Old 01-02-2021, 09:25 PM   #476
DET17
Reformed SAABaholic
I just thought of something you might not be aware of. The offset spherical mounts you are using have a modular spacer installed on them on the bottom, its only needed when using the stock spring perch, when you move to a coilover spring you can remove it. That will move the spring up by ~5mm or so which will give you some more clearance to your springs / tires.
That would have been excellent information to have known, prior to assembly & installation. Have you considered providing exploded views of your systems, and indicating such options for the end user?
Technically the spring assembly is not metal to metal as you are using the luxe bearings and there are plastic layers of isolation between the metal connections but it does have ALOT less separation than the factory Lazy Boi spring seat.
Indeed. I'm not familiar with your Luxe Steer system.... the bearings I'm using are OEM, INA part # F-230378. Bought them years ago from IPD I believe. So everyone knows what we're talking about, a few pics attached showing the female receiving plate which this bearing seats perfectly on. Had I know that your modular spacer was superfluous for my application, I would have removed it........
Old 01-04-2021, 03:16 PM   #477
Same thing.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 01-10-2021, 08:02 PM   #478
DET17
Reformed SAABaholic
So as Ben informed, there is indeed a spacer installed into the SELECT top mount assembly. It appeared to be a light press fit, so I set out to remove it. A small "pecking hammer" as Dad used to call them, and a sharp chisel is what was needed:
Making a light chisel "wedge drive" between the top plate and the spacer, 3 points 90* apart, and sure enough the spacer walked out. Just as Ben said, the INA bearing drops right into the same female bore in the top mount plate:
My non-NIST traceable scale says these spacers are 8mm thick, so the front of the sedan will drop by that amount.
After comparing notes with Redblockpowered, it seems my sedan will only be about 3/4 ~ 1 inch lower than stock ride height. From memory, Ben says his QSRC's are necessary when your 7/9 is lowered more than 1.5 inches / 45mm or thereabouts. With the sedan back up near stock height, I will remove the roll correctors and restore the stock setup. No more middle hole "quick steering", but the OE setup will be AOK for daily driving duty. Since the QSRCs are on their way out, my shortened/chopped brake dust shields are no longer necessary. With all the new goodies going into the front suspenders, I couldn't resist putting brand new OEM dust shields back in service:
Coming in the mail are NOS control stay "radius rods" with the 396mm length (used in the 94 and 95 models only). My 92 sedan has the 385mm length, so these long rods will increase the caster and give all around improvement to front end steering functions. More to come.... if parts arrive this coming Saturday, she'll begin going back together up front next weekend.
Old 01-12-2021, 02:45 PM   #479
I am assuming you will raise the spring perches by the 8mm to keep the same ride height and gain wheel / spring perch clearance?
Old 01-13-2021, 09:38 PM   #480
GSWAGON
my other ride is a exmark
Where did you order these from, part number? I never knew the later model ones were longer. Direct bolt in I assume, just changes the angle?
87 765 GS Wagon LT4/T56 13.1@111
90 740 Turbo M46
90 780 Bertone Turbo
99 SL500 AMG Sport
08 Corvette JSB LS3 6 speed
08 Escalade AWD- wifes daily
15 Ram CCSB Hemi 4wd
Life is short, so live it! You are only old when your dreams are replaced by regrets.
GSWAGON is offline   Reply With Quote
Old 01-14-2021, 08:31 AM   #481
DET17
Reformed SAABaholic
Yes, that will be step 1; Install the 32mm Gil Racing adapters if needed.
Old 01-14-2021, 08:33 AM   #482
DET17
Reformed SAABaholic
I will add that detail here soon.
Old 01-14-2021, 09:39 AM   #483
Based on what you previously had and the fact that you can now increase clearance. There's no reason you would need a 32mm in the front... unless you just want to, then by all means....
Old 01-19-2021, 07:16 AM   #484
DET17
Reformed SAABaholic
As the parts trickle in, the work continues. The lower control arm "stay (radius) rods" in the 396mm length:
PN should be visible in this last pic. Thanks to BLACKVLV, eBay seller for providing these.
Next, I found out that Roy had these 30K mile later style aluminum LCA's in his thinning hoard. Rather than fight my old cast steel versions (with bushing replacements), I bought these to add to the improvements. NOTE - this type uses a different sway end link than my old 92 version:
All I lack is the JEGS shipment with Eibach 2.5 inch ID spring isolators..... and the struts will go back in for the final time.
Old 01-19-2021, 12:06 PM   #485
What do you think the Eibach isolaters will do for you?
Old 01-19-2021, 12:40 PM   #486
DET17
Reformed SAABaholic
Isolate some NVH from the chassis, cabin. At $10 a piece, it cannot hurt. I understand that plastic can't isolate like rubber spring seats.
Old 01-19-2021, 02:10 PM   #487
Those wont help with that at all.
They are intended more to be a cheap version of the luxe steer which lets the spring slip but you don't need it since you have a roller bearing.
Old 01-20-2021, 07:34 AM   #488
DET17
Reformed SAABaholic
My test drive of the front suspension revealed a lot of "metallic noise" transmitting into the cabin. What may well have been the culprit, was I tightened the KONI top nut only holding back by the 11mm hex which is at the top of the strut (centered within it, the damping adjustment tab). You can't get a lot of counter-torque with such a small resistance, so I think the strut shaft might have been turning inside the spherical top mount bearing. I think the KONI Sport manual calls for a torque of around 55 lb.ft. on the main nut, and I'm sure I wasn't at that. This time around, I'll use my impact on the top nut (24mm? from memory) and confirm torque achieved with my torque wrench. I'm installing the Eibach isolators regardless.... as I said, it cannot hurt NVH, and it is better than metal to metal.
Onward.
Old 01-20-2021, 02:47 PM   #489
Onward.
That could have been the pillow ball moving in the strout mount housing on warm days. I found the pocket in mine was ~0.025" too deep. Loctite bearing retaining compound shut it up.
So if this metallic noise includes popping and groaning, this may be it.
Old 01-20-2021, 02:49 PM   #490
This could very well be true.
loctite 680 and flipping the tapered snap ring can help a lot if this is the situation.
Easy to do when its still apart as well.
Old 01-20-2021, 03:17 PM   #491
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
What's the weight savings with the aluminum control arms? I've thought about getting a set.
I sell chips for LH 2.4!
Old 01-21-2021, 07:11 AM   #492
DET17
Reformed SAABaholic
I'll weigh one of the cast steel units and share it..... before the fetch me $0.05 per lb.
Old 01-21-2021, 07:13 AM   #493
DET17
Reformed SAABaholic
I ran these same top mounts for several years prior to the coilover conversion.... and they were completely silent. What changed, is the cause of the metallic sounds. We will see how vocal it is after the top nut reaches the KONI spec torque.
For sure ,the Loctite GREEN retention compound works.... I've used it for decades at work.
Old 01-21-2021, 11:05 AM   #494
If they have been quite then it sounds like the bearing assembly is fine....
If that top nut is under torqued, it can cause a real racket.
Old 01-27-2021, 06:54 AM   #495
Swedbrick
Swedbrick's Avatar
What is the pn of those aluminium LCA's I have never encountered them in europe
Old 01-27-2021, 04:06 PM   #496
Chilm
Double Dutch
Chilm's Avatar
This... very curious
Flying Dutchman - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 01-27-2021, 05:08 PM   #497
Swedbrick
Swedbrick's Avatar
Are they more common on later 940's? I've mostly worked on pre-facelift 740's
Old 01-27-2021, 05:15 PM   #498
Chilm
Double Dutch
Chilm's Avatar
I personally have not seen them ever on any 940, so I'm very curious too about where they come from.
Old 01-27-2021, 05:38 PM   #499
Early 960s had them. I dont think the 940s got them.
Aluminum hood cars usually had aluminum control arms too.
Old 01-27-2021, 05:49 PM   #500
Chilm
Double Dutch
Chilm's Avatar
Thanks Ben, I've really never seen them come by. Weight wise these alu rods are preferable I think. The weight of the iron ones is huge, I'm only curious for the detoriation of the surface where the "mushroom" rubber rests cuz Aluminium is a lot softer.
