Old 10-06-2007, 12:27 PM   #1
barry240
Default 016 vs 012 maf meter
this is on my +t i have a 016 maf meter and i hear a lot of stuff using about using a 012 meter whats the diffrence ?
barry240 is offline   Reply With Quote
Old 10-06-2007, 12:43 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
012 is a 3" amm
better suited for having larger than 46lb/hr injectors along w/ moves the AMM cut point up a few hundred RPM
Chip Feedback Thread / PM for Discount Chip Prices / PM for DownPipe and Exhaust Prices / 240 Silicone Cooling Hose Sets
Old 10-06-2007, 03:08 PM   #3
barry240
seems like fuel cut happens at like 20 lbs on myne tho .maby its the freds chip
Old 10-06-2007, 04:24 PM   #4
thelostartof
unbalanced chemical
the chip does nothing to the AMM cut out point
Old 10-06-2007, 04:27 PM   #5
phenry
my name is Ram
phenry's Avatar
Originally Posted by thelostartof View Post
012 is a 3" amm
Sorry to be a hassle, but what size would that make an 016?
Originally Posted by -DARKSIDE- View Post
I shave my pubes and draw them back on, the ladies love it.
phenry is online now   Reply With Quote
Old 10-06-2007, 04:30 PM   #6
thelostartof
unbalanced chemical
2.75 or maybe a little smaller
Old 10-06-2007, 04:50 PM   #7
frpe82
Guest
2.48" ID I think. I can be wrong though. It was a long time since I measured one.
Old 10-06-2007, 05:17 PM   #8
thelostartof
unbalanced chemical
haha yea it has been a long time since i have had one here, and yea i think 2.5" is the size as my old cone filter was 2.75 so yea
Old 10-06-2007, 06:01 PM   #9
barry240
i do have ford red top injectors so would a 012 be a good or will it over advance the timing .because of the diff in load
Old 10-06-2007, 08:20 PM   #10
Booster
v-tec kicked in yo!
Booster's Avatar
arent ford red tops equal to stock green tops? i would wait untill you up to brown tops or something larger before going with the 012.
im just here to make chunga
Booster is offline   Reply With Quote
Old 10-07-2007, 06:42 AM   #11
stoni
stoni's Avatar
i have measured out a 012 today, the 012 ist 34% larger than a 016, therefore you need 424cc/min injectors on a B230FT to match exactly for gasoline or 590cc/min for E85 (smallest for E85 is round about 530cc/min, the rest will be managed from the LH)...
Data:
016
- internal diameter 62.5mm - 2,46"
- external diameter 70mm - 2,75"
- = 30.67cm2
012
- internal diameter 72.5mm - 2,85"
- external diameter 80mm - 3,14"
- = 41.28cm2
That's a increase from round about +34%
SeBCON-µC Programmable Boost Controller
My ride: 945 Turbo MJ. 1993, 530, T-cam, +90M, T3, 10.6:1, 13.5psi, 470cc/min injectors, 977 ECU / EZK 148 with +3deg. mod., 012 AMM, M46/3.73, E85 fuel, 2.5" 200Cel metal race cat, tight squish squirter block (0.030inch)
stoni is offline   Reply With Quote
Old 10-07-2007, 03:12 PM   #12
frpe82
Guest
Data:
016
- = 30.67cm2
012
- = 41.28cm2
Also an addition from someone who knows LH... (that is me btw)...
You are absolutely correct in what you are saying Stoni.
But this is my input:
To run the 012 (and make it mathematically correct) you need to use 436-452cc/min injectors for gasoline.
To run the 012 with E85 you need to use 620-642cc/min injectors. Preferrably up to 764cc/min if you want to really get some power.
But like I said Stoni, you are right in that you can run the B230FT on 590cc/min injectors. On E85 you don“t have to be very exact. Both the octane and cooling properties are better and you can get away with smaller injectors than what is mathematically correct.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
