Old 12-13-2020, 03:18 PM   #426
Mattis
Mattis's Avatar
Congrats on the feature in bilsport magazine! 😀
Mattis is offline   Reply With Quote
Old 12-20-2020, 03:33 PM   #427
JohnLane
Sander.... Radio silence is deafening!
Old 12-27-2020, 08:25 AM   #428
Sander
Good news everyone!
Sander's Avatar
Originally Posted by Mattis View Post
Congrats on the feature in bilsport magazine! ��
Thanks! No idea yet what they wrote though, they were supposed to send me a copy but haven't heard anything yet and the article on their website is behind a paywall.
The Drive wrote something about it too, as did Top Gear in the Netherlands
https://www.thedrive.com/news/37080/...t-flying-brick
https://topgear.nl/autonieuws/merced...-in-volvo-740/
Yeah haven't really done much to it yet. A few small things here and there but that's about it. I hope to get going again in about a month or so.
Old 12-27-2020, 10:54 AM   #429
KwikBrik245
KwikBrik245's Avatar
So cool! The progression is amazing
Daily: '91 245, B230F/M46 P-type, '93 Dana 30
'88 744, Twin Turbo LS1/T56, Grizzly locked Dana 30.
KwikBrik245 is offline   Reply With Quote
Old 02-13-2021, 01:02 PM   #430
Sander
Good news everyone!
Sander's Avatar
Yay a bit of progress. I've been busy with a long list of small things here and there. Been working on adding an ABS sensor and tone ring to each rear wheel for the BMW M3 abs system, more on that later. I also made a fan shroud as there is still enough space. Initially, I had the fan just tied to the radiator, but a shroud is better. If only I had the proper tools to make nice bends... Oh well, hammer it is.
And I added paddle shifters to it. I like the shifters to stay in place when you steer, like on most Italian sports cars. I used the shifters from some Maserati and modded them to fit the Volvo. They fit way better than I expected.
Old 02-14-2021, 01:21 AM   #431
940 16 valve
940 16 valve's Avatar
Spectacular! Anything less than Maserati paddle shifters wouldn't have done this build justice.
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191
Old 02-14-2021, 12:36 PM   #432
Swedbrick
Swedbrick's Avatar
That looks sweet!
Old 02-14-2021, 01:24 PM   #433
JohnLane
Progress!
Eager to hear the pipe organ run. Should be glorious.
Old 02-15-2021, 05:25 AM   #434
Arn02
Arn02's Avatar
Those shifters are great!
Ambitious but rubbish.
The 245 GT
The Euromurican
Old 02-15-2021, 01:11 PM   #435
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Nice work mr. Belt Sander what are you doing for engine and trans Management? Asking becuz interested :p
Old 02-15-2021, 06:52 PM   #436
Sander
Good news everyone!
Sander's Avatar
Thanks everyone!
I think you'll be pleased to hear that I'm planning on running a Maxxecu Pro. You're still doing this remote tuning thing? ;) For the transmission I'm using a standalone controller from ofgear.dk
Old 02-16-2021, 03:44 PM   #437
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah! Maxxecu!!!
Old 03-03-2021, 01:49 PM   #438
Sander
Good news everyone!
Sander's Avatar
Spent some time finishing up the ABS system. The BMW M3 abs system is a proper 4 channel system, so it needs a sensor for each rear wheel. I made some tone rings on my cnc plasma cutter, zinc plated them and tack welded them directly to the CV joint. Also made a little bracket for the sensor that uses the caliper bolts to hold it in place. The front was easier as the 960 knuckles that I'm using already have a 48 teeth tone ring and a hole for the sensor. The Volvo sensor is just the wrong type, so I made a little adapter thing out of aluminium in which I glued the modified BMW sensor. They're wedged in there, the silicone/glue is just to be really sure they're not moving.
The front:
Old 03-03-2021, 03:29 PM   #439
JerryJS8
der Junge
JerryJS8's Avatar
I can see how an independent Anti-Block System on a spaceship would be useful
Gimme a first start video already!!!!
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 03-28-2021, 11:19 PM   #440
7MGTEVOLVO
You are a lunatic... in the best way possible. An M113 would have been ridiculous enough for most, but not this madman.
Did you replace the valvebody in addition to the TCU integration\bypass work for the paddle shifters?
7MGTEVOLVO is offline   Reply With Quote
Old 03-29-2021, 04:06 PM   #441
Sander
Good news everyone!
Sander's Avatar
That'll still be a while unfortunately
Thanks! No need to change the valvebody. The only mod I did was drill out one of the oil passages to keep more pressure on the 3rd gear clutch pack during shifting from 3rd to 4th. The stand alone controller can't reduce power during shifting, so without that mod the rpm would flare up during the 3rd to 4th shift. It has full control over the stock valve body and torque converter etc and supports paddle shifters.
Old 03-29-2021, 05:57 PM   #442
7MGTEVOLVO
Originally Posted by Sander View Post
...Thanks! No need to change the valvebody. The only mod I did was drill out one of the oil passages to keep more pressure on the 3rd gear clutch pack during shifting from 3rd to 4th. The stand alone controller can't reduce power during shifting, so without that mod the rpm would flare up during the 3rd to 4th shift. It has full control over the stock valve body and torque converter etc and supports paddle shifters.
Gotcha. FYI, I installed a VRP valvebody in my E55 and it significantly reduced shift times. It changed the whole nature of the car on track, as the previous lag between gears was so severe that the rearend would start to unload during mid-turn upshifts.
Old 03-31-2021, 01:31 AM   #443
Arn02
Arn02's Avatar
@Sander: You might want to check Wesley Kagan on YT. He's doing the same sort of thing but putting it in some '73 Corvette.
Old 05-15-2021, 09:49 PM   #444
JohnLane
Sander…. Making progress?
I’m eager to hear the pipe organ!
Old 05-17-2021, 05:53 AM   #445
Sander
Good news everyone!
Sander's Avatar
Not a whole lot to report yet, been working on a very long list of small stuff that needs to be done too. Made a trigger wheel for the cam sensor. Modified the mounting thing for the distributor rotor and added a trigger wheel to that, so it'll hide nicely under the engine cover. Moved the battery to the back and made a mount for it. Installed the Mercedes shifter unit. Just made a simple plate that bolts to the Volvo trans tunnel and has mounting points for the Merc shifter. Just have to move the seat heater switches and make a small new plastic panel to cover the gap and it'll look like it belongs in there. Worked out quite nicely. I needed to use the Merc shifter because my transmission controller needs some of the electronics which are in that unit. Lastly I installed an e-throttle gas pedal out of a V70III. Many things left to do still, but it's slowly coming together.
Old 05-17-2021, 10:08 AM   #446
rijk
rijk's Avatar
Default Spare?
Still look at all your work with admiration.
Just curious. Where will you store the spare wheel?
The B204FT to B234FT conversion
http://forums.turbobricks.com/showthread.php?t=182821
rijk is offline   Reply With Quote
Old 05-17-2021, 07:41 PM   #447
LC4CARL
Aero challenged
LC4CARL's Avatar
Exciting!
@PDXvolvo on IG
B21FT with a T3/T4, STS coil-overs, T5 trans.
