Old 12-28-2004, 09:41 AM   #1
19Brambling
Default 1991 Volvo 940 Turbo won't start in 18 degree weather
My 1991 Volvo 940 Turbo won't start in 18 degree weather; I have heard there is a Cold Start injector and I would like to inspect it. Unfortunately i cannot find it on ALLDATA or my service CD. Can someone please tell me where to look? Also does anyone have a part number?
Finally is there a test I can do on it to ensure its integrity, such as electrical resistance or vacuum integrity?
Thanks, turns out the only car I could get started the last few days is my OLD mercedes diesel.
19Brambling is offline   Reply With Quote
Old 12-28-2004, 09:46 AM   #2
945TurboTwins
Board Blue Devil
945TurboTwins's Avatar
More info would help us. Does it crank and not turn over? Are you sure the battery is good? That would be my first guess.
The CSI should be on the bottom of the intake manifold, if you have one. My 95 940 doesn't have one.
Chris
'95 945T - 102k miles...11 psi.....ipd Turbo Cam....
945TurboTwins is offline   Reply With Quote
Old 12-28-2004, 11:48 AM   #3
740TurboPerformance
740TurboPerformance's Avatar
Exclamation
If the CS system checks out fine then I would look for any possible vacuum leaks. Check your grounds and clean the batter terminals and connectors. What condition are your plugs, ignition cap and rotor in? I would also look hard at the battery, how many CCA, should be like 700CCA for it to crank up cool when that cold. Also, the motor oil, are you using synthetic? Synthetic really helps with cold climate starts, like 10w30 fully synthetic should do the job, it'l even pour a little thinner and has more fluidability that standard 10w30.
Videos of my 740 @252K:
745T Aftermarket Exhaust
Driving The 745T w/9PSI
Past and Present - 1987 745T - 1987 740T - 1988 745T -
1994 960 - 1994 850T - 1997 S90
855 T5 w/ Carsound/Magnaflow high flow exhaust,
sedan rear sway added, Eagle RSA's.
740TurboPerformance is offline   Reply With Quote
Old 12-28-2004, 12:13 PM   #4
volvo9
volvo9's Avatar
When my plugs where bad my car would not start in the cold weather. When I worked at the dealer lots of 850's came in with cold weather no start problems and performing a tune up wit h cap/rotor/plugs/wires solved the problem.
Your 91 should not have a cold start injector.
volvo9 is offline   Reply With Quote
