Old 06-06-2016, 11:01 PM   #1
dkrause
Default B230 Intermediate Shaft Bearings
I am having difficulties finding a set of intermediate shaft bearings, anyone know where I can get a set?
dkrause is offline   Reply With Quote
Old 06-06-2016, 11:28 PM   #2
planetman
planetman's Avatar
I've got a set in stock.
Eric
Torrance, CA 90502
Old 06-06-2016, 11:30 PM   #3
PhoeniXXX
I've seen that IPD carries bearings, check the sizes they may have it. Worse comes to worse I'm sure Volvo will have them
PhoeniXXX is offline   Reply With Quote
Old 06-06-2016, 11:33 PM   #4
planetman
planetman's Avatar
Volvo intermediate shaft bearings have to be align bored, while I sell pre-fit bearings.
Old 06-06-2016, 11:41 PM   #5
The Librarian
Only the front bearing is available from Volvo.
http://www.tascaparts.com/oe-volvo/463360
http://www.tascaparts.com/oe-volvo/463361
Old 06-07-2016, 09:35 AM   #6
Beep beep zip tang
Try Napa
NAPA "Altrom" product line -
part number: ATM 3C7937000 (set of THREE pieces)
Old 06-07-2016, 09:38 AM   #7
JohnMc
JohnMc's Avatar
Originally Posted by VB242 View Post
Try Napa
That's where I finally found a set last time, but:
http://www.napaonline.com/napa/en/p/ATM3C7937000/
$42.49 /Each
Out of Stock
Call Store for Availability.
(804) 747-1873
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 06-07-2016, 12:34 PM   #8
coalminer
This guy has the bearings in stock.....pre-finished....ready to install and run.
Buy them from him.....end of story.
coalminer is offline   Reply With Quote
Old 06-07-2016, 12:40 PM   #9
The Librarian
NAPA hasn't had them for over a year. They said they have no plans on re-ordering them.
All of these places claim to have them.
http://www.acm-ab.se/mellanaxellager/2484-0
https://shop.klracing.se/sv/artiklar...-b23-b230.html
http://www.rendcarparts.com/volvo/pa...463361/53.4015
http://www.vp-autoparts.com/main.asp...e&artno=463360
http://www.skandix.de/en/spare-parts...shaft/1000410/
There are some places that say they can get the IS bearings, but because of a catalog error, you end up with B18/B20 cam bearings instead.
I have both in stock, so I know the difference.
Old 06-07-2016, 12:45 PM   #10
coalminer
I thought I was responding to you when I posted. I know that I've talked to you before about a set of these bearings. I'm still not well enough to rebuild that B21F, but I keep hoping.
Old 06-07-2016, 01:01 PM   #11
The Librarian
No worries, planetman is my brother. You can contact either one of us.
Old 06-07-2016, 09:20 PM   #12
dkrause
Default Thanks problems solved
purchased parts from hiperfauto. Thanks
