16v VW?
Old 08-21-2020, 12:20 PM   #114
JohnMc
JohnMc's Avatar
HOOOOOOLD the horses, I was using Toyota COPS, not VAG COPS. Derped my mind.
Not nearly as fun.
They were doing fine at 24-ish PSI w/E85.
Old 08-21-2020, 12:33 PM   #115
culberro
culberro's Avatar
Not nearly as fun.
You got a part number on those Toyota COPs? I tried a few different ones but they were not having it.
Old 08-21-2020, 01:18 PM   #116
JohnMc
JohnMc's Avatar
UF314? Something like that. They fit the 2ZZGE Toyota motor.
They're also 'logic level trigger - no need for a driver, no real need to sweat the dwell settings in MS, just run 12V/GND/TRG to them and let them figure out how to zap.
You have to lop off part of it - mostly the plastic flange (it's circular, a bit too wide to fit down in the Volvo plug hole all the way).
Old 08-21-2020, 01:37 PM   #117
Weird. I bought one of those to test and it stuck out way too far.
Old 08-21-2020, 01:37 PM   #118
culberro
culberro's Avatar
Many thanks! Those are definitely not the coils I tried using.
Edit: Harald, we will never figure this out...
Old 08-21-2020, 01:50 PM   #119
GTJordan
Been here for too long
GTJordan's Avatar
I'm interested in COP options for my 16V also. Prefer they had their own logic.
Old 08-21-2020, 01:54 PM   #120
Could be that the cheapo coil I bought off Amazon for $16 could have been something not at all like advertised:
Old 08-21-2020, 02:15 PM   #121
sbabbs
sbabbs's Avatar
Ford triton V8 ones seems the right lenght. Anybody try those?
Old 08-21-2020, 02:24 PM   #122
JohnMc
JohnMc's Avatar
Here's a couiple of quick pics I snapped (the motor is just sitting in the garage until I get the urge to put it in the PV):
Old 08-21-2020, 02:37 PM   #123
Will try without the seal, brb.
Old 08-21-2020, 02:44 PM   #124
JohnMc
JohnMc's Avatar
I removed the sides of the palstic flange the seal sits on. That's how it can sit all the way down in the rectangular depression in the head.
There's a spring inside the coil tip that engages the sparkplug - once the coil goes on the plug it will go down a fair distance.
Still, it's hard to judge, but your coil looks a bit longer. Like it's the same 'basic' coil, but there's that spacer below the main body - holding the boot.
Old 08-21-2020, 02:50 PM   #125
2manyturbos
Hopefully, along with a roll cage. A lightweight rusty shell with primitive steering, brakes, suspension and insane HP. What could possibly go wrong?
