Old 06-10-2016, 03:06 AM   #1
Default Analysis of EZK ignition system.
Crank sensor is a Variable Reluctance Sensor and it sends a signal to the EZK ignition computer:
The EZK ignition computer sends a 5v square wave to the ignition power stage to control dwell and timing:
The powerstage grounds the ignition coil. Primary voltage can exceed 400 volts!:
Then after that, Secondary Ignition occurs!!! This is a trace of Secondary Ignition Voltage (Kilovolts) along with Primary Ignition Current (Amps):
Old 06-13-2016, 07:47 PM   #2
corey_mck
Good stuff.
corey_mck is offline   Reply With Quote
Old 06-13-2016, 09:24 PM   #3
sim
Mere Drab Mob
sim's Avatar
What data does it use to calculate the ignition advance?
I have a Volvo with some half-done, homemade crap in it.
http://forums.turbobricks.com/showthread.php?t=244534
sim is offline   Reply With Quote
Old 06-13-2016, 09:51 PM   #4
Karl Buchka
The EZK receives a load signal from the fuel computer. That, along with RPM, coolant temp, and the knock sensor input, is used to control timing.
Old 06-13-2016, 11:26 PM   #5
sim
Mere Drab Mob
sim's Avatar
Ah, the eighties. A separate computer each for spark and fuel.
The weird dual coolant temp sensor is a neat artifact of that
scheme.
The fuel computer gets RPM data from the EZK, correct?
Maybe Zach will have a chance to stick his oscilloscope on the
load signal between the computers. I bet that would be
interesting. I'm going to guess it's a 5v PWM square wave.
Old 06-14-2016, 01:18 AM   #6
Karl Buchka
It's been a few years since I looked at the traces. If I remember correctly, the EZK sends a 50% duty square wave to the fuel computer with the rising edge denoting an ignition event and the fuel computer sends a variable duty, fixed frequency wave back to the EZK to indicate load.
Old 06-14-2016, 11:16 AM   #7
Yes. I think it's just a square wave that increases frequency with RPM. I forget. I have researched it before. Gotta redo my work.
There are THREE wires that connect EZK and LH box.
1: RPM signal FROM EZK box to LH box. The crank sensor signal goes direct to EZK box. It converts it likely to a square wave that gets sent over to LH box.
2. KNOCK signal FROM EZK box to LH box. This one I think is just an increasing voltage. Again, I lost my data. Please help me out.
3. Third wire. LOAD signal from LH box to EZK box.
SEEEE!?: Pins 17, 8, and 4 on the EZK go to 1, 25, and 28 on the LH box. Help me remember what they are and do. I gotta hit IPDdowns? website again. He broke it down, but it was kinda hard to understand and needed more info.
Here it is:
http://ipdown.net/wiki/index.php/EZK#Knock_control
I guess I could slap the old high end scopometer to each of these three wires on my time off and see what they look like with a modern scope. The publications are decades old and assume a tech has just a crappy multimeter. Technology is better now and so I go by waveform analysis instead of some obscure voltage reading on a 30 year old chart!
