#1 |
![]() I am having trouble finding my answer on here or the rest of the internet.
Folks, those who have installed stainless exhaust manifold studs, what anti-seize did you use on the stud going into the head? I have Permatex "aluminum" (silver color, supposedly contains aluminum, graphite & maybe copper?) anti seize on hand. Should I be using something different, or just send it with the aluminum stuff? EDIT: please move, accidentally posted to wrong subforum
'96 854 Platinum - "Trusty" '92 245 - "Boat" '71 145 - "Rusty" '93 Land Cruiser - "Ruby" '01 Cherokee - "Janice" Last edited by IansPlatinum; 08-05-2020 at 11:05 AM.. |
#2 |
lacks goats
![]() Any is better than none, but copper anti-seize can withstand slightly higher temperatures.
#3 |
![]() The solid copper or solid graphite paste is what you want.
The gray is just for getting all over your clothes and tools.
Cult Person. Pissing in your Kool-Aid. |
#4 |
![]() I use copper on really hot stuff.
#5 |
![]() Nickel anti-seize is for high temp applications.
Feedback: http://forums.turbobricks.com/showthread.php?t=341280 |
#6 |
#7 |
Redblock for life.
![]() I'd go for Loctite 77124 with stainless especially with the aluminum head.
#8 |
![]() If you go to the Permatex website
https://www.permatex.com/product-cat...ts-anti-seize/ and click on the particular product, you will see a tech documents tab. Open the TDS document and it will provide you with application information including temperature ratings. Permatex's application info for the nickel version suggest use primarily on exhaust stuff. |
#9 |
Living The Dream
![]() I'd suggest copper anti seize, but I would not suggest stainless exhaust hardware.
Maybe if we lived in Michigan, but here in TX I'm thinking the risk vs reward isn't there.
-78 242 tic, a kyotefab/willettrun joint -83 245 tic, daily in progress -14 F150 FX4 3.5 EcoBeast (Wife's) |
#10 |
![]() I believe I bought mine from Autozone and they had it on the shelf. You can ask if they can get it from warehouse.
#11 | |
![]() Quote:
![]() The nuts are the copper ones FCP sells. aluminum & stainless corrode, but not in a catastrophic way. We do 1000hr salt fog testing on stuff at my work, frequently containing junctions of aluminum & stainless (5052 & 316 specifically). I don't think it has ever caused an issue in our application, which is sensitive RF equipment & will detect if advanced corrosion is present because it'll induce PIM. And maybe this is one of those experience things where you'll end up being right, but I think the consequence of failure in this scenario is low. Also the car doesn't just drive in TX ![]() |
#12 | |
![]() Quote:
#13 |
![]() What's the right way to install studs, anyhow? Is there a way to keep them from backing out when you loosen the locking nuts?
1993 245 DL; LH2.4, M47 - DD & Winter Beater 1978 242 GT - To Be Restored, someday 1993 245 DL - OEM+ Project |
#14 |
![]() Hmm, now I'm curious, has anybody used this stuff before?
https://www.amazon.com/dp/B001HW82SW..._8UWkFbW5CSX7K High temp and non-metallic. Might have to give this one a shot. |
#15 |
![]() The stud coming out with the nut is from corrosion. The stud gets torqued to a spec if you are being careful. Tight enough to stay in there but not so tight it's jammed in the threads. Probably something low like 10-15ftlb as a guess. The anti seize being on there tends to make you over torque things so be careful.
I use the Wurth copper anti seize. Great stuff and the can has lasted about 20 years. The aluminum anti seize is good to low temp applications such as shock and suspension bolts.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 430k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
#16 | |
![]() Quote:
Just remove nut & reinstall stud. I think the two reasons for being a stud for this application are 1: hanging of manifold & gaskets 2: greater chance of removal. if it's a screw, you must loosen the junction at the aluminum head & fastener. If it's a stud, there's two chance that it'll come off without stripping or snapping and the stud has an unthreaded section mid-way that starts to snug up on the surface of the head. I think that's how contact pressure is achieved in the stud. I just measured my old OE volvo stud and the unthreaded portion is 7.95mm OD, threaded is 7.83mm. So I wouldn't really bank on its presence having to do with anything related to diameter. |
#17 | |
![]() Quote:
#18 | |
![]() Quote:
#19 |
![]() I've read about using Maalox to prevent galling of stainless bolt threads.
Trying to understand stupid people is like trying to pick up a turd by the clean end. |
#20 | |
![]() Quote:
I prefer the OE volvo studs over stainless for the exhaust side. |
#21 |
Astro Zombie
![]() I always prefer the "aluminum", the copper always turns gummy and weird on plugs and exhaust stuff. It's rated for 1600 degrees vs 1800 for the copper.
https://www.permatex.com/products/lu.../?locale=en_us
Feedback thread https://forums.tbforums.com/showthread.php?t=144924 1978 242, 5.3 L33 1979 242, MS, R brakes 2006 V50 T5 AWD @ 17 PSI |
#22 |
#23 |
How PSI a stock can support? Always Be Crushing! Last edited by Kjets On a Plane; 08-11-2020 at 12:04 PM.. |
#24 |
![]() ^ good addition, I also use the OE Volvo cupped turbo washers.
#25 | |
![]() Quote:
https://www.pegasusautoracing.com/pr...p?Product=MJET |
Thread Tools | |
Display Modes | |
