Old 03-07-2012, 05:10 PM   #1
940guy
940guy's Avatar
Default innovate lc-1 calibrate to tuner studio?
I followed the below instructions and have the lc1 wired up correctly. but i am getting a reading that hovers around 10.2
Anyone have something i can try setting on the lc1 are defaulted for wideband.
Originally Posted by diyautotune View Post
MS2/Extra:
With your TunerStudio project open, go to:
File > Project > Project Properties and click on the Settings tab
Under EGO O2 Sensor, chose the right option (Innovate LC-1 Default) for your wideband in the drop down menu and click Ok. TunerStudio will quickly restart and take you back to the main dashboard.
Next, click on the Basic Settings tab and chose EGO Controls. You will need to change your EGO Sensor Type to wideband or dual wideband as appropriate for your setup. Don't forget to burn the change to your MegaSquirt. Lastly you will need to go to the Tools menu up top and click on Calibrate AFR Table. Chose your sensor type (Innovate LC-1 Default) in the drop down menu, and click on Write to Controller. This is a one way flash, so don't be alarmed if your settings don't 'stick' in this menu after you've sent them to the controller. After the write is complete, click Close.
Your AFR Targets Table will be under Basic setup > AFR Table 1
93 944t
b230+16v+holset hx35 16cm hot side +75shot CRUSHED
01 v70 boring DD
88 745 racewagon lots of around cones goodies
940guy is offline   Reply With Quote
Old 03-07-2012, 05:14 PM   #2
JohnMc
JohnMc's Avatar
I'd have to look. I had a pretty persistent .5 difference between what the gauge showed (which I would assume is accurate) and what TS picked up (a voltage over a line, interpreted into a numeric value, subject to fudging). I had to mess with it for a while to get the two numbers to match better.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 03-08-2012, 07:08 PM   #3
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
At least yours works. My buddy and I couldn't get his to stop flashing 7.0 no matter we did.
'91 744t...it's fast as phuck
Old 03-08-2012, 07:20 PM   #4
gsellstr
gsellstr's Avatar
I thought that was just a fluke on the 140, guess not! Mine was .8-1.2 different until I ran the LC1 to the same engine ground as the MS box, which brought the readings on TS closer to the DB gauge. TS also reacts way faster than the gauge.
As for the OP, the stuff you quoted worked just fine on mine. Have you confirmed the setup and output voltages coming from the LC1?
RIP
74 144 B20
90 745Ti
Old 03-08-2012, 08:52 PM   #5
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
Having a wideband not log correctly blows for others viewing. My LC1 didn't log accuratly either, so after getting frustrated I litteraly tossed the whole controller anf guage down the street and bought an AEM!
962j 815/692@27psi
THIS IS FORSALE V
Old 03-10-2012, 12:01 AM   #6
MrBill
fige=500Dollar Mistake
MrBill's Avatar
I've gone through 3 LC-1s and finally decided they are complete garbage.
SLCPurePlus
Someone say crazy rays?
Old 03-11-2012, 10:49 AM   #7
550
I have no issues with my LC-1's :-/
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
