Old 01-23-2013, 10:29 PM   #1
Jack
junkman
Jack's Avatar
Default NA cam
What's the best cam for NA 1985 b230? And what models did this cam come on.
I'm sure this has been asked tons of times
Thanks
Jack
Old 01-23-2013, 10:55 PM   #2
For the money that you can readily find in the cali JY's the B cam.
Early NA 240's till 81.
how psi a stock can support?
Old 01-24-2013, 12:35 AM   #3
Jack
junkman
Jack's Avatar
Thanks Ken
How does it affect power/ ecomony/torque
Found my answer
Old 01-24-2013, 07:04 AM   #4
classicswede
Volvo upgrades
The hottest cam is the rare H cam but K's and V's are available over here with little bother.
Old 01-24-2013, 07:31 AM   #5
Wilford Brimley
enjoys the beetus
Wilford Brimley's Avatar
i've got a b for cheap if you are intersted
(Insert Photobucket pic here)
http://forums.turbobricks.com/showthread.php?t=316428 91'744T .57 t3/t4, big ic, greddy type s, 55lb/hr injectors, bosch 044, tloa ecu/ezk, 3"amm, rsi stg 3 cam, ttr cam gear, top mount header, 3" exhaust, kevlar tbelt, e-fan, 22 psi, intrax springs, cherry turbo brace, ipd rear sway, dual front sway bars, bilstein struts, camber mod, accum mod
Old 01-24-2013, 09:48 AM   #6
icebrick
one lesson after another
icebrick's Avatar
Thanks
Jack
I used a K cam for several years (91 B230f) I finally got tired of its' bad manners creeping along in traffic.
I swapped in a B last Summer and like driving the car a whole lot more.
Originally posted by Barefoot
A low-mile Volvo is really only a psychological benefit.
kind of cool, but still grandpas' car
icebrick is offline   Reply With Quote
Old 01-24-2013, 11:24 AM   #7
fivealive
fivealive is offline   Reply With Quote
Old 01-24-2013, 04:40 PM   #8
classicswede
Volvo upgrades
I have to disagree on the H cam.
Spec on my old 240 was B21 on K jetronic, 2.25 inch stainless exhaust system and running on LPG. I droppedin a H cam with the impression I might have to take it out. What a suprise it was very flat for what is supposed to be a hot cam! Tick over was perfect and low speed work was fine even on LPG. LPG does not like a hot cam especially with a close centre line angle. Once you hit about 3000RPM then it did start to take off. Running that cam made me decide that something a fair bit wilder would be a nice upgrade without comprimising the engine ability to labour especialy when towing heavy loads. With a 2.3 engine a lot wilder cam could be used.
The only trouble for some of you guys would be the smog test and swapping cams to pass would be a right pita.
The A cam is very readily available in the UK but it aint any performance cam
Old 01-24-2013, 04:42 PM   #9
Mueller
Mueller's Avatar
Being in CA, don't throw away your old cam in case you have issues with smog with the new cam, you might be fine but better to be safe than sorry.
Old 01-24-2013, 05:46 PM   #10
gashog
gashog's Avatar
I have a B cam in Wifee's '93 245. It was a nice upgrade from the M cam and didn't cost anything.
The old stuff is getting rare so get one while you can.
Edit: B cams were in the old no turbo Kjet cars. 1982 and down. Not sure about 1983. Seems like I had one with EFI but can't remember.
Here comes the BOOST!
gashog is offline   Reply With Quote
Old 01-25-2013, 11:26 AM   #11
D.E
tvåförti
D.E's Avatar
I don't know how available it is there but I really like the A for a daily. Slightly better fuel economy, more mid-range power and it actually revs to around 5000 without sounding completely tortured.
'88 Volvo 245 - B230F, LH2.4, A-cam, 4-2-1 header, de-cat, M47
'83 Volvo 244 - B23A, M46, 48k miles
'64 Ford 17M, '59 Plymouth Custom Suburban, '76 Ford Granada 2.8
D.E is offline   Reply With Quote
Old 01-27-2013, 03:06 AM   #12
cookieboy
cookieboy's Avatar
Wait, isn't the "M" cam the ultra rare high performance "Motorsport" cam ??
1990 244 DL, (Given to stepson 3-2-13)
cookieboy is offline   Reply With Quote
Old 01-30-2013, 04:05 PM   #13
mark244turbo
mark244turbo's Avatar
lol
mark244turbo is offline   Reply With Quote
Old 01-30-2013, 04:08 PM   #14
The Full Banana
not yet good enough
The Full Banana's Avatar
I think you mean the "W" cam.
Project Thread - 1980 242 GT
Old 01-31-2013, 03:56 AM   #15
professor245
professor245's Avatar
OP get a V cam, nice and sophisticated...and revs like crazy...you can get one from me
''I was so ugly the doctor slapped my momma when i was born!
Then he took out his pocket knife and cut off my horns...''
WAYLON
My seller/buyer feedback
professor245 is offline   Reply With Quote
Old 02-02-2013, 07:08 PM   #16
Can play the blues
I run the enem V15 n/a cam in my 93 wagon without any other mods. 4 degrees advanced. It gave a nice performance boost but still has all the good low rpm torque of stock. Makes it a good running wide power band engine. Still has good economy and i've passed emissions without any problems multiple times on a 342k mile engine.
1982 242 turbo. 339k miles. Stuff...old stuff....cool...old...stuff...rust...not...cool...
1993 245 Classic, 413k miles, enem V15. 5spd. IPD bars and chassis braces. New Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
1981 242 turbo. 71k miles. Cool old stuff...
1969 145S more cool old stuff. A barn car.
1967 123GT yet more cool stuff in the barn.
