Old 06-09-2012, 12:54 AM   #1
volvoboy90
sanna kärlek är svensk
volvoboy90's Avatar
Question Simple easy question (i hope)
Ok, I have in my hand new IPD poly sway bar end link bushings which will be put onto my '89 244 dl. Then I got to thinking, what would be the easiest way to push out the old bushings and push in the new ones without destroying my endlinks in the process? I assume they fit snugly inside the endlink, and I really don't want to cause more damage than I have to. Any respnses and advice is appreciated, thanks!
Originally Posted by TrickMick View Post
HEY...we're all in this "Volvo stuff" together here @ Camp TBrix...
keeping the "oldies but goodies rockin' down the road"...
*PICK YER POISON*...either put a raw egg under your gas pedal
and tip-toe around town - *OR* learn to live with the GREAT FUN of
sucking unsuspecting "other brand drivers" into the educational benefits
of NEVER underestimating a "grandpa car" again....hee, hee....
RIP TrickMick You'll be missed
volvoboy90 is offline   Reply With Quote
Old 06-09-2012, 01:01 AM   #2
Lando
Arthur Digby Sellers
Lando's Avatar
If you need any tools to remove sway bar endlink bushings, once the end links are disconnected, you need to hit the gym. I am 6'7" and only 180lbs and have never had to press out an end link bushing.
SST: your fingers, and possibly any pair of channel locks, will do the trick.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is offline   Reply With Quote
Old 06-09-2012, 01:04 AM   #3
volvoboy90
volvoboy90's Avatar
Haven't taken the old ones off yet, and I wasn't sure if it was just going to be a pain to get them out or not...
Old 06-09-2012, 01:10 AM   #4
Lando
Lando's Avatar
They should slide right off with one finger on either side and a solid yank.
Old 06-09-2012, 01:11 AM   #5
volvoboy90
volvoboy90's Avatar
Good to know, thanks Lando.
Old 06-09-2012, 01:11 AM   #6
MasterBlaster
This style, that goes inside the loop on the right side of the endlink below?
Or the squishier rubber version?
Out should be: cut off one side & punch the rest out.
In would be: remove the metal sleeve, LOTS of lube, long bolt, nut, washers, big socket, maybe something metal & funnel-shaped to squeeze it while pushing it in, like a piston ring compressor, just smaller. A piece of tin can & a hose clamp?
453,000 km so far...
Old 06-09-2012, 01:14 AM   #7
Lando
Lando's Avatar
Originally Posted by MasterBlaster View Post
These might require a vice or possibly a press to install, but removal should be cake.
Old 06-09-2012, 01:14 AM   #8
volvoboy90
volvoboy90's Avatar
The poly blue ones are what I am putting in, the old ones are original 23 year old volvo rubber.
Old 06-09-2012, 01:17 AM   #9
Lando
Lando's Avatar
If you dont have a vice or a press, sauce it up real good with silicone and use a couple of pliers to squeeze it in. Be careful to apply pressure to only the metal sleeve and non threaded portion of the endlink. If that doesnt do the trick, a deep well socket that clears the threads but contacts the sleeve, and your weight will work.
Old 06-09-2012, 01:25 AM   #10
volvoboy90
volvoboy90's Avatar
Simple enough, thanks... I am planning to do this in the morning before I go to work... Hoping for a ncie and simple in and out job.
Old 06-09-2012, 01:27 AM   #11
Lando
Lando's Avatar
You can only hope...
