Old 04-10-2020, 02:56 AM   #401
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
*fap*
Old 04-10-2020, 12:32 PM   #402
JerryJS8
der Junge
JerryJS8's Avatar
Originally Posted by MadDog_945 View Post
*fap*
Clean up on aisle 3
@Sander - Love it, as always
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 04-10-2020, 04:42 PM   #403
adomz
Volvo 486 owner :D
adomz's Avatar
WoW!
Errr.... 242... No engine no cringdingding...
=->Adam's youtube channel<-=
adomz is offline   Reply With Quote
Old 04-11-2020, 01:09 AM   #404
Sjeng
Sjeng's Avatar
Very impressive work. Hats off.
Old 04-11-2020, 01:33 AM   #405
R-Pow3R3d
Master of Disaster
R-Pow3R3d's Avatar
Looks like a locomotive engine in the front. It's enormous. What a beautiful engine bay!
1990 745 Turbo Intercooler
2007 XC90 V8 Sport
2007 XC70
R-Pow3R3d
R-Pow3R3d is offline   Reply With Quote
Old 04-11-2020, 11:30 AM   #406
940 16 valve
940 16 valve's Avatar
I'm always excited when I see updates to this thread. Inspiring work as always Sander!
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191
Old 05-11-2020, 03:28 PM   #407
Sander
Good news everyone!
Sander's Avatar
Thanks for the nice replies!
Unfortunately the stock Volvo 940 E-fan doesn't fit, even with the radiator about 4" further forward than stock. Got a Spal one that is a lot flatter. It can move 2220m3 of air per hour, should be enough.
Installed an ABS unit from an E46 BMW M3 (Teves MK60). It's a proper 4-channel abs system that will also work as a standalone unit.
The front part of the drive shaft is also done. I used the stock 740 2-piece drive shaft. I cut the rear part that sits in the bearing off of the front drive shaft and turned it down to fit the new tubing (same diameter as stock, 70mm). I took the forward flange off of the S600 one and made an adapter thingy to get it to fit the 70mm diameter of the Volvo shaft. The S600 one is only 60mm in diameter. I never would've thought that I would need to beef up the parts from the S600 to fit the Volvo... The rear piece of the Volvo driveshaft doesn't need to be modified. The length is perfect, it just needs an adapter/spacer to fit the Volvo shaft to the BMW diff I'm using. Nothing terribly complicated there.
Old 05-11-2020, 04:32 PM   #408
LC4CARL
Aero challenged
LC4CARL's Avatar
That engine is so big.
And that driveshaft is to pretty to conceal out of sight, under a car.
@PDXvolvo on IG
B21FT with a T3/T4, STS coil-overs, T5 trans.
Old 05-11-2020, 05:35 PM   #409
Chilm
Double Dutch
Chilm's Avatar
This is better than sex (almost) ;P
Flying Dutchman - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 05-13-2020, 12:33 AM   #410
940 16 valve
Interested to see the adapter you come up with from driveshaft to diff. I recently picked up a BMW LSD to adapt to a MKI IRS like you have. Thanks for the inspiration!
Old 05-13-2020, 03:22 AM   #411
arsenix
Have any pics of the wheel encoders you installed in the rear for the Teves Mk60? That is awesome. I have been considering this for our racecar. These modern ABS systems work quite a bit better than the 1980's stuff I'm used it.
88' 740 GLE Wagon - B230FT, T5 Trans, MSII-extra, G80, 3" T->T Exhaust
- - > Project Thread < - -
My new project - 1990 740 SE Wagon
arsenix is offline   Reply With Quote
Old 05-13-2020, 04:25 AM   #412
Sander
Good news everyone!
Sander's Avatar
Thanks, it'll get painted black though :(
Haha thanks
This is what I made. It's pretty straight forward, just a lip and bolt pattern on one side that matches the diff flange and the other side an indent and Volvo axle pattern that matches the U joint. Don't mind the weird surface finish on it, I was experimenting a bit with some different tooling on my lathe. What diff did you get exactly? BMW used something like 6 different input flanges on these things. Also I'm not sure if the rear part of the Volvo drive shaft for the IRS equipped cars is the same as the ones for the live axle ones. My car had a live axle, so that's the shaft I used.
Another way that would work without an adapter is to disassemble the Volvo axle's U joint, turn down the lip/centering ring of the U-joint flange (that centers it on the diff) to the size of the BMW flange and then drill the Volvo hole pattern in the BMW flange. It'll look completely stock like this.
Not yet as I still have to make that. I'll cut a pair of tone rings on my plasma cutter that goes over the outboard cv joints and make a little bracket that'll hold the BMW sensor. I can make an extra set if you're interested (and it works as planned)
Old 05-13-2020, 03:05 PM   #413
77volvo245
77volvo245's Avatar
This is what we made for a TR6060
STSmachining
Old 05-15-2020, 02:10 PM   #414
aidanahunter
aidanahunter's Avatar
Everything here is just so good! I'm really enjoying watching the progress.
Aidan
4.6 32V 240 Wagon
aidanahunter is offline   Reply With Quote
Old 07-03-2020, 11:32 PM   #415
JohnLane
Sander... Any updates?
Old 07-04-2020, 05:11 AM   #416
TurboDutch
Verschrikkelijk mooi dit :D
TurboDutch is offline   Reply With Quote
Old 07-05-2020, 05:28 AM   #417
Sander
Good news everyone!
Sander's Avatar
Thanks!
Nothing to report until now. It's a bit on hold for the moment as the whole corona thing wiped out pretty much all of my disposable income for the time being. Things are starting to go somewhat back to normal again now, but still a long way to go.
Dankje!
Old 07-05-2020, 05:54 AM   #418
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
.. hm.. i can imagine you sitting in corona home office flying planes in the new m$ simulator? ;)
Old 07-05-2020, 09:23 PM   #419
arsenix
Yeah would be! I'm very interested to hear how this works out. I'm doing a Mk2 IRS swap on my v8 740 project and I'm considering this. I'm also not doing any work on this until I finish my other project car
Old 10-04-2020, 12:34 PM   #420
JohnLane
Sander I hope that you are making progress.... That life is returning to a 'normal' that is a positive for you and that you will soon tell us of how your pipe organ sounds on the road!
Old 10-04-2020, 04:15 PM   #421
tomasss
former PRVert
tomasss's Avatar
Yes...we need to hear that thing...
Volvo 740 Turbo B204GT 1991 >project thread<
It's the oversteer that scares passengers. It's the understeer that scares the driver.
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
Old 11-01-2020, 06:09 AM   #422
Chili
You may consider ceramic coating for the exhaust manifolds; just buy the painting material and use oven - and polish those. I did that to my MB CL600; and it looks to be effective in keeping the heat inside the pipes.
Chili is offline   Reply With Quote
Old 11-01-2020, 12:05 PM   #423
Dirty Rick
Dirty Rick's Avatar
"I would also strongly recommend using one or two S54 idle valves as they flow quite a bit more air than "normal" idle valves."
Can someone ID these Idle valves? Are they bigger than a 6cyl BMW ISC?
Old 11-02-2020, 01:15 AM   #424
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Looks to be the same valve as lots of other cars:
https://www.realoem.com/bmw/enUS/par...&q=13411733090
Alex Buchka is offline   Reply With Quote
Old 11-02-2020, 01:01 PM   #425
Dirty Rick
Dirty Rick's Avatar
Cool Thanks
