Old 03-22-2019, 06:21 AM   #1
KoduKoer
Default My 940 T4 swap
I am burdened with the hellish task of fitting a small 1.9L whiteblock into my 940 diesel.
I have the engine and tranny in place and am about to start creating necessary engine mounts. When mounting the M90 to the engine, I noticed that bolt holes on the tranny line up with the engine block like they should, but wont line up with holes on the T4 oil pan.
Any advice on how to solve it? Do I even need to solve it?
Other thing that is concerning me is the drive shaft. Since the M90 is shorter than M46, the front section of the shaft will not reach.
Is the easiest option here to weld the two together?
I am apologise for any questions that might be too stupid, but I really want to get this thing done and will not hesitate to ask for advice.
Thank you
KoduKoer is offline   Reply With Quote
Old 03-23-2019, 09:34 PM   #2
volvo 4 life
volvo 4 life's Avatar
Sounds like a cool project, though I am partial to the diesels myself lol. Any pics of the bellhousing bolts that don't line up?
Originally posted by Forg: "How To Properly Seafoam A Saab In One Easy Steps":
Step 1. Push into sea.
Originally Posted by Tenacious Todd View Post
I was hitting the brakes real hard and the grille flew out and I ran it over
Only on a Volvo...
Originally Posted by isaac View Post
A volvo 240 with the front wheels chopped off would be a reliable all wheel drive vehicle.
volvo 4 life is offline   Reply With Quote
Old 03-25-2019, 08:23 AM   #3
Sander
Good news everyone!
Sander's Avatar
The T4 engine is basically a 6 cylinder 960 engine, minus 2 cylinders. You need to take a 960 oil pan and cut a piece out of the middle to shorten it and then weld it back together so it fits on the T4 engine. The same needs to be done with the oil pickup tube from the 960. I'm not sure about the T4 engine, but on the 5 cylinder ones you can also just use the 960 engine mounts and it'll bolt in. As Volvo designed this engine series (4,5 and 6 cyl) to be modular, I wouldn't be surprised if the 960 mounts just bolt on too. As for the M90 and the driveshaft, just get the front section of the driveshaft from the car you got the M90 out of. It bolts right on.
Old 03-29-2019, 01:56 PM   #4
KoduKoer
Yes I want it to be kind of like a bit modernized tribute to the old redblock 940 turbo. Plus I love the weight of the engine and hopefully with it being so short, it will improve the weight distribution a little bit.
No picture of the housing bolt holes since I dont have an oilpan attached and I bolted the crossmember back on, so the oil pan will not fit at the moment.
Originally Posted by Sander View Post
Just get the front section of the driveshaft from the car you got the M90 out of. It bolts right on.
That is what I did, disassembled the U joint and took the front of the 960 shaft. But I had a 10mm spacer fabricated because the rear axle flange on 960 shaft was different, more bolts and thicker. So the hybrid-shaft was just that much too short.
As for the 960 pan and mounts, it is a real headache. In Estonia, 960s are kind of rare and to find one for scraps is complicated and expensive. It seems that it is equal or even cheaper for me to have a custom oil pan fabricated out of the stock T4 pan. A guy who put a T5 in his E36 and faced the same problem with his oil pan, he welded it slim, rerouted the oil filter lines and said that he could do the same to my pan for around 100 euros. Finding, buying and modifying a 960 pan will probably set me back a little more than that...
Old 03-30-2019, 10:05 AM   #5
Lankku
Lankku's Avatar
Lower bellhousing bolts for transmission are not that important. It will last without those even with +800hp engine.
245 -90 "B6284T"
Old 03-30-2019, 06:35 PM   #6
KoduKoer
Thank you!
That is exactly what I was hoping to learn. Good man
Old 04-01-2019, 07:25 PM   #7
okoye
okoye's Avatar
What are you doing for wiring? I’ve been considering this idea lately
Old 04-02-2019, 06:55 AM   #8
KoduKoer
I have never done any swap, so I really cant answer that yet. If I get the big bad bits sorted out, I can start tinkering with electrics. I have the T4 factory loom, but the ECUs immobilizer has failed, or so I was told, so I might just connect the essentials and go for MS or speeduino ECU. Will decide when it becomes necessary.
Old 09-29-2019, 05:54 PM   #9
KoduKoer
I just got my custom oil pan and it fits (mostly...)
I have decided that I will go for MS2 for ECU. My biggest fear was the oil pan, now that it is sorted, I will start sorting out the intake manifold and turbo flange adapter.
Cylinders and the block itself is in good condition, for my relief, I didn`t have to reposition the steering box. But I sacrificed the oil cooler for this. You see, the T5 does not have this problem because oil filter/cooler bracket is in front of the cross member, not on top of it.
Old 09-30-2019, 09:42 AM   #10
You can get a bypass plate and run the cooler and filter in a circuit
Old 10-02-2019, 12:02 AM   #11
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Here's a picture of what I did on the 6 cylinder in my 242. You can see the bypass plate at the front of the oil pan and the setrab thermostat sandwich plate. I used the 960 angled filter adapter but you can also run the filter directly on the sandwich plate if you have the space for it.
Old 10-14-2019, 09:42 AM   #12
okoye
okoye's Avatar
Really interested in progress on this. Any updates?
Old 10-14-2019, 05:40 PM   #13
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
ha! thats the first time ever i see somebody doing that ;)
Old 10-14-2019, 08:21 PM   #14
Broke4speed
Broke4speed's Avatar
I've thought about it for my 240, but unless the engine gets moved ahead SUBSTANTIALLY, the oil filter and the crossmember will occupy the same space. I'd love to run a super light engine that's practically set completely behind the front wheels .
1984 244/ AQ140A / M46
Old 10-16-2019, 07:20 PM   #15
Dr. Volvo
Dr. Volvo's Avatar
It is also possible to use a oil cooler adapter from 960.
It replaces the plate under the crank pulley.
242L 1976-2003R.I.P.
'74 mod. 242L (Currently under restoration)
Installed now: Nothing at all
Coming soon:
B21ET Block bored to 94.0mm, '87 740 Motronic injection, Garret T3 trim 60, Alu M46
Dr. Volvo is offline   Reply With Quote
Old 10-26-2019, 01:35 PM   #16
KoduKoer
No big updates as of yet, but today I started working on the intake manifold. I will use a newer 5cyl manifold runners and have a custom plenum made for them. For exhaust manifold, I am going with stock, but rotated so turbo will sit at the front. Using an adapter plate, I can use a T3-flanged turbo.
Also thanks for oil cooling suggestions, that is some really good advice!
I need some suggestions about fitting a starter motor. Stupid thing is that I dont have the 960 M90 starter motor bracket and I was wondering if anyone had a picture of it? All 960 stuff is very hard to find in Estonia which is worrying me.
I have the T4 automatic starter motor, but I probably cant use that even if I had the bracket?
Old 10-26-2019, 05:38 PM   #17
lummert
lummert's Avatar
Would it have been easier to swap in a 5 cylinder petrol engine from an Audi?
Old 10-26-2019, 06:31 PM   #18
KoduKoer
Well I'm not sure. Audi 5cyl turbo engine is hard to find and I don't know what trans to use on an Audi engine and so on.. That T4 was super cheap and I just went for it, Volvo 5cyl hpt engine would have cost about 4 times as much. And that got me thinking that maybe it would be nice to fit a 4-banger as sort of a tribute to 940 turbos. Newer aluminum engine is much lighter and the block itself is so short that it is almost front mid-engined, crank pulley sits just over the cross member. I am really excited to find out what the handling is going to be like since my 940s have always been a bit understeery at times.
Old 10-26-2019, 06:48 PM   #19
lummert
lummert's Avatar
I would guess the front springs may be to stiff with a lighter engine.
Old 10-26-2019, 09:08 PM   #20
KoduKoer
I had not thought about that... If the springs are stiff, that I can live with, would probably help cornering with the BMW 17 inch rims I have installed. But if it also sits higher than rear, then it is a problem and I am going to have to adjust height.
Old 12-07-2019, 10:08 AM   #21
okoye
okoye's Avatar
Any updates?
Old 01-07-2020, 06:36 AM   #22
KoduKoer
Any updates?
No, can`t really do any major work in the winter time, I have a miserable cold garage.
I really need an 850 single mass flywheel and 960 starter motor bracket. If anyone has one of these, let me know.
Old 08-13-2020, 12:51 AM   #23
okoye
okoye's Avatar
We need updates
Old 08-13-2020, 03:52 AM   #24
KoduKoer
We need updates
Lets give you some then. I uploaded some photos here:
https://photos.app.goo.gl/9GR2skh6xzacfycw6
So what has been going on..
  • Installed some H-profile connecting rods with new rod bearings
  • Got a single mass 850 flywheel (btw if someone tells you that there are different flywheels for 228 and 240mm clutches, its BS, same flywheel, different clutches)
  • Found a brand new 850R clutch kit on ebay, ordered it.
  • Found a custom exhaust manifold for T4, unfortunately it was made for a different turbo and FWD, so we made an adapter. I had to raise the bonnet from the back a little bit to fit the turbo. (did not want to hack the manifold because I will probably go for a bigger turbo in the future)
  • Finally found the M90 whiteblock starter bracket. On the picture I have a 960 starter, but T4 one works as well.
  • Installed an intercooler, didnt go for the biggest one, but it should get the job done. For the radiator I have a 960 radiator with a stock electric fan.
  • Got a standalone ECU
  • Got proper O rings and installed the oil pan.
I have a nice oil cooler waiting for its adapter, 850cc injectors, just ordered the belts. I am waiting for my custom intake manifold, which is almost done (see last picture in the album) and once I get my manifold, I will have oil feed/return lines done and power steering lines.
Often struggling to find time but I am really motivated.
Thoughts?
Old 08-13-2020, 10:44 AM   #25
okoye
okoye's Avatar
It's looking good. Do you have better pics of your engine mounts? They seem really far forward. And what you did for your oil pan
