Old 07-22-2021, 07:47 PM   #1
Nickagriffin
Nickagriffin's Avatar
Default T5 Swap Gone Wrong
Hey all,
I recently did a T5 swap using a '93 WC T5 from a Mustang GT. I used the yoshifab kit and shimmed it as close as I could with the shims I got. It seemed fine at first, made noise, but I thought that was just the ****ty foxbody driveshaft I used.
After a few hundred miles it started to get really hard to put into gear, and 5th made more noise than other gears. This happened on the way to the dmv. I let it cool off and it seemed better for a second but then when I got off the highway it wasnt going into any gear and trying to move with the clutch out in neutral!
Something internal is really f'd up and I'm wondering if it could be my fault or just some bad facebook marketplace luck.
I'd really not like to go through this again
1992 240 Sedan Project Car
1988 245 Daily
@turbobricknick on instagram
Nickagriffin is offline   Reply With Quote
Old 07-22-2021, 08:16 PM   #2
J_Jones
J_Jones's Avatar
Now that you've vented, take it apart and have a look. Let us know what you find and we will be happy to help.
Old 07-22-2021, 08:16 PM   #3
cwdodson88
Sounds like a combination of issues. Pilot bearing siezed, and selectors keeping in in a gear. Does it have an aftermarket shifter?
The Build Thread
SVEA - PUSHROD TURBO!
Old 07-22-2021, 08:20 PM   #4
cwdodson88
They’re easy to pull apart. So this is what I’d do, pull it and start with tail housing and selector plate. I’d be looking at the shift rails/selector forks for the obvious stuck/broken/bent, then selector hubs and input shaft.
Old 07-22-2021, 08:33 PM   #5
Nickagriffin
Ok, I'll give it a try but won't really be sure what I'm looking at. Not familiar with trans internals at all. I did take it out of the car this evening and took a look at the input shaft, seemed normal to an untrained eye.
Old 07-22-2021, 08:34 PM   #6
Nickagriffin
Ok, thanks. I'll start pulling
Old 07-22-2021, 08:47 PM   #7
Nickagriffin
Yes, it has a PRO 5.0 shifter. Reached into the pilot bearing and it seemed to spin freely by hand
Old 07-22-2021, 09:10 PM   #8
culberro
culberro's Avatar
If it's ever been apart, it's pretty easy to mess up the shift keys/selector mechanism when installing the top plate. Or they could be bent/cracked.
Or the countershaft bearings are gone, and/or the thrust bearing on the input shaft it gone.
In for pics of carnage.
Before you pull the trans apart, try and run it through the gears by turning the input shaft and going through the gears. You'll be able to feel for bad bearings, and you can sort of feel what's going on with the shifting.
It gives you an idea of what you're getting into.
Old 07-22-2021, 10:10 PM   #9
OldCarNewTricks
OldCarNewTricks's Avatar
It's really easy to mess this stuff up. IOW, sounds like you may have got a bad trans off the FB marketplace. Good luck!!
OldCarNewTricks is offline   Reply With Quote
Old 07-22-2021, 11:03 PM   #10
carver
Involvoed
carver's Avatar
They are pretty easy to rebuild provided you have a 20 ton press. Check out the following vids, they will walk you though it.
carver is offline   Reply With Quote
Old 07-23-2021, 08:35 AM   #11
esmth
how is the juice, did it leak out slowly perhaps?
1991 244 LH2.4 M46 360k miles
Old 07-23-2021, 06:36 PM   #12
J_Jones
J_Jones's Avatar
I'm betting the problem is obvious once you take the trans out.
Old 07-23-2021, 08:23 PM   #13
Nickagriffin
The trans is out, just not apart. Still trying to find some time to take it apart.
