Old 03-15-2021, 07:57 AM   #1
84B23F
84B23F's Avatar
Default Outer Rotor Diameter
I noticed two different sized rotors being listed for 93-940...the designs are different, but will they interchange?
Outer (IN) 11.295
Outer (in) 11
Old 03-15-2021, 11:23 AM   #2
daniels740
No, measure the rotors you have on now, and order the same size if you're keeping everything else stock.
daniels740 is offline   Reply With Quote
Old 03-18-2021, 02:51 PM   #3
lummert
lummert's Avatar
93 940 should be 280mm (11 in.). 287mm (11.3 in) was last used on 1991 740 w/o ABS. The 2 rotors are not the same thickness.
Old 03-19-2021, 07:27 AM   #4
84B23F
84B23F's Avatar
93 940 should be....
In those years, on 740s/940s, Volvo used rotors with
Outboard Vented Vents On Wheel Side Of Rotor
and rotors with
Inboard Vented Vents On Axle Side Of Rotor
For the 1993-940 I own, it takes the smaller diameter rotor (11") with inboard venting on axle side. The outboard vented rotor is about 11.3" in diameter.
0.3" would give a pinch more braking, but I know nothing about why Volvo flipped around.
Old 03-21-2021, 01:19 AM   #5
dkrause
The "smaller" 11" rotor with inside air intake is also thicker and considered the HD version.
dkrause is offline   Reply With Quote
