- Nov 12, 2002
- Santa Rosa Ca
driveline vibration t5 swapped 7/9xx 1pc driveline - with solution
So here's the deal. Goldie, my '92 940 project car got a t5 swap last july and has been plagued with problems since.
Relevant parts list:
flat flywheel, 8.5" spec s2+ clutch kit - it's not rpm dependent anyhow
solid under-drive pulley
Solid rubber 740 motor mounts
Rebuilt T5 (also tried a second borrowed T5 which didn't change anything)
modified aw71 x-member
energy poly trans mount
54.5" 3" DOM tube driveline (balanced)
new fancy spicher 1330 rear u-joints
used mustang slip yoke and 1350 u-joint
no play in either u-joint
full Kaplhenke rear end (subframe, tq rods, ph bar)
spherical bearings on tq rods, and panhard bar
freshly rebuilt 1041 rear end
new bearings shims and seals
axle shafts checked for balance and straightness
Pinion angle is set to 2.5 deg down at the trans and 2.5 deg up at the pinion. So they are equal and opposite with 2.5deg of working angle for the u-joints. I do not know how I can measure the side to side alignment, I'm just assuming that since it's in the center of the tunnel it's all good.
this is one of the sites i used to learn how to set a pinion angle:
http://jniolon.clubfte.com/drivelinephasing/drivelinephasing.html
Vibration tests were done with car up in the air (on the suspension), wheels, brake rotors and e-brake removed. So it's just the axle, driveline, trans, and engine spinning. Road tests have the similar results, with 2 sets of wheels and tires. RPM determined with 1:1 4th gear and speed on 3.73:1 rear end gear, 24.9" tires.
The symptom:
At 3200 rpm driveline speed (~60mph) I get a strong driveline vibration. I can visually see the driveline move up and down as it spins, and using applying a scribe slowly to the spinning driveline it will chatter and mark about 2" of the circumference of the driveline.
I didn't setup a dial indicator to measure how much deflection there is.
The vibration is felt strongly in the car up to about 4600rpm driveline speed (~90mph) where is smooths out.
I'm running out of options, i've rebuilt the trans, the rear end, and replaced all the motor and trans mounts. I've tried several different pinion angle combos, including raising the trans so that it's pointing up, and lowering the pinion. The driveline has been back to the driveline shop 2 times and each time they tell me that's it's perfect and that it spins up beautifully. They don't however include the slip yoke in the balancing.
I'm going to have them install a new front u-joint and a new slip yoke tomorrow. With those replaced, I don't know where else to turn.
What have I overlooked? How likely is it that there is a lateral pinion offset, and how can I check that?
Thanks for the help guys. I'm real close to scrapping the 1pc and going to a 2 piece.
Here's another good trans vibration thread:
http://forums.turbobricks.com/showthread.php?t=217894
The FIX:
As per Nathan's suggestion I checked out my bellhousing alignment.
First numbers were scary to say the least over .030 or 10x the allowed misalignment.
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5 Swap/Photo440.jpg
I rearranged the dial indicator to be more accurate and measured that it was still .010 out, so more matterial removed.
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5 Swap/Photo442.jpg
Getting closer:
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5 Swap/Photo443.jpg
How I aligned it was to clearance the opening in the bellhousing and slipping the adapter down.
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5 Swap/Photo444.jpg
A few more passes with the emery cloth, and a few more refittings and remeasurings I eventually got it close enough. The spec being passed around is .004" misaligned. I'm happy with .002"
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5 Swap/Photo445.jpg
Since the adapter was no longer interference fit into the bellhousing again as per Nathan's suggestion I decided to pin the adapter in place by drilling and threaded 2 7/16" bolts through the bellhousing and into the adapter.
I used an end mill to make 2 flat spots on the bellhousing.
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5 Swap/Photo450.jpg
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5 Swap/Photo449.jpg
Drilled and tapped some holes.
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5 Swap/IMG_0628.jpg
And bolted it down:
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5 Swap/IMG_0621.jpg
http://i483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/T5 Swap/IMG_0619.jpg
I also changed the tail housing of the T5 for another unit that had a significantly wider tailshaft bushing. The new bushing was only .750" wide where the old one from this other box was 1.25" wide so I figured it may help stabilize the slip yoke.
So that's the story, I got it all installed, dialed in 1.5deg of pinion offset on the driveline and ran it up on the jackstands. Ran real smooth well past 130mph will very little vibration at the problematic 65mph range. Put it on the ground and drive it, and god dam it drives like a regular 5 speed, not a car trying to shake itself apart. Simply amazing.
So thanks everyone for their help and support. I hope no one runs into issues like this, but if they do I hope that this will help them remedy it with less hassle.
as always pics an be found here:
http://s483.photobucket.com/albums/rr191/Magnumte/Volvo/Goldie/
EDIT:
I added some Lucas heavy duty oil stabilizer about 10-16oz (basically until my hands got wore out from squeezing the bottle to feed it up the tube into the trans) and much of the gear noise has quieted down. I don't need to wear ear plugs on the freeway anymore.
The symptom:
The FIX:
Getting closer:
And bolted it down:
EDIT:
