Old 03-24-2019, 09:15 AM   #476
slow240
Home Schooled
slow240's Avatar
None of the new pictures are loading for me!?!?!
Now I'm standing here with my pants around my ankles and a greasy shop rag in my hand lookin silly...
Edit: They loaded.....hnnggggf
That backseat is totally worth the effort. It gives it that finished street rod look that is incredibly hard to pull off on a Volvo. Bravo
I'll polish your face
'89 780. Fine Corinthian leather.
Old 03-24-2019, 03:32 PM   #477
Sander
Good news everyone!
Sander's Avatar
It looks gorgeous, well done
Old 03-25-2019, 05:59 PM   #478
towerymt
the real Towery
towerymt's Avatar
Originally Posted by hackster View Post
Front tires look very close...how's the clearance up there? I thought you might have gotten the 285/30 (couldn't read the size) but saw you mentioned elsewhere 275/35. The height difference is significant, but the taller tire is probably the way to go with all those torks. Those are about the same size as the 275/45/16 Hoosiers I used. With negative offset on the front, I definitely had to flatten the pinch weld at the rear of the inner wheel well (saw you discovered that already).
The perspective from the wide angle makes the rear look high but it doesn't seem that way in other photos. What's the front & rear ride height measured to the rocker (either to the bottom of the pinch weld, or to the rocker itself)?
Does anyone make a 5pt harness in chocolate-brown?
Old 03-26-2019, 10:45 AM   #479
hackster
Originally Posted by MadDog_945 View Post
oh my god this car is pure sex!
Haha....Thanks
Originally Posted by RustoGusto View Post
Unf%^&ing believable as always!
Much appreciated.
Originally Posted by JW240 View Post
++++1
Great, really.
Thanks man
Originally Posted by Mick13 View Post
Superb car, work and details !
Originally Posted by Jerd View Post
Didn't expect anything less from you. Every build looks better than the last. Amazing work man. Looking forward to hearing your feedback on the suspension.
Thanks man, that is why I keep doing them, I feel like I can do better on the next one from things I learned on the last one. Suspension feels good on initial driving but its really, really stiff. I am thinking softer springs are going to be a must.
Originally Posted by mblue240 View Post
When are you going to C&C next> I want to be sure to come see the car in person.
If I don't head to Pleasonton this weekend for good guys and the weather is nice, I should be there Saturday.
The back seat although a lot of people questioned why, I think the finished results are well worth it. Thanks for the props.
Much appreciated.
Front is very close, everywhere but with about 100 miles on the car the fronts dont seem to rub the rears on the other hand, well they do. Rear fenders are going to need some more work. I should have pulled another 5mm from the offset in the rears but it is what it is now.
Yep, didnt see that pinch weld till I had the fenders off, would need to happen eventually cause this car will see 315's on it someday.
Ill take a measurement, its is a little higher in the rear, but I also think partly because there is no diffuser on the rear of the car. Going to wait until I get the exhaust redone and then I can work on something to smooth out the rear of the car.
Tinkered with the car this weekend a fair bit, did a lot of little **** that nobody cares about. Got the wiring redone for the VSS directly into the Racepak as well as pulled the wiring from the dash for the oil pressure sender. Apparently you cannot get oil pressure through can bus on this particular racepak dash.......even though everything I read says you can. I also can get oil pressure on HP Tuners so I know its available on the can network. Frustrated with that.
I went to the junk yard and had a great day there. Found a bunch of stuff I needed. But Cheek cover for passenger trunk, a bunch of bolts to get plated for the front fenders and apron so they all match, a great looking antenna and 2 rear decks in amazing uncut condition all for $15.03
Got the antenna cleaned, painted and installed. Built a matching panel for the trunk to cover the drivers side hole and got the rear trunk carpet all installed, turned out good, but forgot to take pics.
Fought getting the IPD aluminum skid plate installed as it will not clear the drop bar, messed with that for a few hours. I have some ****ty spacers in there but it needs something more better, will work on that this week.
Pulled the pinstipe off the rest of the car to clean it up and have it match the fenders, buffed as much of the remnants off of it.
Messing with stupid VSS......still no luck.
Took the car for a spin, got fuel.....have a stinky fuel system I gotta fix, pretty sure I need to figure out a proper vent as my system doesnt really work how I thought it should.
Took it to Red Door Meet on sunday for a few hours. Car starts lots of conversations, its pretty fun. Got on it for the 1-2 shift for the first time, its got great power and the torque is incredible, as soon as you get into 2nd it just pulls.
The howl and rearend noise got worse and worse, weather is garbage up here and the gear guy is wonderful at gears but gravel road, rain so it would be a huge mess so here we go...
5:00 last night when I got home from work.
6 pm last night, loaded up and ready to drop off.
He took one spin of the pinion and was like what the hell? So its getting all new bearings, seals, solid pinion spacer if he has the right one and an Eaton True Track.
As long as it doesnt need gears it will be back in the car tomorrow night, we got **** to get to now.
Sean
Old 03-26-2019, 11:07 AM   #480
M.H. Yount
M.H. Yount's Avatar
I ran the fuel tank vent from tank to canister like stock, then canister to barbed fitting in the air intake tube upstream of the maf sensor. Never smell any fuel. ‘Course, fuel line choice has to be impermeable too...I made that mistake once.
Old 03-26-2019, 11:10 AM   #481
I'd get a charcoal canister and rollover valve setup from a later car. I think 80-81 just use a single vent from a check valve at the filler neck to the intake. Those kinda suck.
Old 03-26-2019, 07:51 PM   #482
cosbySweater
cosbySweater's Avatar
I have a horribly stinky fuel system as well. It sucks. Solid pinion shim is a must in these. Mine has been smashed for a long time and it's annoying but I have been lazy. Swapping from 3.73s to 3.27s so it will get addressed then. You driving it to Davis?
1995 Porsche 993
2013 VW Passat TDI
Old 03-27-2019, 02:23 PM   #483
hackster
Good feedback. No not driving it to Davis, I am continuing onto Vegas for LS Fest West after Davis and a 3,000 mile trip in this doesnt sound like fun at all. We did the solid pinion spacer, new bearings throughout as well. Dan also shimmed the axles so there is zero axle play in out with the c clip so hopefully pad knockback is a non issue. He is the best gear guy I have ever run across and totally reasonable.
Axle is back home and hung under the car. Not bad for 24 hours. Had a ****ty day yesterday and ****ed up a brake line fitting so going to try and round that up this afternoon if possible.
All in all glad I pulled the axle, I found a brake line had gotten crushed between the exhaust and the axle so that got redone and some of my hardware was too short not engaging in the lock nut. I got some longer hardware and reassembled everything with a few drops of lock tight.
Should be able to get the **** box back on the road tonight barring I can get gear oil in it and bleed the brakes.
Good fun!!!
Old 03-28-2019, 11:47 AM   #484
hackster
Very little motivation to work on this thing last night after work knowing I had to get up and hit the road this morning for 2 days of travel across the state for work.
Managed to get a local portland shop to make me a new brake line (rediculously expensive compared to Eugene price) but its done.
As you can see the only difference is the color of the hose, probably only something I will ever see so it is what it is.
Eaton recommends just regular old GL5 non synthetic gear oil for these Trutrac's so 3 quarts of GL5 went in before I raised it up in place and hooked up the shocks and track bar.
All back together. Only thing left to do is to bleed the brakes and get it on the ground again.
All in all I am glad I did it. I replaced some hardware that was just a tad bit too short, I went through and properly torqued everything this go around and added locktite to fasteners that needed it.
I want to get the exhaust done. I ordered a Borla Xr-1 muffler for the back of the car but am concerned that its not going to be large enough to do anything. I kind of want like a huge truck muffler back there to make it really quiet but cannot find anything that would be right.
Sean
Old 03-28-2019, 01:44 PM   #485
Vol242vo
Keep it clean...
Vol242vo's Avatar
Car is amazing as always. What rechargeable work light is that? CAT? I need one!
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Vol242vo is online now   Reply With Quote
Old 03-28-2019, 02:00 PM   #486
Hathos+
PooPoo Pee Pee
Hathos+'s Avatar
Let me know if you want those rear-quarter windows with the chrome trim on the bottom.
They've been sitting in my garage, so I can check their condition later today if you'd like.
I learned everything I needed to know about revalving shocks in this one little-known phone call..
Hathos+ is offline   Reply With Quote
Old 03-28-2019, 05:32 PM   #487
Texas240
Prius Owner
Texas240's Avatar
I did a nice big magnaflow muffler in back and nothing else. It had a bit of drone but isnt loud unless you step on it. Im quite happy with it and sounds bonkers when you free rev it.
93 245 LS Engine Swap Project
Old 03-28-2019, 08:52 PM   #488
M.H. Yount
M.H. Yount's Avatar
Wonder if an OEM-style F-body muffler (single 3" in, duals out) would work for you? Mine had Flowmaster's version of that on it at one time. Fit just fine transversely in the back. I'm running big OEM mufflers on mine in the back, but I'm duals all the way back, so that won't work with what you have now.
Old 03-28-2019, 09:29 PM   #489
Texas240
Prius Owner
Texas240's Avatar
When the corvette rear end goes in i'll be going to dual 2.5" with some cats. Im getting tired of the smell. Hoping to quiet the thing down a little than now.
Old 03-28-2019, 10:18 PM   #490
M.H. Yount
M.H. Yount's Avatar
I’ve got oem 5.0L Coyote mufflers on mine...some fab required but easy for you. Quiet, no drone. They manage 420-440 HP with little loss.
Old 03-28-2019, 10:55 PM   #491
cosbySweater
i have a single big magnaflow, i do have a turbo but when i was on the stock cam it sounded like a stock 240. lol
Old 04-01-2019, 11:48 AM   #492
hackster
Luckily my parts all showed up last week so I was able to get home after traveling last week and get to it Friday night!!!
Chopped off the tailpipe next to the fuel tank and got to installing some more Vibrant U bends, V bands and the Borla Muffler.
It made a world of difference in volume and tone, there is no more drone and the car is plenty quiet. Sounds good at idle, quiet on the freeway.
I am just learning to TIG and dont have a purge setup yet. Will in the next week though.
Got the brakes bled and rolled the rear fenders a little more for some reason the rear axle creeped forward a little bit so I extended the lower control arms to push it back by .125".
Then I drove it, I put fuel in it and drove it. I drove it to Wilsonville for Cars and Coffee and back home, tweaked the rear a bit, checked the fluids, retorqued the wheels and checked things, ran some errands in it, drove out by the air port for a car meet with the stance kids to check things out. Went over it again to check for things to be tight and normal. I adjusted the shifter to better fit seating position and its dialed now.
Then I took it out and actually "drove the car" its good, torque is really good, pulls to limiter. I have a little bit of a soft pedal, think I am going to go through and rebleed the entire system this week and make sure I dont have any remaining air in there. The brakes work great, but pedal has a little more travel than it had before pulling and swapping the rearend.
This is up near Skyline and Germantown, there are some amazing country roads up there and the car was a blast. Letting it cool down a bit and checking the brakes.
Ran through an entire tank of fuel this weekend, probably have a few hundred miles on it and its getting better the more it gets driven and I get the little bugs worked out. I dig all the small details and getting it dialed in just right.
3 weeks till I leave for Davis and LS Fest weather is turning to crap here so probably not much more testing till then.
Managed to get lots of honey do's done this weekend, cars all cleaned and detailed, changed the oil on the JK, replaced some lights around the house and did some much needed furnace maintenance.
This is how sick of a person I am. This was for Cleaning and then swapped some wheels and tires around. I love clean.....clean, clean, clean.
Old 04-01-2019, 06:45 PM   #493
Texas240
Prius Owner
Texas240's Avatar
what borla muffler is that?
Old 04-01-2019, 07:53 PM   #494
M.H. Yount
M.H. Yount's Avatar
Clean only works.....every time.
Old 04-02-2019, 12:44 PM   #495
hackster
Borla XR-1
Oh man you and I have a lot in common =)
Well, some tinkering last night found my first major snafu in my build so far.
In messing with my brake bias and trying to figure out why the car felt like it was must missing a few calipers I adjusted the proportioning valve and the stopping got worse and I got a pull to the passenger side, like rip the wheel out of your hands pull.
So chatting with volvo buddy Asher he pointed out that I have it all wrong. So some testing of his theory by adjusting the proportioning valve out to add in "rear" brakes gained back all of the stopping power and pedal feel and took the pull away from the passenger side and gave me a little pull to the drivers side.
When I built the plumbing for the brakes I did everything as others have, with the exception of the proportioning valve, but in my head it worked.......Obviously I didnt think too deep on this.
Volvo has a cross plumbed braking system in an effort to be the safest car on the road, they have a network of plumbing that essentially has 4 front brake lines and individual rear brake lines right and left. The master cylinder has 2 lines, but really not a front and rear, its really a dual bowl system. the idea is that if one of the systems were to completley fail you would only lose one of the rear wheels braking 100%.
So in effect my plumbing and proportioning valve is modulating one front and one rear caliper
So I either ditch the prop valve and put a straight piece of pipe in there or I re plumb the entire brake system and start over.
I will say that with the prop valve fully open the car has amazing brakes!!! Cannot wait to get some real pads in there.
But here is my derp moment....always learning something new right?
Sean
Old 04-03-2019, 12:00 AM   #496
Texas240
Prius Owner
Texas240's Avatar
waiting for "my brakes squeal like a mother" comment
Old 04-03-2019, 07:21 AM   #497
M.H. Yount
M.H. Yount's Avatar
Seems like you could leave the existing prop valve wide open (or eliminate it - reuse at the rear); and then merge the two rear lines into one - into a prop valve at the back - then split the output of this new rear prop valve to the two rear calipers. That should allow you to reduce pressure to just the rear brakes. Maybe that's what you meant by "replumb"....
Old 04-08-2019, 02:21 PM   #498
hackster
Zero squeal so far and I have not been gentle on the brakes. My old R Brakes did though.
I wanted a clean start and easily adjusted rear bias.
So I picked up some t's and plugs with the original intention was the Barton idea of using the factory block slider for the rears.
I eliminated the factory front slider and installed 2 10mm T's in their location, a little bending of the lines netted me an ok installation. I fabricated a small bracket to hold it all nicely together and keep the lines from rubbing on anything. All in all happy, you really cannot see anything from above. and its somewhat clean from below.
I eliminated the cross piping volvo B.S. The front output from the master controls the front 2 calipers, the rear output from the master controls the 2 rear calipers.
In effect this is now a normal brake system.
I then removed the factory proportioning valves and where I was going to put a bunch of plugs in the old block and install it, it just seemed way cleaner to install 2 10mmx1.0 unions. Amazingly I had 2 in my parts bin and tossed them in.
Backed out the rear prop valve and bled the brakes. They bled fast this time around and pedal feel was better than before and stiff.
It was still Dry before the monsoon came in so I gave it a quick spin around the neighborhood......WE HAVE BRAKES!!!! Like real brakes. Car stops hard and fast and now stops dead straight unlike before. I now have the ability to modulate just the rear brakes.
So moving on. I got the Racepak VNet oil pressure sender installed last week and was waiting on the new cable. It showed up Friday so I got that installed and chatted with them on the phone to get it working. A little programming and its good to go. I will say their tech support is far less than stellar. It was my 3rd call in to them and the first time we have resolved an issue. I still have no working VSS and speedo.
One of the other issues I stumbled onto was I omitted a vent from the fuel system when I hooked everything up and the car and trunk stunk like fuel.
I did a little digging around on the old interweb and found some useful info on the factory five forum. Guys were able to easily build a charcoal canister on their vent line and eliminate any smells.
Off to the pet store and home depot and we had this tidy little setup.
This is all hooked into an anti rollover valve installed inside the factory fuel filler door. I was trying to get it higher than the filer neck and this was the only location I could make that happen. I hope that it works better and eliminates any smells.
I also got the factory cover panels to fit over my new charcoal canister, got the other butcheek cover built from MDF and got the rear carpet fit.
Not done in the trunk, It is going to get all trimmed out with a nice stereo in there but running out of time for Davis and LS Fest.
Hope to get some seatbelts ironed out in the next few days, door panels to upholstery shop and rear carpets all bound around the edge next week.
I leave for Davis in 18 days, 10 of them I will be out of town.
Sean
Old 04-08-2019, 03:01 PM   #499
M.H. Yount
M.H. Yount's Avatar
Need more jacks. Just sayin'....
Old 04-08-2019, 03:46 PM   #500
patrickstar
patrickstar's Avatar
Came into this thread excited to see a beige 83 242 getting LS swapped, because it would be great inspiration for my beige 83 242!
...And now I feel inadequate. Great thread, beautiful car. Hope I can see it someday, I'm just down the columbia river gorge in SE Washington
patrickstar is offline   Reply With Quote
