Old 10-01-2020, 08:33 AM   #1
ogamer777
Loading...
ogamer777's Avatar
Default how to weld BNE adjustable strut mounts?
https://www.bneshop.com/collections/...e-strut-mounts
I want to be able to adjust these without having to the lower the whole strut assembly, so what exactly needs to be done to weld these? Please be as specific as possible
84 242 DL M46 212000Mi
82 244 GLT (15G) M46 243500Mi 23 Aug 2019
79 242 GT 1 of 600 Aussie RHD BW55 312223Km
83 245 TURBO M46 "117000Mi"
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
ogamer777 is offline   Reply With Quote
Old 10-01-2020, 11:20 AM   #2
cwdodson88
From this picture, it looks like the steel plates just sandwich the factory location after trimming the rolled lip flat. The adjustment is carried out from up top using those 4 small fasteners.
The Build Thread
SVEA - PUSHROD TURBO!
Old 10-01-2020, 11:41 AM   #3
Thats a decent pic, you probably want to rotate the plates a back a little more so you get more caster and camber gain with adjustment.
I prefer to have one of the outer paths going straight forwards and backward to have the ability to get more caster..
My advice is I would only be cutting if the factory sheet metal is restrictive to the alignment you want. Otherwise set the 4 bolts in approx the same left to right based on what you are trying to do and fine tune with the factory slots. Then there is no need to access the lower bolts unless you want a drastic change in your alignment.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 10-01-2020, 01:39 PM   #4
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Is that thing turbo or na
94 944 + lots of stuff http://forums.turbobricks.com/showthread.php?t=354303
Old 10-01-2020, 03:05 PM   #5
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
it is hybrid, it has spool, but no boost ;)
