Old 01-14-2015, 05:45 PM   #76
Definitely referencing from the intake manifold. I did not expect that much of a delta in boost pressure at all. Alas, here we are.
Old 01-15-2015, 04:32 PM   #77
The Full Banana
not yet good enough
The Full Banana's Avatar
Originally Posted by harribert View Post
So setting boost is more of a pain than expected. Springs in both of my MBCs are too short/stiff...what a PITA. May be time to upgrade to an EBC.
Strange... I've never had any issue with either of the grainger valve MBC's I've used. Solid boost control, never an issue. Had it at 11psi for a while, now I've had it sitting at 14.5psi.
Mine is inline between the compressor housing and the wastegate actuator with about 2.5" of vacuum line on each end. Not saying it's "right", but it does and has worked well for me for years.
-Tom 1980 242 T5
Old 01-15-2015, 04:36 PM   #78
Figured that out. Boost is rock solid again!
Old 02-05-2015, 04:17 PM   #79
Cheap whatever water pump shat the bed. Found a pair of NOS Hepus.
Pretty sure my high idle issue has to do with old/worn/broken throttle body seals and old old old idle valve hoses. Engine bay is crying for a detail; it's disgusting.
Old 02-07-2015, 12:05 PM   #80
Got a few more things on the way. Kocksense module, an MS2v3 jumper harness from Lord_Athlon, NOS Hepu B21/23 water pumps, extra spark plugs, and some seals to attempt to cure the crappy idle quality that has plagued this car since day 1. The RSI cam is doing it no favors. Some more things I have picked up to make it a nicer thing to live with on a daily basis.
Old 02-07-2015, 12:42 PM   #81
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
I wasn't aware they stopped making them. I had no issues getting one a year ago
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 02-07-2015, 12:54 PM   #82
The B21 ones have nearly vanished.
Old 02-07-2015, 01:04 PM   #83
WindowsBreakerG4
That sucks maybe I should buy a spare for the 242 for down the road.
FCP still has them IPD is still failing. I'll find out if IMC still has them in stock
Old 02-07-2015, 01:13 PM   #84
I tried finding them in FCP but as far as I can tell they only carry OE or GMB...
EDIT: never mind, found it now. AutohausAZ has them for 10 bucks less a pop and with free shipping. Yay!
Old 02-07-2015, 02:56 PM   #85
cosbySweater
cosbySweater's Avatar
Your welcome
1995 Porsche 993
2013 VW Passat TDI
Old 02-07-2015, 03:06 PM   #86
Thanks
Old 02-07-2015, 04:53 PM   #87
Welp, couldn't wait to get them on. Really cleaned up the front end along with the headlights and grille. Also I realized I have no pics that highlight the axle being forward 18mm from stock and the wheels pushed out 25mm on each side. Also, cockpit shots. Waiting on an R-Sport cluster come May.
Old 02-07-2015, 06:00 PM   #88
Lord Tentacle
Anime Lord
Lord Tentacle's Avatar
needs more stick
Originally Posted by .:Sven:. View Post
Your not getting naked pics of my GF, and im getting a 3inch. Its settled
Tentacle Wagon-91 940; stuff including paddles and Holset etc... powered by Corn
Tentacle Sedan-08 S80 D5, Working 4C suspension, 40mpg and radar cruise....
recently crushed Volvo's
1990 244, 99 v70 t5, 98 v70 t5, 2002 s80 t6, 98 940s
Lord Tentacle is offline   Reply With Quote
Old 02-07-2015, 06:19 PM   #89
I know
Old 02-07-2015, 08:06 PM   #90
Duder
Comes with a free Frogurt
Duder's Avatar
The trans is a tragedy but otherwise it's looking good!
Does this car have 250 lb/in springs all around? If so I'm assuming it rides fairly plush and has decent travel with the short struts, amirite?
Old 02-07-2015, 08:24 PM   #91
250 lb/in springs up front with Monroe inserts and chopped sedan springs in the back with Suburban shocks. The rear is unsurprisingly much stiffer than the front. I do plan on getting some 175 lb rear springs on adjustable perches and some sort of a motorsport solution for the fronts. Maybe the revalved B6 bilsteins that RSI sells. It is definitely very comfortable for what it is. If the stars align and you end up going to Davis (and if I end up driving rather than flying...) you are more than welcome to give it a feel.
That said, 9" or 10" springs would be better as I do get coil bind if I'm pushing it hard on imperfect road surfaces. Only problem is wheel backspacing...I would have to run ET15 for my front wheels to clear the spring perches.
Old 02-07-2015, 10:12 PM   #92
oldschoolvolvo
oldschoolvolvo's Avatar
Euro side markers look great!
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 02-07-2015, 10:29 PM   #93
Stiggy Pop
Stiggy Pop's Avatar
5 panels, rounds, and Euro corners is the best light set up, in my unbiased opinion.
'79 242
943 pickup
Old 02-07-2015, 11:37 PM   #94
I would drop the rounds for early TV screens in a heartbeat I do love the five panel tails!
But yes, the euro corners brighten up the front end a great deal!
Old 02-08-2015, 08:50 AM   #95
Dammit
+8cm
I guess it is a case of you want the rare stuff- in the UK round headlights are vanishingly rare, so I always prefer the cars that have them.
The TV screen lights are what every car had here, pretty much.
Dammit is offline   Reply With Quote
Old 02-08-2015, 12:40 PM   #96
Chewy
Chewy's Avatar
what are the deets on the headlights? Looks good!
Originally Posted by alreadyupsidedown View Post
Just think of K-jet as an extremely complicated mechanical Rube-Goldberg carburetor.
Originally Posted by volvo240skunk37 View Post
Good God son, you're just a pile of fail.
A-A-Ron
Going away: 69 142 "Inga" Build Thread
Had: 80 242 "Elsa" Build Thread
Chewy is offline   Reply With Quote
Old 02-08-2015, 12:50 PM   #97
I am referring to the ones on 1980 and earlier build years, like the ones John R H has on his red 245. That said I am quite content with the current front end setup!
Here you go! http://m.summitracing.com/parts/sum-899250
Old 02-08-2015, 01:19 PM   #98
Lord_Athlon
300+ Clurb
Lord_Athlon's Avatar
Post a cutoff pic of the lights.
Where did you get that wheel?
Originally Posted by RvolvoR View Post
simple...just throw the redblock in the trash and install, well, almost anything modern
Yet Asher here went with...
Old 02-08-2015, 02:12 PM   #99
Will do.
Got the wheel barely used from someone rlse on here. Kinda wanting to get a Mod 7 or a Prototipo next...
Old 02-08-2015, 05:15 PM   #100
Lord_Athlon
300+ Clurb
Is it a real momo? I only ask because my brother had one and it snapped off while driving.
