Old 09-03-2012, 11:24 AM   #1
dobber13
Default Valve Lifter Question
I bought a B21 head that was sitting for a while and a few of the lifters have rust on them. I cleaned them with Eastwood Etch and it removed the rust but 2 of the lifters have a small amount of pitting. Can I reuse them if I clean them up with steel wool and some light grade wet/dry sand paper or do I need to buy new ones.
Charlie 85 244 TI B21FT 265K M46
dobber13 is offline   Reply With Quote
Old 09-03-2012, 12:34 PM   #2
TrickMick
Broad Member
TrickMick's Avatar
*NO* "SANDPAPER" need apply (too often grit remains embedded in metal)...
you're talking about the cam FOLLOWER "BUCKETS" or the shims thereon
mounted??
replace pitted SHIMS....RUN "pitted" "follower buckets" as ling as there NO
"longwise" SCORES that would promote "excessive oil flow" down the follower bores
to the valve spring / guide area which would give you "smoke" when overloaded oil
sits atop flaky valve stem / guide interface....
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity.
TrickMick is offline   Reply With Quote
