M.H. Yount
- Nov 1, 2008
- Charlotte, NC
Did the crank pulley get changed or size altered as part of fitting up the belt drive for the charger?
I deal with a more severe set of ambient conditions down here (plus A/C) -- not an issue at all on mine. Who knows....
edit - 'Course, I'm not trying to get it down to 170F either -- same issue might show up if I was.
This is a known common problem once I looked into it. LS water pumps just dont flow that much at idle.
[QUOTE/]springs first, then the front bar, but have them all with me at the next track day in case I want to make more changes. I also needed a little more tire pressure up front as I could feel the tires rolling over more than they should be. The extra camber should be a huge help though.
I hear ya on opening up the strut tower bar, like I have said before sometimes its a balance of aesthetics and performance for me. I still cannot believe that there are no instructions provided with any of Kaplhenke's parts as well as not a single one linked off of his website, Moreover, why doesn't the strut tower bar opening match the pattern on the top of the adjustable upper strut mount. I understand that not everyone will run them, but maybe have it as an option? I cut enough, not to mention I don't really want to send it off to have it re powdercoated.
On the engine temps, I understand thermal dynamics pretty well but this one has me a little bit confused. Its not load or speed related.
If I sit in stop and go traffic it will get up to about 211, this is in super mild temperatures like 50 degrees here in Portland as well as 95 degree weather in Vegas.
It will come down to 200 ish when I get moving. When I am on the freeway cruising at say 70 or so, with very little load on the engine 1700 rpm virtually no throttle it will run about 210 or so More accelerator or shift gears and it will drop.
Makes me think that the stat is more likely an issue than airflow. I do wonder if I am going to have to do some hood louvers to get some airflow through the engine bay. When I pop the hood though, its not really hot in there like I would think it would be.
Either way, its a next step, it either helps or it doesnt, but its the best path forward that I can think of.
Sean
This is why you see a lot of LS swaps running electric water pumps.
3-9pm - Pacific Raceways, Kent
