Old 12-19-2020, 04:48 PM   #1
shoestring
shoestring's Avatar
Default Sealed U joint part numbers
OK, so I put a pair of GKN U110 u joints in my 240 because I had to. The ones in there were a little loose. Problem for me is, they're the greasable style, and I hate that. I've always been a dealership parts consultant, and no manufacturer I've ever worked for uses a greasable joint. It looks like the factory 3520997 joint is the sealed design, but they're a little dear, and if I can get the same joint or equivalent for less, I'd rather do that. Yes, I would take out these joints that I just put in. I know it seems daft but greasing u joints isn't something I want to do. Also, they're not as good. My question is if any of you guys have replaced the joints in your prop shafts with a sealed type joint that wasn't from Volvo and if you would share the part number with me.
Thanks in advance. Not to be curt, but I'm not interested in trying to be convinced that a greasable joint is superior. If they were, manufacturers would use them, because they cut costs wherever they can.
Old 12-19-2020, 04:57 PM   #2
JW240
All idiot, no savant
https://www.landroverexpedition.com/...t-differences/
I got the cheap GKN ones you have too, with grease nipple. Agreed that that is a poor solution. Cannot comment on their quality since I have not run them yet.
The link shows the HD version too. Could not find them at the time so went with the cheaper ones.
Maybe this helps with sourcing the better ones! I forgot the exact dimensions but I remember the LR U-joints have the same dimensions.
Old 12-19-2020, 11:16 PM   #3
283SD
Of the 3 U joints on my V8 Wagon, One was replaced @ 250K miles,the other 2 are still fine,@325K [32 years later] miles now. P.S. they all have grease fittings that I check and grease at least once a year.
Old 12-20-2020, 01:09 AM   #4
culberro
culberro's Avatar
Neapco solid are the only ones I use in the race cars now. Much better longevity than Spicer joints.
I believe the earlier 240s were just 1310 u-joints.
Old 12-20-2020, 08:54 AM   #5
Beep beep zip tang
They are 1300 I believe, also used on some Jags. Nobody makes conversion joints in 1300 either.
Here's RockAuto link
https://www.rockauto.com/en/catalog/...sal+joint,2392
Old 12-20-2020, 08:22 PM   #6
shoestring
shoestring's Avatar
Yeah, they are a 1300 series joint. I may have to buck up and buy a Volvo joint and see if the GKN number reveals itself.
Old 12-21-2020, 01:41 PM   #7
culberro
culberro's Avatar
Have you tried contacting a driveshaft shop, and seeing what they can get?
Old 12-23-2020, 05:48 AM   #8
carver
Involvoed
carver's Avatar
I just had a two piece from a '90 240 cut down and refurbed and they said there were no non-greasable u-joints available. Pretty sure you're right about the early ones having 1310's but I'm not sure on the years offered. Anyone?
carver is offline   Reply With Quote
Old 12-23-2020, 08:51 AM   #9
shoestring
shoestring's Avatar
I haven't as yet. I'm normally hesitant to take up people's professional time gathering information unless I'm ready to pull the trigger immediately. Probably stems from the fact that I'm a commissioned employee. That, and in the Age of Information, I should be able to find this stuff out relatively simply.
Thanks for the push. I'll let you know what I find.
Old 12-23-2020, 02:13 PM   #10
The pictures of the u joint on the VP autoparts web site shows some ujoints without lubricator. Depends what size you want.
Edit:The part number of the rear ujoint on my 93 wagon with M47 is 1209814. Mostly I see the Meyle one for sale which is a grease able ujoint.
Edit2:OK that number is super seded by 383472. I found a non grease able one on this web page. https://www.volvo340onderdelen.nl/en...ive-shaft.html
Old 12-23-2020, 03:43 PM   #11
Beep beep zip tang
They are 1300, the link I provided to Rock auto above has a non greaseable joint listed under economy even though the pic shows a grease fitting.
Old 12-30-2020, 08:27 PM   #12
shoestring
shoestring's Avatar
Little update here, I got 2 joints from my local Volvo store PN 3520997, and they are a proper sealed unit. They are also still GKNs, which makes me wonder why I can't find them in the aftermarket. Perhaps there's a proprietary contract with the OEs? I know Land Rover uses them also...
Also, I've not heard back from any prop shaft shops, but since it's the week between two major holidays I'm not too surprised.
