Old 01-13-2009, 12:08 AM   #1
decalservice
Stickin' it to the world!
decalservice's Avatar
Default Hit a curb going 10mph, now steering wheel is crooked. - Please share experience?
Hey guys,
I was on a date today and as luck would have it, I hit and went over a curb while turning. The car drives fine, and there is no shaking or major pulling to the left or right, but my steering wheel is off by about 10%. When I called my dad said "You know you only need ONE hand up her skirt, right"?
It wasn't funny considering the circumstance.
Before I take it to the alignment shop, I was going to ask If anyone has had this problem before..
Did an alignment fix the issue? I don't see anything bent, and there's no major driveability problems..
How does the car go out of alignment? Aren't there adjustment screws that need to get stripped of thread before it can me misaligned?
Hoping you can share some knowledge?
Cheers,
Rod
Www.DecalService.coM
(512) 228-8811
Austin, TX.
"Now with more lasers!"
decalservice is offline   Reply With Quote
Old 01-13-2009, 12:30 AM   #2
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
hit a curb at the same speed on the other side, should be good.
seriously though, your alignment IS off, or you skipped a tooth on your steering rack. Could have f**ked a tie rod as well or shifted the steering rack.
If you break a weakened tie-rod at speed you WILL crash, so take it in and have a pro check it out.
we dont need a dead t-bricker.
1982 GLT 244 redwood metallic, turbo, lowered...RIP
Colonel Mustard: 1979 242DL, B21A, SU carb, M45, GT sways, Limited-slip, rad hubcaps, Manual rack, no ac e-fan
Originally Posted by NativeJesus View Post
This isn't even a trailer park suspension.
Old 01-13-2009, 12:39 AM   #3
pooprah
Guest
you probably bent a control arm
Old 01-13-2009, 12:58 AM   #4
moxy123
moxy123's Avatar
Post
What about the girl, did you knock her out of alignment too?
moxy123 is offline   Reply With Quote
Old 01-13-2009, 01:21 PM   #5
doeboy
Thumbs up
yeh 10mph its either alignment or control arm or radius rod. the alignment shop would probably do a shake down of the suspension to make sure there arent things that would throw the alignment out(a reputable place would) i remember when i got my last alignment it was an outer tie rod end that was messed up and it was real cheap to fix.
doeboy is offline   Reply With Quote
Old 01-13-2009, 01:22 PM   #6
Falcone
Falcone's Avatar
Watch out for this
Mike
K-Town Brick Militia________94 854 The BBQ
I was us up all night with a rusty hammer trying to build a fence around these magic beans my dreams have gathered
Falcone is offline   Reply With Quote
Old 01-13-2009, 01:32 PM   #7
cmunkee
cmunkee's Avatar
How in the hell is that still holding air!!!
cmunkee is offline   Reply With Quote
Old 01-13-2009, 02:45 PM   #8
Chris_R
Kickin' rocks in sandals
Chris_R's Avatar
The air is frozen inside.
Ermergherd!! Erm gernner kerhm!!
1995 964 (Silver)
1992 944Ti (White)
1996 965 (Burgundy) - Scrap
1994 945 Ti (Black) - Sirius Black Scrap
1992 944 GL (Black) - Killed by drunk driver
1988 745Ti (Silver) - Sold
Originally Posted by TurboBrickMan View Post
Long story short I found out she's a squirter.
Chris_R is offline   Reply With Quote
Old 01-13-2009, 02:56 PM   #9
Falcone
Falcone's Avatar
Its been holding 40psi for three weeks now, Boggles my mind, but tire is starting to buldge where sidwall is missing. Oh well
Mike
Old 01-13-2009, 03:25 PM   #10
cmunkee
cmunkee's Avatar
decal service... What hit the curb? Tire only or other? My brother hit a curb head on going head on at 10 mph (I think he's full of ish) and the suspension cross member got bent and it broke the steering rack off. Granted my '83 245 is way too low. Just take a rally close look at everything underneath especially if you heard metal hit the curb.
Old 01-13-2009, 06:57 PM   #11
decalservice
No, didnt hear metal hit the curb, and i didn't go parallel with the curb.... in other words, i was 90 degree angle with it. It happened when I was trying to turn left onto a twp way street and didnt see the divider, and I went over. I really didn't hear any sounds, and my air dam wasn't even damaged... I haven't had time to take it to an alignment shop, but just wanted to see if it was probably just alignment if I cant see anything bent really.
Old 01-14-2009, 01:45 PM   #12
samWagon240
u raka disiprin!
samWagon240's Avatar
Your dad doesn't know what he's talking about. Drive with your knees, and put your hands to better use.
Seriously, you more than likely will need alignment, and have them check the vehicle for bent things. If the shop is worthwhile, they should be able to give a thorough inspection of your steering & suspension components within a few hours, and diagnose what problems you may have. Shouldn't be anything major if you were only going 10mph.
Make sure they don't just overcorrect your alignment so the car goes straight! Sometimes a shop will do that to cover up real damage if the mechanic/tech is in a hurry or is just a lazy SOB. Have them give you a printout of your alignment settings, and then show those to a mechanic at another shop. If the other guy's eyes bug out, you've been hoodwinked.
Good luck.
samWagon240 is offline   Reply With Quote
Old 01-14-2009, 02:00 PM   #13
2manyturbos
You certainly bent something. The only way to deal with it is to take it to an alignment shop and have them attempt to align it. If they run out of adjustment on one side, then you will be able to narrow down what changed. It doesn't take much distortion to really change the alignment.
Old 01-15-2009, 01:02 PM   #14
vvpete
I was driving around my neighborhood in the 245 looking for my dog that took-off from the backyard, and while cruising in 2nd gear, looking out the window (instead of where I was going!), I hit a storm drain cement abutment that was only ~8" high. The car having IPD lowering coils, hit the corner of the cement drain square-on the steering rack and crossmember, right in the middle, 90 degrees, and went under the air dam. I bent both the rack & crossmember. The car sort-a drove OK, and had a rough spot in the turning circle, but within 500 mi I got a lot of tire wear.
Most likely the rack or one of the tie rods are bent, although probably not evident or visible, can't be good if the alignment is that bad. It should be obvious where the contact was made. If the curb hit the aluminum rack, yould not necessarily hear a metallic sound, just a thud or nothing at all.
Put the front end up on jacks, and turn the wheel lock to lock, and look for glitches in the movement, or restrictions one side or the other.
If your car has more than 150k mi, and you find a tie rod bent, replace the whole rack w/ends, as replacing just a tie rod is throwing good money after bad.
Time to replace the rack.
vvpete is offline   Reply With Quote
Old 01-15-2009, 03:00 PM   #15
gatormotorhead
Because you say you hit the curb headon, I'm more likely to thing the problem is in the control arm/bushing than it is in the tie-rods or steering rack.
2001 BMW 330Ci - ZSP - 5spd
1998 Toyota Camry 5SFE
1993 BMW 525i 5spd - SOLD
1991 Volvo 240 B230F NA
1999 Jeep Grand Cherokee 4.0L
gatormotorhead is offline   Reply With Quote
Old 01-15-2009, 03:10 PM   #16
adrianpike
adrianpike's Avatar
I jumped a curb at 50mph and blew both front tires, have you checked those?
Seriously though, you bent something. Have a pro scope it out, or crawl underneath and figure it out yo'self.
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 01-15-2009, 05:22 PM   #17
decalservice
YES!!!! IT's official! Nothing broken or visibly bent!
NTB did an alignment for $70 and life is better than ever now. However, he could not get the camber to spec, so I told him to leave it at - 1.5 deg.
Old 01-16-2009, 07:20 PM   #18
psy
psy's Avatar
$70???? I think most I ever paid was for $50 and that was from a shop that all they did was alignment but hey if nothing is broken
http://votom.mybrute.com
“It is possible that mankind is on the threshold of a golden age; but, if so, it will be necessary first to slay the dragon that guards the door, and this dragon is religion"
psy is offline   Reply With Quote
Old 01-17-2009, 02:47 PM   #19
shellshock
Below, is a photo of Clay
shellshock's Avatar
I did this with my V70 just about a month ago when it was icy. I slid into a curb going really slow while turning. My wheel was off and the steering felt odd. I took it into the tire shop to see what was up and after they got it on a lift it was apparent waht was bent. I toasted a engine sub frame and the control arm.
Glad to see nothing is messed up! 240s are ****ing tough. I've been retarded in mine so much and the car always pulls through. That cant be said about my V70, haha
1988 740 Turbo
2005 S60R M66 flashcama
2007 XC90 V8 Sport
1983 SAAB 900 Turbo
shellshock is offline   Reply With Quote
Old 01-17-2009, 02:55 PM   #20
Coupe' de Grace
Slowest in the West™
Coupe' de Grace's Avatar
see other thread for continuing fun.
V A F
(1976 265dl/b27/m46 killed in battle, 1991)
(1976 265dl/b27/bw55 bring out ye dead, 2000)
(1980 262c/b28/m46 trebuchet fatality 2014)
1982 244t/b21ft/aw71 'Vicious Chicken of Bristol'
1989 780/b230ft/aw71 'Brave Sir Robin'
Coupe' de Grace is offline   Reply With Quote
Old 01-17-2009, 03:07 PM   #21
decalservice
No kidding!!!!
Old 01-18-2009, 11:31 AM   #22
dmax99
Chances are that if the tire took the hit ,the knuckle got bent.If it's not to badly bent it may still be able to be aligned properly.
dmax99 is offline   Reply With Quote
