Old 07-12-2021, 01:21 PM   #1
Default Car needs paint; car needs sunroof seal
So my 242's sunroof seal finally bit the dust and it's time to have a shop (correct, I'm not tackling this one). Considering that most shops want around $500 to do the job, this is something that I would rather only have done once.
The paint on the top half of the car is also sad and the whole thing could do with some bodywork and a new coat of paint. This is something I'd like to put off for another 2 years or so if possible as the finish still has some life left in it, and I can't stomach a $5000 paint shop bill this minute.
Question here is: is it possible to have a good paint job done with the sunroof seal installed, or would it need to be removed as part of the prepping process?
Old 07-12-2021, 01:24 PM   #2
white855T
I'm going through this process now... You absolutely have to remove sunroof panel. Its not difficult and its something you can do yourself. If you're thinking about a paint job. Remove front & rear glass(also quarter glass too) It will take you half a day to strip the car(removing bumpers, trim, etc.) if you want to get a good job done. You can get a paint job for 2500-3000 especially if there isn't much body work to do.
Old 07-12-2021, 01:31 PM   #3
https://www.maaco.com/locations/or/portland-12334/
how psi stock cna sprout?
Old 07-12-2021, 02:00 PM   #4
I'm not asking about windows or removing the panel. My question pertains about the seal, specifically.
No, Ken.
Old 07-12-2021, 02:14 PM   #5
white855T
No, Ken.
There are guys who are really good at taping up cars but I just don't get why you wouldn't want to remove to seal. If you want it to look look like ass, I guess...
Maaco uses the cheapest paint. It will be peeling in a few months.
Old 07-12-2021, 02:38 PM   #6
the thought of doing a $500 job twice in a short time span makes me wince.
Old 07-12-2021, 02:47 PM   #7
OldCarNewTricks
OldCarNewTricks's Avatar
I'm planning to do it myself. I have a Husky compressor and a couple of paint guns. I plan to mask off my garage and use affordable paint. Much cheaper than 5k.
Maaco uses cheap paint, but if they did a good job with the prep, it would probably stay okay.
Old 07-12-2021, 03:15 PM   #8
white855T
Yeah sure, if you parked in a garage everyday, never parked in the sun. Then, yeah sure. I've seen macco jobs on 240s. They hold up for a couple of years and look like ass again. Bend over and take it like man. Awesome that you have a a big enough compressor to do it yourself. If I were able to run a big compressor, I would definitely be doing paint jobs on my cars. I can do small jobs like an engine bay but an entire job is not something that I can do in my shop space(only have 120v, not able to run 240v for a compressor). The cost of paint/materials is high but if you're able to paint it in your garage, why not. Mask off garage well but because overspray gets everywhere.
Old 07-12-2021, 04:50 PM   #9
OldCarNewTricks
My compressor is 120v.
Old 07-12-2021, 07:38 PM   #10
No, Ken.
Matching single stage, TB¢#3@p™ & in your home town, perfect for your molested hoop-t.
What's not to like?
Old 07-12-2021, 08:56 PM   #11
johfraser
Consider having it done by the Auto Technology Department of a Community College. Many include Auto Body and Paint curriculum. Visit the instructor and have a chat. I've had a couple of good experiences in the past and you only pay for materials plus perhaps a facility fee. Remove as much trim as you like or not.
Old 07-13-2021, 01:24 PM   #12
Short answer, no. Remove the seals before painting the car. There is no way to tape off a fuzzy seal and have the paint layer terminate right up next to it. Besides that, the buffer will ruin the seal when the paint is being polished.
Old 07-13-2021, 04:35 PM   #13
spock345
spock345's Avatar
What's not to like?
It you layer on that cheap single stage you can probably just keep polishing it to keep it looking OK until you burn through it.
I prefer single stage on older cars because I can just color sand it until it looks OK again.
1998 S70, grandma-mobile
Old 07-13-2021, 11:49 PM   #14
dobber13
When I had mine painted in 2005 I removed everything I could and the guy how painted it wouldn't paint it unless I removed the seals. Not that hard to do. Just take your time and you will be glad you did.
Charlie 85 244 TI B21FT 265K M46
dobber13 is offline   Reply With Quote
Old 07-23-2021, 11:00 AM   #15
cwdodson88
I’d remove it if I were to paint your car. Mt hood CC has a body tech school, might be worth a shot to have it done there. Just have them go for max mil thickness so it can be wet sanded and polished. If it were me, and I needed to fix a leaky seal to get through a few pdx winters before pulling the trigger on paint. I’d just do the seal now, and do all the seals again after paint. 3-5k for that roof sounds dead on with collision shops out here. Having a whole car jammed and sprayed out here is 15-20k.
Now if your not doing a color change, I wouldn’t worry about jamming it unless there’s issues. Block it out (20-30 hrs), epoxy sealer (8 hours), base (8-10) then drop it through the detailer for an 8 hour buff session. Something like 60 hours at 160/hr is what I’d expect plus 2-3k in paint.
The Build Thread
SVEA - PUSHROD TURBO!
Old 07-23-2021, 08:46 PM   #16
My car is fun hp club
Yes, you should remove the seal for the paint job. If you don't the seal is hard to tape over and it will cause edges on the paint that could easily chip and then it'll look bad. What I would do is instead of having the new seal installed. In the meantime cover the sunroof seal with some painters tape. Something that would be easily removable for the paint job. That should stop most of the water getting in. Then in a couple of years remove the tape and the seals and after paint you can put the new seals in.
Old 07-27-2021, 10:03 AM   #17
Alan29
Alan29's Avatar
Caulk it closed but make sure to use a paintable caulk as you wouldn't want it to look like **** after.
Seriously you need to remove it. It's very tight at the body line and there is no way to backtape it to extend the base and clear behind it like you could possibly do with a big fat windshield seal.
Signature.
Old 07-27-2021, 10:10 AM   #18
Yep got it, suck it up and just get it done properly.
