Old 11-25-2020, 12:43 PM   #1
Polar971
Default goes up and down
Good afternoon, I have a Volvo 240 1991 Polar, with a SWAP from a B230ET. The car has a couple of modifications as the nose of an old model, has the lower fuel pump canceled, and a higher power inside the fuel tank. I also carry the rear axle welded so that I carry a configuration of drift type I imagine. A turbo boost and a pressure regulator with increased turbo and blowing to 0.8. The car is going very well.
The thing is that I had trouble blowing the pump fuse, then the injector relay and now, the car starts, goes up and down turns and stays up and down turns all the time ...
I changed the IAC and nothing, the same ... Someone can advise me something ... thanks
Polar971 is offline   Reply With Quote
Old 11-25-2020, 01:41 PM   #2
It's time to do a fuel pressure check. It could be that there is an issue with the fuel pump. With the fuse to the fuel pump blowing. I'm thinking the wiring was not upgraded when a high power in tank pump was installed. You may need to upgrade the wiring to the pump and add an extra relay to handle the power the new pump needs.
Old 11-26-2020, 04:49 AM   #3
Polar971
THANKS!!
Hello, I'll check all that, but I'll tell you. It has a parallel installation to the pump, if I plug it in I hear the pump, it works fine I think. But it follows that constant rise and fall of RPM. But on the normal installation, the pump doesn't sound... the relay opens and closes, but with the contact only not.
I will dismantle the throttle body in case there is any leak and check the installation.
The gasoline pressure regulator, I mark the rise and fall, it seems to go from 2.5 bar to almost 5 / 6 bar ... that's a lot, right?
Edit:
The TPS sensor when i unplugged, the car accelerate, i think it s normal... maybe its ok..
Old 11-26-2020, 06:57 PM   #4
Another thought was to check the alternator. If the output of the alternator had a problem. The voltage could rise and fall if it's not functioning correctly.
Old 11-27-2020, 03:37 AM   #5
Polar971
Ok, i'll check. thanks
Old 11-27-2020, 01:17 PM   #6
Polar971
Hi, checked, looks like works ok, charge almonst 14v etcc...
its like the ECU send it a emergengy cut inyection or some think...
EDIT:
It,s posible the fuel pump relay? i think its ECU.
Old 12-07-2020, 06:50 AM   #7
Polar971
Ecu testesd, with another... nothing.
The car was well for a seconds, and again aceleration and cut fuel mode... (go up and down)...
nobody ???nobody knows o can hel me?
I have Motronic sistem, the MAF, when i desconected, the car dies... it is not normal...
Old 12-08-2020, 07:52 AM   #8
Polar971
Hi, finally, the IAC (cis) is not working. Not voltage on middle pin... somebody knows where goes this wires? thanks
Old 12-08-2020, 03:48 PM   #9
h20ham
Think its a second ground
h20ham is offline   Reply With Quote
