Old 08-07-2020, 12:55 PM   #26
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
When it comes to exhaust studs/stainless fasteners, I use Permatex 77124 Anti-seize. Works a trick
-Stephen
#mclovethesenuts
-My car: White 1991 244, 330k miles. B230F LH2.4, AW70, R134a retro
-Wife's car: White 1990 244DL, T cam, 200k miles.B230F LH2.4, AW70 w/aux cooler, Virgos, tow hitch
-PSM 2002 Subaru WRX wagon: EJ205, 5MT, 120k miles, Perrin TBE
-1997 Subaru Legacy Brighton: EJ22, 5MT, 236k miles
Old 08-09-2020, 04:05 AM   #27
Kjets On a Plane
Kjets On a Plane's Avatar
How PSI a stock can support?
Always Be Crushing!
Old 08-10-2020, 11:52 AM   #28
IansPlatinum
IansPlatinum's Avatar
I'm just moving alt to 940 location
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
'93 Land Cruiser - "Ruby"
'01 Cherokee - "Janice"
Old 08-10-2020, 03:49 PM   #29
Kjets On a Plane
^Above my pay grade.
I just try to swap bolt-on stuff without doing a custom engine harness or anything and get more life out of what's already there/keep the dual belts.
That, & the remote reservoir PS is usually a fountain of oozing gross mess on these cars, so the 92-93 240 PS pump is kind of a mercy/simplifies the engine bay, of the OE setups they used.
Old 08-10-2020, 06:08 PM   #30
IansPlatinum
no custom harness required. There are 3 wires that go beneath the crank. Those are alternator wire, alternator exciter wire, and oil pressure sensor wire. You just reattach the alternator wires, then make a small extension for the oil pressure sensor wire.
foregoing dual belts, yes, but also getting greater belt contact length on the pulley.
I think the only worry is collision with the distributor, but I've seen pictures of it working (240 engine swapped into 940 car)
Old 08-10-2020, 07:30 PM   #31
Kjets On a Plane
Old 08-10-2020, 08:03 PM   #32
IansPlatinum
You must not have driven a 240 in texas summers. The alt gets way too hot.
Zero charging at idle on stock and 100a denso. 100a bosch at least keeps it above 13V with AC on, phone charging, headlights on, aux fan on, rear evacuator fan, radio on, etc
The low alt is also more prone to water messing it up
Old 08-10-2020, 08:23 PM   #33
Kjets On a Plane
Old 08-10-2020, 08:27 PM   #34
240 turbos had a heat shield on the alternator. But by the time I got my car in 95 it was already rusty and falling off. Probably hasn't been available for a long time. Even the heat shields for the 90+ turbo manifold came up nla last time I checked. I count on that mechanical fan to keep the air moving.
Speaking of piping cooling air. My old 80 porsche 924 I had back in the 90s used a ducted cool air feed to the alternator. That was the first time I'd seen that.
Old 08-11-2020, 01:41 AM   #35
IansPlatinum
How much water are you driving thru?
Do you still have the OE 185R14 wagon diameter tires that barely leave snow-chain-clearance to the spring perch & stock springs?
Sometimes I don't know how deep it is.
I have a build thread. http://forums.turbobricks.com/showthread.php?t=351038
195/75r14
Old 08-11-2020, 01:57 AM   #36
Kjets On a Plane
Old 08-14-2020, 10:32 AM   #37
volvowagoon
volvowagoon's Avatar
I use copper anti-seize on exhaust bolts and O2 threads. It's been a big time saver when removing stuff down the road.
1986 Buick Grand National - The show car
2002 Camaro V6 T5 +T - The fun car
2010 C30 T5 - My daily
1989 245 DL - Girlfriend's daily
IG: @v6buick
