Old 03-31-2012, 09:04 AM   #1
Wottel
Default engine swap volvo 240
=) wondering what's the best option for an engine swap in my volvo 240 with a B19A.
Whats the most practical ? :
a B230FT and put a 16 valves head on it.
or a B234 and put a turbo on it
Offcourse the engine will be combined with a M90 gearbox.
Thanks !
Wottel
Wottel is offline   Reply With Quote
Old 03-31-2012, 09:51 AM   #2
Practical?
93+ B230FT
Old 03-31-2012, 10:48 AM   #3
Wottel
Practical?
93+ B230FT
=) what do u mean : 93 ?
Old 03-31-2012, 11:17 AM   #4
M.H. Yount
M.H. Yount's Avatar
He means a 1993 or newer model year B230FT - I think. Although I'd just put an LS in it.
Old 03-31-2012, 02:24 PM   #5
viking20
Are you from Europe ?
How much work you want to do , and where you want to do the work/spend the money will decide this for you
The guys are trying to tell you that an 8 valve turbo will be the easiest to adapt to your car.
A newer turbo engine from a 900 series will bolt in to your car without much work ,if any.
Then you will need an engine harness from a 240 with LH 2.4 , and use the turbo boxes from the 940
To use the 234 head on a B230 block , you have to get custom cam belt parts , tensioner etc. These parts are available from the aftermarket , or you can use Penta marine stuff for bolt-on stuff. The Penta AQ 171 used the 16 valve head on the B230 .
Either way , it will cost a bit of money. You can also do a budget job with a belt from an Opel , and a tensioner from a VW Golf mk 1.
Most B230 engines use square tooth wheels for the belt , and the 16v use round-tooth , so youll need new cam/crank gears as well...
The manifolds: No b234 turbo engine was ever built , so you will need the exhaust manifold from the ( 2 litre turbo) b204 engine , or an adapter kit to use the 90+ manifold from a b230.
Off course ,a full-on custom tube header can also be used. The intake manifold from the 234 are not considered ideal by most people ,and will be hard to fit in the 240 because of clearance problems.
Again the b204 part can be used , but both manifolds from a b204 are rare , and will cost quite a bit of money.
The b234 block wont fit in your car , right side motor mount will need to be custom made. If you solve this , there is no room for the distributor in a 240 , as it is mounted at the back of the head.
You can use a block mounted distributor on a b230 block , but not on the b234. The shaft in the block isnt there , and you cant fit one....Of course , there is wasted fire ignition without a dizzy , but again.....
You will have to do some kind of custom engine management if you go the 16 valve/turbo route , Megasquirt or something similar is the only way.
If you plan it thoroughly you should be able to swap in a b230 Turbo in a few days. Most 16 valve turbo builds will take a lot longer , and could cost you a lot more
viking20 is offline   Reply With Quote
Old 04-01-2012, 09:00 AM   #6
Wottel
yeah i'm from Europe (Belgium). So its hard to find custom pieces and turbo engines.... )=
Most of the pieces can be ordered in the states but are overprieced when shipping
I dont want an overpowered 240. I will be glad when i have around 200-250 HP.
Maybe the best thing is to get a 740 with a B230FT and swap this engine in my 240. Then i have also all components and wiring. Put work and offcourse money in the engine and hopefully i will get around that 200-250 HP.
Is there any big difference in the B230FT an B23FT ?
Thanks for your help !
Wottel
Old 04-01-2012, 09:15 AM   #7
740volvo
There is, they are way different in the inside and the B23FT is way more expensive to rebuild then the B230FT.
740volvo is offline   Reply With Quote
Old 04-02-2012, 04:35 PM   #8
jdean299
jdean299's Avatar
Can the harness from a LH2.4 940 not be used in a 940 to 240 swap?
jdean299 is offline   Reply With Quote
Old 04-02-2012, 04:43 PM   #9
It can with a bit of work.
A 240 engine harness is much easier.
Old 04-02-2012, 06:02 PM   #10
Mylesofsmyles
It can with a eternal amount of work.
FTFY
Old 04-03-2012, 02:32 AM   #11
viking20
The 240 LH 2.4 harness , is completely separated from the rest of the car.
In practice you change out the engine harness , and the rest of the car stays the same.
If you have a B19A now , the car is probably too old to be prepared for LH wiring inside. You will have to add 4 or 5 wires in order to make the car run.
Then theres also an issue about needing the electronic sensor in the rear axle for the speedo , which your car wont have if its from before 86. You can read a lot about this in previous threads on TB , and elsewhere.
I dont have any experience with the newer models , but have read that the engine wiring is a lot more integrated with the wiring for the rest of the car.
Do a search , many people have done all this before you.
Old 10-09-2014, 01:52 AM   #12
volvostig
Default 1983 volvo 244 gl
I just bought a 1983 volvo 244 gl was wondering what would be the easiest engine to swap and add a turbo and trans.
volvostig is offline   Reply With Quote
Old 10-09-2014, 02:18 AM   #13
2fast242gt
Do you have a cobalt?
Lol what?
1983 242dl
*6.0 lq4 swaped* Build thread
Old 10-09-2014, 09:58 AM   #14
Mueller
Mueller's Avatar
get the turbo stuff off of a 740/940 turbo motor and put on your current motor...or install complete turbo motor into your car.
No other "easy" swaps....if you have to ask, not easy for you.
Old 10-09-2014, 10:32 AM   #15
John V, outside agitator
crank journal sizes---but that doesn't cost anything.
crank is steel, that doesn't cost anything.
Bearings are bearings, gaskets are gaskets, they interchange, seals all interchange...
Aftermarket forged pistons cost the same if you specify 24mm pin and 46.xx mm comp hgt or 23mm pin and 39,7mm comp hgt or get smart and go 31,7mm and 22mm pin--all the same cost
Aftermarket longer and better rods for B23 or simply better for B230 cost exactly the same..
What is it that supposedly is "way more" expensive?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 10-09-2014, 10:37 AM   #16
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
The pistons have been NLA forever, so you'd have to buy custom pistons.
John. Not every thread is a chance to sell some dude pistons.
Hey guys, should I buy a 740 as an engine donor for my 240?
Yeah. Buy these cool custom pistons for it too.
Originally Posted by rvolvor
Old 10-09-2014, 10:43 AM   #17
poulrais
poulrais's Avatar
He probably meant to say that rebuilding a B23FT with performance and upgraded parts is more expensive than rebuilding a B230FT...
1990, Volvo 740 16v +T
poulrais is online now   Reply With Quote
Old 10-09-2014, 12:45 PM   #18
Pistons other than a few sizes are drying up faster than hell...
And those around are expensive..
It's clear this OP is not interested in a big build...but the claim the B23 is "way" more expensive is the ONLY thing I was questioning..
What's "way"?
(you don't have to be suspicious of every single post a person makes..The amount of bad info here, persistent myths etc is terrible)
Old 10-09-2014, 01:06 PM   #19
Mueller
Mueller's Avatar
What's "way"?
Posted over 2 years ago...guessing he might have solved this issue by now
I sent you an email....check it!
Old 10-09-2014, 01:35 PM   #20
Derp! for all of us!
I just emailed you.. Send your Paypal addy.
Old 10-09-2014, 03:11 PM   #21
mikep
The MP
mikep's Avatar
I don't think that was his intention.
And even though this is a 2 year bump for a noob to ask a question, I will let it run out, rather then locking it.
So, my answer to "what's the easiest" is:
Get a whole donor car. That's the easiest.
Originally Posted by 4x4_Welder View Post
You have some very specific issues.
Old 06-25-2017, 02:43 PM   #22
Teel_adam
Question What engine would be most reliable, powerful, and easiest to swap?
I hope to purchase a volvo 240 ASAP! Please let me know if you know of any two doors for sale.
Anyways... i would be engine swapping. I can't decide on a 2JZ, LS2 or an RB20.
What would you swap and why?
Teel_adam is offline   Reply With Quote
Old 06-25-2017, 04:26 PM   #23
Dan Stokes
Of course, the LS is a decent swap - but I simply don't like them. It's an UGLY engine! Personal preference thing. Don't rule out a Ford small block. The low deck engines (289/302, for example) fit really well but the tall deck (351/5.8L) are a pretty tight fit. The SBF is a bit smaller than a Chevy and that simplifies the swap considerably. Either the Ford or the Chevy will make more HP than you can use and either will get your attention when depressing the loud pedal so it's kind of a toss-up. We're back to that personal preference thing again!
The Ford, when fitted with aluminum heads (relatively cheap) is just a bit heavier than the LS but not enough to notice. There are lots of cheap carb intakes for the Ford which can simplify the swap considerably though I DO like EFI.
JTR (Jags That Run) and other companies make installation manuals and some swap parts for either engine - use them! Folks THINK they're going to save money by making their own stuff but it's false economy. At the very least buy the manuals!
Dan
Dan Stokes is offline   Reply With Quote
Old 06-25-2017, 04:31 PM   #24
Tuff240
240 Ninja
Tuff240's Avatar
The LS based motors are easiest to swap because people like STSmachininginc.com make parts for it. Cheap, easy and reliable. There is a reason everyone swaps to those motors.
-Patrick
Old 06-25-2017, 05:13 PM   #25
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Nevermind.
