Old 01-14-2021, 09:31 PM   #1
2 old for this
Default 240 plus t air filter
What is everybody using for a air filter? The other car I did was cut a hole in the inner fender, putting the cone styler filter in the wheel well. It’s a pain to service it
Old 01-14-2021, 09:42 PM   #2
spock345
spock345's Avatar
When my 240 had the +T installed I just used a generic cone filter where the turbo airbox would go.
1967 122s, B20F, M40
Old 01-14-2021, 10:10 PM   #3
culberro
culberro's Avatar
^This.
Autozone special bouncing around the inner fender
Old 01-14-2021, 11:26 PM   #4
James M
Bored member
James M's Avatar
Ebay is cheaper
Why are you servicing and air filter? Install and forget forever
Old 01-14-2021, 11:28 PM   #5
JohnMc
JohnMc's Avatar
Mine originally looked factory, someone spent some time carefully melting and reshaping parts of the bottom of a 940 Turbo airbox, until it fit into the corner of the 240 engine bay like it belonged there. Then a small hole through the inner fender for the air box inlet. Super clean install, before I got my grubby mitts on it.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 01-14-2021, 11:35 PM   #6
James M
Bored member
James M's Avatar
I tried that
But with a sawzall
Then gave up about 4 ****ed up cuts later
Old 01-15-2021, 12:19 AM   #7
2turbotoys
Salaminizer
2turbotoys's Avatar
Get an S&B filter, they make any size you want and are way better than the parts store stuff. Interior velocity stack instead of a shelf. And $35 to $45. If you want a garbage parts store one I will send one to ya for shipping cost, just found one in the hoard.
I wouldn't put it in the fender well, just on the outskirts of the engine bay. Enginemasters did a lot of dyno testing on this and intake air temp does not matter nearly as much as fuel temp. Plus I assume an intercooler is part of the plan, so no worries.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 01-15-2021, 09:41 PM   #8
2 old for this
Any chance you still have that assembly?
Old 01-15-2021, 11:58 PM   #9
Jussi Alanko
Does anybody have to route actual cold air at front spoiler to turbo air filter, i'm talking about 244 model?
Jussi Alanko is offline   Reply With Quote
Old 01-16-2021, 12:55 AM   #10
white855T
You could do something like this with a turbo kjet airbox.
Old 01-16-2021, 01:23 AM   #11
James M
Bored member
James M's Avatar
That's not 14.99 tho
Old 01-16-2021, 08:39 AM   #12
DET17
Reformed SAABaholic
There is also the 240 Diesel air box option..... not $15, but factory parts.
Some have poo hoo'd the size of the filter.... but better than listening to the cone filters "wheezing" IMO. If running without an AMM for your engine management, I believe it would be fine for reasonable power levels. Best of all, it fits the 2 series sheet metal.
Old 01-17-2021, 08:27 AM   #13
JW240
All idiot, no savant
Diesel air box does not play nice with stock 240T intercooler, outlet of the filter is perpendicular to the IC pipe and at the same height.
With a different intercooler its a pretty neat oem looking setup though space is limited.
Old 01-17-2021, 01:42 PM   #14
OttoB
This is the one I will accept. AMM needs straight tube before air inlet.
Old 01-17-2021, 10:30 PM   #15
2 old for this
I sliced up a 740 air box. The flange is all that is left from the bottom. Top still locks down holding the filter. Hose from 240 intake hooks it to the amm.
Old 02-07-2021, 05:25 PM   #16
245Pim
245Pim's Avatar
I'm planning on a +t soon and i have a airbox from a diesel 240. It fits where the coolant and washer tanks are located. So I got to move those. Also make the tubing fit to the turbo. I can make a pic of it if you want.
245Pim is offline   Reply With Quote
Old 02-08-2021, 12:37 PM   #17
dbarton
Dejected by Volvo
dbarton's Avatar
I did this exactly back in 2001 when I installed the stroker B26FT, but my reason was to keep Calif smog techs from noticing I no longer had K-Jet.
Currently I use the simple cone filter in my 242, but I keep thinking someday I'd like to make something that can wall off the engine heat without looking too out of place.
Dave
'84 242ti, fourth owner, mine since 2003. Always garaged since brand new. Old-school rounds because I like. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with modded 0.73 OD, 3.91 diff, unmodified G80.
Old 02-17-2021, 03:44 PM   #18
nolift911
Doing the same on my +T - although I read if pulling higher than OEM boost you need the internal cage support for the bellow as it will suck down and restrict - could be urban legend but its an OEM part, still available and cheap so...
nolift911 is offline   Reply With Quote
