Old 02-06-2019, 03:24 PM   #26
Chilm
Double Dutch
Chilm's Avatar
Thanks for the info Swedbrick,
a diy kit sounds interesting, count me in if you have one
Flying Dutchman - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 03-20-2019, 12:49 PM   #27
Swedbrick
Swedbrick's Avatar
Post A bunch of little fixes
Since the car is finally out of winter storage again, I got to work on a bunch of little fixes on the car I had noticed after getting it running on LH for the first month.
The first fix was the car nearly dying at the stop light if you weren't gentle on the brakes, I suspected the pump having fallen of the hanger, however the issue was in the return tube on the pump hanger. It was aimed in stock position to just outside of the stock bucket in the tank, and the new pump would suck it dry by pumping it all out. This was fixed with a little readjustment of the rotation of the return tube.
The next fix was getting a better fuel pressure regulator installed since I got a lambda code and noticed the car running rich with the bigger walboro pump. I got myself a chinese version that would work, and instantly tore it apart to replace all the orings with quality items (since one of the original ones on the one my brother bought was installed incorrecly), cleared the chips I was warned for and took all of the fittings out, since they were sealed with epoxy. I retapped the threads to get the coating off, added permatex and put the thing back together
With the fuel pressure regulator now fixed, I got to figuring out a way to adapt it to the stock fuel rail for now. I welded a piece of steel to the chopped off end on the original FPR, and drilled and tapped it to fit the npt thread on the reg as a mock-up, I also made a nice bracket and painted it black.
After testing, seeing the needle bounce in all sorts of weird manners and wondering for a while what I managed to mess up, I realized I swapped the in and output of the regulator. So off it came again, and a new bracket was made
I then measured the distance, triple checking everything, and got an adapter piece made ready to be tapped to adapt the rail to the regulator for good.
This solved my fuel pressure issue, and I only got the lambda code for idle, for which I expect the leaky exhaust and the ignition system to be to blame. I also made the mistake of installing iridium plugs before upgrading the stock system, which promptly fried the (I assume) already worn rotor, being part of the bad idle problem.
To solve this I swapped back to copper plugs, put on a different rotor and cap I had laying around, and to resolve another expected issue, performed a vacuum leak check with brake clean listening for an change in rpm as I sprayed around all inlet air seals of relevance. Suprisingly no leaks were found The car still idled rough, but better.
I took a look at the plugs once more, and they showed rich
To get this part solved I am planning on getting to a sealed exhaust soon, as well as considering some other interesting options involving COP ignition since I have access to some extra b6304 coilpacks, if I can find space with respect to the turbo manifolds which will be getting a redo soon.
As a conclusion to my day of working through a list of small fixes, I made up a 8mm shim for my center bearing, since the sound of my driveshaft bottoming out, was starting to hurt Luckily this did the trick and the car is much less clunky now
Any tips on other checks I could do for my rough idle would be much appreciated The MAF, IAC and throttle body where cleaned before installation, and I will try to check those soon, but I suspect the issue is elsewhere. Unplugging the MAF results in an even rougher idle, so I'm pretty sure it is not my suspect.
Old 03-20-2019, 12:52 PM   #28
Swedbrick
Swedbrick's Avatar
Hi Chilm,
I'm currently still setting up a little company to get something like this on offer, hopefully I'll get it made before summer, but it might take a while to get it to work to my liking I'll will most definitely contact you when I have them at the ready.
Old 03-20-2019, 05:06 PM   #29
Chilm
Double Dutch
Chilm's Avatar
Originally Posted by Swedbrick View Post
Hi Chilm,
Great... I'll wait
Old 06-03-2019, 01:36 PM   #30
Swedbrick
Swedbrick's Avatar
Default Rust repairs, and another track session
Hi all, it's about time for another little update on the project.
As part of getting all of the door seals and windows seals fixed on the car, I got a set of side window seals since the old ones were pretty far gone.
The rust I suspected to find was actually the lesser problem, since due to a badly done respray of the car by a previous owner, the paint had separated from the window edge, which had been covered up with silicone sealant instead of an actual repair. This left the rust to propagate, and resulted in the rear window being so loose, that I could push it out by hand
After removing the window and committing to the long road to fixing the rust, I also decided to fix all of the rust spots on the top of the car, including a spot on the a-pillar and a little hole under the left side window strip.
First off the bad paint job and rust got sanded down and rust converter was applied. After which I proceeded by filling all of the bad spots and factory seams.
A few layers of primer after that with many hours of sanding, and the top coats could be applied.
I used paint matched 173-2 with 2 clear topcoats. For now the paint will be left to harden since it is acrylic paint, and will be blended in soon with a possible paint restoration for the whole car.
The trim got put back on, and the preparations for another track day at Zandvoort circuit began (all of this had to happen in about a month mind you:p). First up, a new steering wheel, for which I had to add a 3D printed ABS section to the hub adapter I bought, since it did not include a proper dust seal as the original wheel had
Made it to the trackday okay, even got to see the sunset without laying under the car.
Unfortunately due to a car spinning in front of me on track, I destroyed the edge of my right front tyre on the gravel since I still hit the chicane at some speed. I did have a good laugh with the owner of the corvette however, who was confused by the old Volvo keeping up with him on track
I also managed to get my hands on some new goodies for the rear axle, which I'll be putting in this weekend
More updates on the track brick to follow soon!
Old 06-20-2019, 11:25 AM   #31
Swedbrick
Swedbrick's Avatar
Default Aussie locker install, engine mounts and sorting out the little stuff
Pretty much a weekend after the track day the car was back up on the usual jack stands over the weekend, ready for the rear end locker.
I zip tied the sway bar to my exhaust and got the cover bolts out, and then then completely butchered the splash guard to get the spider gear retaining pin out
Ended up having to dremel it in half, since there was no way it was going to fit through the space available, proceding to realized that I was an idiot for believing that the pin was going to go past the 3.94 ring gear
Proceded to dissasemble all of the things, and make a mess of the rear of my car. I also marked the diff's position and caps with paint, to make sure I would be able to reassemble it all in the right place.
First job on the bench was to remove the splash guard for good, since such ugly buchery cannot be allowed Followed by disassembly and cleaning of all parts.
Gave the teeth of the locker a good greasing
Got it all in and checked clearance (converted to metric, specs were provided in inches), one note I did have to bend the provided spring retaining pins to get it all in before pulling them out to complete the install
Luckily the kit provided the pin I cut in two, so I got that back in correctly
I got the ring gear back on in the same location, torqued the bolts to 100 Nm as specified for flanged bolts by the green book for the 1030. Gave it a greasing and put it back in, reverse order of it all, also re greased the wheel bearings and gave it all a clean and fresh fluids. also replaced the stripped fill plug with the oil pan plug of an 850, same thread and a lot cheaper, long live internet cross referencing:p
Next the sound that gave me a mini heart attack on the way to the track since it went away with the clutch pressed in, sounding like a broken release bearing. Luckily it only was a loose fuel pressure gauge bezel, but it did scratch the glass This time re-installed it with thread locker and spring washers for double the safety.
I then moved on to the motor mounts, which were part of the vibration issue that probably got them loose. Replaced them with some I got from my dad, not sure for which Volvo they were, but with a few extra holes and a bit of cursing when it did not align first try, I got the new ones in, much better, the car feels way smoother now
The last thing I fixed was my coolant leak which I noticed after the trackday when engine bay temps got hot. Whilst pushing my brothers car into storage for winter I found out my fan was not yet ecu operated, boiling the coolant, I have been making due with a jumper for now. The issue was pretty clear when I got the water pump off
The easy job went hard mode when I broke off one of the bolts in my blockThe welder got involved, but did not help
I ended up drilling in tapping for an acceptable result, the old bolt was really rusted in there somehow
I got the pump back on with new seals and a cleanup in the parts washer, and also removed my power steering setup. I'll be moving all of that a bit to make room for the future ITB manifold upgrade.
More updates soon on rechipping the ecu for e-fan compatibility, getting buchka wasted spark and cruise control installed and cleaning up the engine bay some more
Old 08-09-2019, 08:59 AM   #32
Swedbrick
Swedbrick's Avatar
Default Crazy sprint to get to
This post will be a bit more chaotic than normal since I was pushing to get the car ready for the holidays so some things are not in the photo's because I forgot to take them:p The chassis had a lot of work to get done, which will be somewhat summarized below, with some recent post holiday updates for the cruise control included
The first thing on my personal list of things to sort was to get a straight pully on the PS pump once more, so I got to cheap second hand pumps with the V belt wheel, bought a tool from aliexpress and got to work.
Got the new pully on straight, however did manage to break the tightening tool for getting it back on, so much for cheap aliexpress tools haha. This should do for now.
Discovered that the stock bracket would work with 2/3 bolt holes a bit lower on the block so I mocked up a test fit, and also re straightened the original bracket which probably was part of my issue This should allow for my plans for the new long runner intake plenum with the ITB's and give some more space for the two intercooler tubes towards the intake.
Used this to mock up a shorter power steering hose with remaining bits I got with the used pumps, and also got a nicer return hose mounted.
Made a bracket for the bosch coil for the wasted spark upgrade out of aluminium scrap, and gave it a sand for the cool look.
I elongated the hole in the stock PS pump bracket to get the 3 holes to align once more.
And proceeded to install the buchka wasted spark board in my EZK module using the unused EGR pins for the coil signals and launch control controls?
I then made a whole bunch of brackets to clean up the engine bay and mounting of the ecu's along with a bracket to mount the ignition module for the new wasted spark in the location of the firewall weight.
I also made a new bracket for the fuel filter since I did not like its location in the engine compartment, so it got relocated to under the car as it should be.
Had a massive face palm moment when I recieved my new hose with the original mock-up fittings on a new section of hose. These were welded shut, still at a loss how they missed this and decided to put them onto the new hose Made a couple of calls and got the correct hose in the mail just before my holiday, more on how that one turned out later haha
I also recently got to installing the cruise control after the holiday, with the launch control and e-fan switches
The old ezk mounting bracket atop the pedal box made the perfect location for the 940 module (running a 48t axle), and it should all work when I get to finishing it up
As for the holiday I managed to make it to Limburg, the only hilly place in the Netherlands Good mountainbiking adventures were had, and my friends had quite some laughs about the 'streetability' of the locker diff The car also improved quite a bit in fuel consumption and power with the wasted spark setup, which made up for the rattely diff haha.
I also managed to visit Sander during our day trip to Luxembourg to see al the v12 crazyness, getting to see the car in person was really cool, and I got to experience the his awesome dodge challenger on the roads there To repay the favor I gave him a ride in my trusty brick, to get him familiar with the creaks and rattles of the interior again which he had forgotten about, and to remind him of the awesome capabilities of these cars when decently set up, at least to the extend mine is.
Whilst getting a tour of his pretty cool shop I also bought his old xc90 front brake setup since he has since upgraded to bigger and better thing, which I'll be getting to when I get some 17" wheels setup
On the way back unfortunately the new (very $$) power steering hose cracked which I discovered when tightening my banjo to stop the leak in front of the airbnb, when the hose folded in on itself and covered me and the driveway in ps fluid Luckily the owner was really cool and we ended up scrubbing the driveway and all was good. I tied an old shirt under the car disconnected the belt and drove the car home on muscle, I might end up deleting the whole system since I am getting rather fed up with the whole PS endevours
Anyway new updates will follow soon on the turbo manifolds, since I am done with the chassis for now!
Old 10-12-2019, 02:18 PM   #33
Swedbrick
Swedbrick's Avatar
Default Quick little update
Since it's been a bit since an update, here's a quick little update. With the good weather season progress has been slow, since I'm mostly out for trips and have been enjoying the car running well during trips with my brother in his new very clean beige 744. Here shown just after lowering and a trip to the yearly dutch volvo convention.
Where I ofcourse had plenty of stuff to sell, and gave a little promotion to my little company and took the twin turbo project as a good conversation starter
I also finally got a set of the 960 chassis braces for me and my brother which will get installed with the front suspension upgrades I'm planning:
- Camber modded struts or TXR adjustables
- IPD LCA busings for added caster
- Koni yellow shocks (current orange ones are questionable)
- DIY strutbrace to clear the twin turbo's
With the front suspension the big xc90 brakes will also be installed for which I will need bigger wheels So in a lucky find I ran in a affordable set of revolution motorsport millenium rally wheels in 17x7.5 front and 17x8 rear
And with a tryout today for fitment and looks I'm very content and stoked for the install which will probably happen after winter!
Old 11-13-2019, 04:01 PM   #34
Swedbrick
Swedbrick's Avatar
Default Front suspension fixed
Due to my annoyance with the lack of front end grip during my last trackday I decided to overhaul the front suspension of the brick a bit, more will follow, but this is what was done the last couple of weeks
Starting of with the cambermod, as commonly known here, which increased my camber to somewhere between 1.5 to 2 deg of negative camber as per my phone and the leveling app. I chose to just take the front studs out of the plates, loosen the back ones, and put a rachet strap across the strut tops to pull them together to the max that was allowed in the strut tower. After a new 10mm hole and pulling the studs back in with some chassis rings in the right size, this is what I ended up with on both sides.
I then moved on to installing the new 960 chassis braces, realizing that my lower control rubbers were shot. Luckily the brake upgrade I bought from sander came with his old LCA's with new (10y old rubbers) which were in much better condition, so I swapped those on.
I then proceeded to being annoyed while finding out my roll steer correctors made the torquing of the bolts while the car sat down on the ground, almost impossible, luckily my socket set had just enough movement in the joints to get it done, pfheew. Moving on, I also torqued into place the braces for which I had pre-dremel'd the appropriate slots, perfect on #2, good enough on the other with a chassis ring on top
Whilst under the car I also got rid of the culprit for the power steering leak, it would seem like the bend was already torn before I tightened it further. I fear that the person making the hose did not anneal the metal before bending, resulting in the failure. I was in luck however, for now the stock hose, with some gentle persuasion fit in its place. So PS is back for now.
I also got to some future goodies prepared in the form of the bijlsma EZK chipping kit
Which will be put in somewhere this weekend if I feel like it at the same time as a 3deg advance switch, which has been on the list for a while, since I took it out with the new loom install. This time it will be contained in the EZK box itself.
One thing I did not like about the kit was the use of the cheap non shock/corrosion proof sockets, as shown on the left, these are notorious at my engineering course for causing weird bugs. Not what I would like to see in my ignition controller, so the provided chip in the kit got soldered directly to the PCB and the EEPROM socket got replaced by a much higher quality machine pin socket.
Below a quick link about what I'm on about, for automotive shaky applications, I'd always go for the machined pin version, that's why they are also used for the LH2.4 EEPROM sockets:P
http://retro64.altervista.org/blog/tht-ic-sockets/
Old 03-01-2020, 12:26 PM   #35
Swedbrick
Swedbrick's Avatar
Default Car almost out of storage again, time to prepare the loose ends!
With the winter almost over again, the car will be back somewhere this week from winter storage, with a fresh registration check (APK) coming up soon, I've been preparing a couple of loose ends which will be done over the coming months.
During winter I've been playing around with mostly little projects on the car, and the XC90 brake upgrade as can be followed in projects and restorations in a separate thread:
http://forums.turbobricks.com/showthread.php?t=352970
In the meanwhile without a proper car, I've been making due with this, which is somewhat reversed from how normal people treat their bikes haha, but 5hp can be a lot of fun in the snow
Since backup transportation is sorted, I've been looking into the ITB setup, and after finally finishing the spacers for the throttle bodies, and with some really nice parts Sander made for me, I got to this stage.
Since I'm also planning to run a set of 16v 350cc injectors from the P80 which I got from mrBlue, I made a set of these jumpers with a little overstock for my small company to take to volvo conventions
I also made this set of centers for a future strut brace, which I can test as soon as I'm finished porting the turbo manifold, which might take a bit
The driveshaft also will get an improvement in the shape of a late M90 turbo one, with fresh everything (and yes its gold, haha). It will be put in place with a newly powdercoated brace, along with a softer rear sway (25mm ipd -> 19mm stock turbo) for better grip with the locker since it is now a bit too loose
I've now also finally concluded on a new direction for the build inspired by some retro 80's racing cars, and an adjustable rear spoiler.
Which looked pretty decent on the quick mockup of what might work, with the spoiler mounted on the stock roofrack locations.
The rest of this thread also got a refresh with functional images (now on a different host) and a removal of some unnecessary bits for a better read, so if this is your first read, it should be a better one
Old 03-08-2020, 07:19 PM   #36
Sander
Good news everyone!
Sander's Avatar
Looks like you won't be bored anytime soon. Also, gold driveshaft ftw.
Old 03-09-2020, 01:31 PM   #37
Sjeng
Sjeng's Avatar
Love your attention to detail. I think you need bigger injectors! Or are those temporary?
Old 03-09-2020, 05:25 PM   #38
Swedbrick
Swedbrick's Avatar
Thanks! These are the temporary ones, I'll be looking into a set of 980cc bosch EV14 injectors for the final setup, these should allow me to at least get to playing around with e85 on the NA motor for now, since I'm pretty close to a station in Germany that has it on the pump. The 350cc injectors should drop right in for a slightly richer mix on the b230f base map
Old 04-02-2020, 08:54 AM   #39
Swedbrick
Swedbrick's Avatar
Default ITB progress and more
With the new found time in my room due to the virus, a little more indoor work got done, first of which was a lot of progress on the itb to block adapters, cue the beauty shots
Even the most crusty fuel rail on earth fit up nicely without interference
I also got around to swapping out the rear swaybar from 25mm to 19mm and also softened up the rear koni's a lot, which made a great difference in rear end grip, making the aussie locker rear end a lot less drifty.
The propshaft also got swapped (well partly, but parts are underway, turns out the rubber couplers were still made in west-germany) solving my problem with the double flex make it work solution that has been under the car for a while:p
I also got started on the quadruple EGT sensor idea that I've had for a while, which will have a sensor in each runner, (cheap cn-racing sensors) with a small oled display on the dash for the temperatures. The sensors already seemed to work to 600 degrees C, with the tip getting red hot, so I believe they'll work out okay.
I'll 3d print a nice enclosure and get some better displays underway, I've already made a second soldered prototype running the finished code, with averaging which proved very accurate
Old 04-02-2020, 05:07 PM   #40
Chilm
Double Dutch
Chilm's Avatar
Hi Chilm,
And...
Old 04-02-2020, 07:01 PM   #41
Swedbrick
Swedbrick's Avatar
And...
No boost to test with yet unfortunately, but I've decided upon a different route, going with modified 52mm gauges from china, to which a MXP5700 might be added. Basically, given that cheap gauges go for 20eu each including the sensor and given that decent pressure sensors are already above that pricepoint, the kit doesn't really make sense unless I've already created it for myself
Old 04-02-2020, 07:48 PM   #42
esmth
Those little OLED screens are my favorite things. I have one as a desk ornament displaying pulses from a GM Maf!
I also used one to display MAP overlayed with fuel lambda, but it was super ram-intensive.
1991 244 LH2.4 M46 352k miles
Old 04-03-2020, 08:02 AM   #43
Swedbrick
Swedbrick's Avatar
Yes they're wonderful, a lot less intrusive than the standard led displays, especially the white ones. I used the u8x8 library, which is much less intensive, since the Arduino micro I'm planning to use has a lot less memory, and I'm also multiplexing I2C for the displays and using SPI to interface the sensor controllers so it's pretty intense haha
Old 04-03-2020, 01:00 PM   #44
esmth
I recently switched from my home brew, memory intensive buffer-and-send technique to u8x8 patched with support for attiny's USI. Works fine even with my micros with only 128 bytes of memory, and no dedicated i2c/spi! I wish I had heard of u8x8 earlier before I wasted so much time on raw doggin the oled protocol, lol.
Old 04-21-2020, 02:26 PM   #45
Swedbrick
Swedbrick's Avatar
Default The wheelwell
With the bi-yearly inspection coming up, it's time to take care of some of the rust on the red wagon. To achieve this I recently bought this welder at an auction of the motor-sports association I'm a member of, after a new torch, a new set of high current feed through terminals and a few re-crimped terminals, it was ready to get going
I started off by reducing the flaking rust and thin steel to a bucket of dust
The inside was farther gone than expected, so more cuts, and the discovery of a second hole in the wheel-well itself
Got that patched up and the rust removed ready for the new panel after a coat of zinc paint, and also fixed the inside corner (door still shut, so win)
Made up a new 1.5mm thick panel (here pre-fine tuning) and got it in place
And proceeded using this cool tool and later a file to get the plug hole made for the rubber cleaning access plug
Had quite the fight welding in the panel outdoors and upside-down (wind and angles were far from ideal for gas coverage), but got it done, with plug weld on the original spot weld locations. Got it done just in time for my small throw away bottle to be empty
Inside view
Next up will be a set of 967 chips with a 951 mapping scaled for the new injectors to go in my spare 984 ecu, a new exhaust section/downpipe which will hopefully seal and some more rust repairs in various places
Old 04-21-2020, 05:22 PM   #46
dorvin
idunno
dorvin's Avatar
Nice work, that looks great!
'85 Cadillac Eldorado
'91 Volvo 740
'93 Volvo 240 - 683/1600
'12 Volvo S60 T5
dorvin is offline   Reply With Quote
Old 04-23-2020, 06:42 AM   #47
Swedbrick
Swedbrick's Avatar
Thanks!
Old 05-14-2020, 07:09 PM   #48
Swedbrick
Swedbrick's Avatar
Default The great inspection prepping jam pt1
Continuing with the prep for the yearly inspection I got to installing the chipping board in the ezk, and adding a little dip switch for the retard/advance selector pins, for now it's on +3deg advanced with the stock 169 chip.
I then moved on to creating a chip for one of my spare 984 LH casings with the e-fan chip to get that working, with the rescaled mapping for my new 350cc ev6 injectors I bought from mrblue (old ones were the (337cc) turbo ones, explaining my richness and bad idle running the 951 ecu, which is configured for the yellowtops (214cc) herp derp)
I took the -946 ecu bin as that should be capable of controlling the e-fan, and changed the mapping to the -951 one, since that one worked well before (read: safe). More info on the fuel/spark tuning thread including discussion of the available stock NA maps for the -9xx ecu's.
klr142 was also so friendly to provide me with one of his lower spec bin files for his old engine tuned with a similar setup, which I'll be looking into as soon as I get a wideband and an ostrich installed. During the chassis rust repairs I also got the exhaust all fixed up, so measurements should be more accurate now
I also took a moment to swap on my second K&N filter (bought for project Twin Turbo), realizing how dirty the original one had gotten after around 500km
Next up on the things I have postponed and need fixed was a speedo convertor with a open collector output for the LH computer to prevent the weird high idle issue post highway. I based it on a simple 74HC393 ripple counter in combination with the relatively cheap NCV1124 VR-conditioner, and made a nice little 3d printed case to fit it neatly behind the cluster. My speedo now already starts at the 20km/h reading, and appears to be perfectly linear, it took a few attempts to get right (6 in and outs maybe) but it works now:p
Old 05-14-2020, 07:21 PM   #49
Swedbrick
Swedbrick's Avatar
Default The great inspection prepping jam pt2
Moving on, the tricky part of the repairs, with the exhaust off I got started with fixing this hole in the front chassis member.
Got it patched, after some uncomfortable under car and upside down welding (don't own a bridge, only jackstands, with spare tires for safety underneath )
I also located a second rust spot and marked that out before
And used the new hole to check the backside weld penetration, looked pretty good
Also got this new hole patched up
Since I had used multiple brackets to hold my relays and ecu's in the engine bay before I had several holes in the wheel well to patch, so after some time with the burner to get the rubber coating off, I got those patched up
My battery tray had the typical 7-series characteristics of Swiss cheese
So plates were put in to get that sorted
I found a last little sneaky spot, patched that and coated all of the rusty spots with new rubber after coating with rustconverter or zink chassis paint.
Inspection already happened today, apart from one steering boot being torn, all was good, so after tomorrow and a set of brand new steering rod ends, it should be ready for 2 more years of modification and fun
Old 06-13-2020, 04:49 PM   #50
Swedbrick
Swedbrick's Avatar
Default Bringing back the shine
With the sun out but still a few clouds left I decided to kill some time trying to fix my red faded paint, starting with this turtle wax restoration polish by hand
It really did a lot quite quickly with the left being unrestored, and the right with only a couple of cross hatch rubs with the compound.
It only took about an hour for the whole hood, so I'll be doing the rest by hand as well and some blending on last years repairs by wet sanding
I also got a little spray matching going with the better available motip paint (right) compared to the paint matched stuff I used last time (left), both seemed an okay match so the corroded aluminium thrunk hatch will receive the motip
Since my wiper arm mechanism decided to play quits, just after the central locking switch decided to go, some comfort was encountered whilst scrapyard hunting with my brother
The crappy fuel pressure regulator gauge also decided to go again showing 8 bar, so that recieved some professional d1-spec upgrades
I also made some deciscions on the engine project and sold off my PZA 16v camshafts
To get some of these for the front
Those will go in with the new struts and front brakes for which the caliper brackets finally got ordered
Hopefully I'll get around to playing with those soon on the fitup
