Old 02-04-2021, 03:54 AM   #1
SkeTchy-MechAniC
SkeTchy-MechAniC's Avatar
Default Clutch options M47+flat flywheel
Goodmorning!
The ITB car will be getting a flat flywheel and needs a clutch setup. We've got a hardly used NA setup laying about that could be used but seriously starting to doubt if it's strong enough. The car will be setup as a streetable tracktoy. 2 rearends to chose from, an open 3.5 with sticky tires for track and welded 4.1 for drifting. While drifting it would be nice to be able to clutchkick it without destroying clutches or the freshly rebuild M47 The options would be the stock NA set to save the M47, B21ET Complete set, B21ET pressure plate with sintered clutch (4puck, 6puck, Suprung, Unsprung?)
So what would you guys do, We don't really enjoy pulling trannies so getting the right the first time would be great!
Never have i ever .... Seen a 242 with two motorcycles in the back
SkeTchy-MechAniC is offline   Reply With Quote
Old 02-04-2021, 01:07 PM   #2
culberro
culberro's Avatar
Pick your fuse: Clutch or transmission
My vote is stock NA setup or an organic disk with a higher clamp PP.
Old 02-05-2021, 07:45 AM   #3
Swedbrick
Swedbrick's Avatar
I currently am running the diesel plate with the higher pressure Sachs, it's rated to roughly 440nm as a fuse for my m90. It requires a bit of a leg workout but it's very streetable
For the m47 I'd opt for a turbo pp setup, should be plenty. Sinter plates eat transmissions I understood from my dad when he raced (1.8L klasse crosskevers)
Volvo 745 - IPD springs, 25mm/19mm swaybars, T-cam, LH2.4, M90 swap, 3.54 \w racingdiff lsd, track/daily
