Old 07-22-2012, 02:00 AM   #1
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
Default 962j
Hey guys. Thought I would get something started to keep track myself of whats going on. As you all know, I lost my motor on the Dyno and am doing a 2jzgte non vvti swap now. Ive got some things underway and wanted to show.
Original thread here. http://forums.turbobricks.com/showth...highlight=941g
So the plans are to freshin up the motor, do some h beam rods, forged pistons, S1 cams, springs/retainers, divided header, intake, and a new Billet 6466 ball bearing turbo (this thing is badass, spools like the 6266, but makes power like the 6766)
Using a midsump pan the engine sits in the bay perfect, and wont be any farther forward than the 16v motor was.
Im mating the engine to the T56 already in the car. And this is where the story begins.
Theres a dxf file that uses the auto bell and adapts a T56, so mocked up an adapter and ridded the tranny of the internal slave and afixed the stock type pull Toyota clutch setup.
Pan mockup
Started engine tear down
Engine blown apart
Tranny adapted
Getting the stock fork to work
And cutting a hole in the oil pan to get a pull style Wilwood slave installed.
962j 815/692@27psi
THIS IS FORSALE V
Old 07-22-2012, 02:02 AM   #2
nathaninwa
nathaninwa's Avatar
saved.
Old 07-22-2012, 02:02 AM   #3
nathaninwa
nathaninwa's Avatar
future updates
Old 07-22-2012, 02:03 AM   #4
Homer
OEMplus++
Homer's Avatar
Saved
-Jacob:
2017 allroad - Comfy DD
Old 07-22-2012, 02:12 AM   #5
Manbeard
#helpbrock2k16
Manbeard's Avatar
inb4 page 95
2012 tdi
Manbeard is offline   Reply With Quote
Old 07-22-2012, 02:20 AM   #6
VQ
Not such a PRVert Anymore
VQ's Avatar
Someone want to explain the 941g and 942j thing to me?
What's the advantage of removing the internal clutch slave designed for high torque V8's and heavier clutches?
Old 07-22-2012, 02:28 AM   #7
nathaninwa
nathaninwa's Avatar
The 941g code name came from the 940 + the 1g (first gen mitsubishe engine management)
And the 942j name came from the new 2jzgte engine going in since the 1g stuff is gone.
I dont mind the internal slave...one failed (mostly my fualt) but with a new clutch setup I was tired of special this and special that. So I opted for a complete 1jz turbo clutch setup that is designed for a pull style pressure plate....so I need the stock setup to pull on it instead of pushing on it.
Old 07-22-2012, 02:35 AM   #8
shaved240
shaved240's Avatar
Here
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
Old 07-22-2012, 02:39 AM   #9
VQ
VQ's Avatar
Interesting, I guess that makes sense in-case you ever sell the car to someone who sends their car to mechanics..
Old 07-22-2012, 02:42 AM   #10
Lord_Athlon
Chuckie Blows
Lord_Athlon's Avatar
I like.
Yet Asher here went with...
Old 07-22-2012, 02:45 AM   #11
Texas240
Prius Owner
Texas240's Avatar
InB4 Penis Jokes.....
93 245 LS Engine Swap Project
Old 07-22-2012, 02:49 AM   #12
Hey-o!
Old 07-22-2012, 03:30 AM   #13
dieselboy
Whooty patrol
dieselboy's Avatar
This should be interesting.
'82 242t hy35 @28psi, ebay header, big intercooler, microsquirt ecm, rsi stg2 cam, arp headstuds, tremec tko600, 3" exhaust, 13" brembos, coilovers, saabspoiler, 245/40r17s, lots of yoshifab stuff.
'12 flex ecoboost "kats" car
'93 940 turbo lifted #trophyvo
'08 f350 4x4 v10 cclb
'97 f-350 4x4 offroad toy
'94 4700 dt466 International toterhome build
dieselboy is offline   Reply With Quote
Old 07-22-2012, 05:31 AM   #14
cosbySweater
cosbySweater's Avatar
finally a good motor in a volvo here in for the race to beat nathan
1995 Porsche 993
2013 VW Passat TDI
Old 07-22-2012, 05:49 AM   #15
TIPSP
Got Boost?
TIPSP's Avatar
Expected nothing else from you Nathan...
Can't wait to see it
Old 07-22-2012, 09:04 AM   #16
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
dangit, i've got the "front" sump. What are you using for coils, and I need to find one of those power steeringfittings. Did you have to modify the pan?
Old 07-22-2012, 09:12 AM   #17
SeriousSteve
staring at my desk
SeriousSteve's Avatar
This is gonna be good...
2002 Volvo V70 T5 - Daily beater
Now completely RWD-less
SeriousSteve is offline   Reply With Quote
Old 07-22-2012, 01:06 PM   #18
nathaninwa
nathaninwa's Avatar
I had a front sump on the JDM motor I bought, but found one on Ebay, and if you tweek the supra forums there on there for a bit cheaper Im finding. The mid sump fit is pretty close/good. It may take just a bit of shaping on the lower steel pan, but nothing major. Itll be tight against the firewall, but thats to get my shifter in a good location.
Im going to break the motor in on stock cams and stock coils. Ive been reading that that the igntion needs to be upgraded. Ill be using AEM for ecu and Ill get the 1zz coils and trigger directly off the box.
You guys are all talkin that Ill be makin the 800whp range
Old 07-22-2012, 01:24 PM   #19
J_Jones
J_Jones's Avatar
watching
Old 07-22-2012, 02:18 PM   #20
2fast242gt
Do you have a cobalt?
Brian likes this.
almost there
ughhh
there it goes!
Photobucket
this is going to be awsome!
1983 242dl
*6.0 lq4 swaped* Build thread
Old 07-22-2012, 02:23 PM   #21
Roger-Dee
is DeeWorks.ca
Roger-Dee's Avatar
Subscribed, for sure!
So that adapter is already done and bolted up?! Dude, when do you sleep? :P
Nathan I was reading your old thread yesterday and here's something you said in the 2nd page:
I picked the turbo because the boys English Racing made 453whp with one.....I know its small, but a bigger unit will bolt up in its spot.....and I would like to make a progression and not dump myself into a ton of lag.....kind of want to feel this one out. And since I have not screwed it up.....it will sell easily on the dsm boards.
This car is my daily driver that totes my family around too....so going gung hoe will be cool, but being a very quick street car is its first prioity!
And look where you are a bit over 2 years later. So yeah, we really all think you will do a 800whp 942j!
94 944T - 16v turbo - 12,14@122
Lm7 5.3, S475, Ms3Pro, 4l80e - 10,36 @ 134 / 6,70 @ 107
www.deeworks.ca
Need T5 Adapter? T5 Speedometer Plug? Gm Torque Converter Adapter? Freeze plug retainer? HE351 solenoid plug? Pm me!
Roger-Dee is offline   Reply With Quote
Old 07-22-2012, 02:26 PM   #22
nathaninwa
nathaninwa's Avatar
Itll be a few weeks before this really takes off. I have a couple intakes to get completed and some final bits of my old setup to tidy up and get sold.
Old 07-22-2012, 02:29 PM   #23
nathaninwa
nathaninwa's Avatar
Thanks Roger....adapter is just a steel mock up plate. Im finalizing the dxf and send it off to you.
Boost is addivitive, theres ways around lag, and Ill use em when I need to. What I have found with larger turbos, is better mileage on the freeway.
Old 07-22-2012, 09:47 PM   #24
nathaninwa
nathaninwa's Avatar
Spent about 2 hours today and got the motor/tranny combo installed. Engine placement is good, motor mounts look easy enough and the header/stock intake will work out too. Im going to run the stock intake to break the motor in then swap out to a sheetmetal.
Old 07-22-2012, 09:51 PM   #25
#swag
