Old 12-07-2008, 02:12 PM   #1
jv_72_jv
Default Is the volvo 2.9 I-6 a good engine ?
I'm looking a buying a 1992 960 with 210,000 miles and in great condition. My question is: are the 2.9 I-6 good reliable engines ?
John
jv_72_jv is offline   Reply With Quote
Old 12-07-2008, 02:18 PM   #2
doeboy
main problem with an older 960 is that the timing belt has to be changed very frequently because this was probably the 2nd overhead cam shaft design volvo had and thus it puts a lot of pressure on the timing belt. on the early ones i heard like every 20k miles. check out this spot http://www.swedishbricks.net/700900F...%20Information
i dont know if i would buy a 92 with its original block..
doeboy is offline   Reply With Quote
Old 12-07-2008, 03:10 PM   #3
DrvSfly
Bored Clown
DrvSfly's Avatar
Thumbs down
In a nutshell, no. We recently had a Volvo tech in our shop looking at an insurance claim and came across the job I was working on. I was pulling a I6 block out the was cracked between cylinders 3 and 4. He said they have had some bad castings and he has seen it a bit. Of course there is more going on with 6 cyls instead of 4. But then I love the b230. simple.
Drive Safely
I think we'll either get rid of religion, or it will get rid of us.
'83 245 TIc sold
'97 960 totalled
'94 745 totalled (not mine)
'87 744 totalled (not mine)
'91 780 totalled and sold
'81 b21f, T cam, Lh2.2, 960 injectors, junkyard/back of the shop 15" trash rims. - Sold
DrvSfly is offline   Reply With Quote
Old 12-07-2008, 03:11 PM   #4
decalservice
Stickin' it to the world!
decalservice's Avatar
Run away. That engine ranks up there with the Bertone 262 v6.
decalservice is offline   Reply With Quote
Old 12-07-2008, 03:16 PM   #5
Geoff240Ti
Geoff240Ti's Avatar
I just bought a 96 960.. the engine has 66,000 miles on it, and it has terrible compression numbers. Not sure exactly why.
Some people like these engines, but I don't think anyone can disagree... they generally give ALOT more trouble then an average engine. Yes, they need to be maintained properly.. and that has alot to do with it. But still.. you find alot of 960s with bad motors, or strange cylinder head problems.
I will probably replace my engine with another I6, hopefully it'll hold out well. But even finding another one of these engines make me nervous.
Geoff
Geoff240Ti is offline   Reply With Quote
Old 12-07-2008, 03:33 PM   #6
Fivehundred
Fivehundred's Avatar
The late ones are fine. I pulled the engine out of my scrap yard sourced V90 with 344K miles on it. The bores are unworn. Most seem to get killed by people allowing the timing belts to break.
The early versions did suffer from porous castings.
Fivehundred is offline   Reply With Quote
Old 12-07-2008, 03:45 PM   #7
sacrifice
The early blocks are prone to leaks and cracks. I have a 97 960 with ~150k and it still runs strong. It has been taken good care of. Timing belt always changed on time and tune up stuff, etc.. The only complaint i have about the 960/s90 is that it EATS brakes like nothing.
granny shifting not double clutchin like I should
sacrifice is offline   Reply With Quote
Old 12-11-2008, 11:32 PM   #8
LloydDobler
LloydDobler's Avatar
Yeah, like a bertone V6 ever went 210k...
Every 960 I see for sale has over 150k on it. They're very reliable, just don't ever let the timing belt break.
