Old 09-30-2020, 12:59 PM   #1
Bloody244
Default 240 B230f+t Dyno result
so i turboed my 87 240 unopened b230f 80k miles with a 19t its running 7.5 psi it has 118 whp in second gear and the dynograph dips at 4.5k to 5k but then pull to 6k like nothing happend and is so Rich that it wont go higher than 3.7k rpm in 3rd then it gets so rich they stopped the dyno run so it has orange top injectors 90+ manifold and the do88 bigpack intercooler its lh2.2 with ezk ignition. so how can i get it to run leaner? lambda is at .7 from 3.5k to 6k
Bloody244 is offline   Reply With Quote
Old 09-30-2020, 01:15 PM   #2
740atl
Gear acquisition syndrome
740atl's Avatar
Add more boost. 7psi is just a tease.
Old 09-30-2020, 01:26 PM   #3
Bloody244
so 14psi? its my daily so id like to have the rods inside the block
Old 09-30-2020, 01:38 PM   #4
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
are you using the turbo ECU and EZK?
Megasquirt Tuning!
Old 09-30-2020, 01:40 PM   #5
Bloody244
i am using the turbo ecu and ezk
Old 09-30-2020, 01:47 PM   #6
Beep beep zip tang
Check O2 sensor, FPR for leakage. If those are good, you can lean out the AMM by taking out the tamper plug and turning the adjuster to the left from what I remember for leaner.
Old 09-30-2020, 03:01 PM   #7
rb92673
Adding more boost isn't a solution if it is running super rich. You need to figure out why it is running rich.
Do you have access to a fuel pressure test kit to see what it is doing at idle and if fuel pressure goes up under boost?
Do you have all the correct LH 2.2 pieces such as AMM (007) and are there no boost leaks between the AMM and the intake?
Have you compared the look/color of the spark plugs to a chart to see if they have any clues?
I assume the orange tops are similar flow rate to the stock turbo green injectors?
Old 09-30-2020, 03:20 PM   #8
Bloody244
i dont have a pressure test kit
i have all the correct pieces
no boost leaks
spark plugs look normal
i dont know about the green vs orange flow rate
i will check the o2 sensor and the FPR then the AMM
Old 09-30-2020, 04:22 PM   #9
Beep beep zip tang
Also check the coolant sensor, best place to check is at the ecu, that way you can make sure your wiring is good too.
Old 09-30-2020, 07:35 PM   #10
KwikBrik245
KwikBrik245's Avatar
Well ****. I just learned my new thing for the day. Never thought to check in such a convenient location hahaha
Daily: '91 245, B230F/M46 P-type, '93 Dana 30
'88 744, Twin Turbo LS1/T56, Grizzly locked Dana 30.
KwikBrik245 is offline   Reply With Quote
Old 10-01-2020, 08:05 AM   #11
linuxman51
linuxman51's Avatar
post a pic of the plugs if you've got one
Old 10-01-2020, 02:56 PM   #12
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
likely boost leak.. just saying.. check the idle hoses... or bad maf..
Threads like this continue to underline the fact that none of yall are ever actually going to catch me.
90 245GL 2JSWEDE 2JZ 245...
91 245GL Team Battle Wagon Chumpcar
93 245GL Street Beater
RoadRacer4Life is offline   Reply With Quote
Old 10-02-2020, 01:13 PM   #13
Bloody244
the 02 sensor wire to the ecu was damaged only the insulation held the wire together also will a 9mm rod stock b230f hold 14 psi or what is safe and how much whp is the max i can safely have i have to race a mk7 gti 230hp dsg
Old 10-02-2020, 03:15 PM   #14
shoestring
shoestring's Avatar
Well this just took a turn
Old 10-02-2020, 05:20 PM   #15
14 psi can be safe as long as your car is setup and tuned correctly.
Have a ****ed up tune or boost leaks or flaky other components.
BAH BYE
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 10-02-2020, 06:14 PM   #16
Cwazywazy
Single jingle
Cwazywazy's Avatar
I wouldn't feel bad about shoving 16 or 17psi through a skinny rod motor if it was running right. Probably still wouldn't beat a GTI though.
I don't know what I have
Old 10-03-2020, 05:32 AM   #17
Bloody244
a v16t Cam And aw71 With 15 Psi ist that closer to beating a gti
Old 10-03-2020, 06:54 AM   #18
Beep beep zip tang
Probably not, is there money, pink's or just pride on the line here?
Old 10-03-2020, 07:47 AM   #19
poulrais
poulrais's Avatar
Only way you're going to beat that GTI is if your pour sugar in his gas tank...
1990, Volvo 740 16v +T
Old 10-03-2020, 08:13 AM   #20
Bloody244
He is willing to do pinks But i only want to Race for 500
Old 10-03-2020, 10:35 AM   #21
shoestring
shoestring's Avatar
If he's willing to do pinks he knows something you don't know.
Old 10-03-2020, 11:20 AM   #22
Bloody244
nah i know that the gti is stock the guy doesnt want to get his hands dirty or break the car
Old 10-03-2020, 03:28 PM   #23
JW240
All idiot, no savant
0-100km/h for a stock Golf 7 GTI is 6,4 seconds (according to my Google skills). Very good response with the DSG etc, don't underestimate it.
If your 240 isn't overly heavy and have some basic mods to your +T it should get similar times to 100 km/h. Think a proper exhaust and making sure it just runs as it should. The DO88 intercooler is a nice touch and helps for sure.
The main bottleneck is the stock turbo. Luckily you can swap FWD mitsu turbo's that look completely stock (for TüV) if you want, though you can get much better turbo's for the same $ but they need more mods to fot them. My 245 +T with a T3 at 7-8PSI is below 6 seconds 0-100kmh and it is a very very basic setup, nothing special and many things that can be improved. Close to 100K on the +T and it runs like the first day, don't worry too much about the engine.
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 10-03-2020, 05:17 PM   #24
Bloody244
so install a wideband, boost bout 15psi v16t cam do88 intercooler 102 octane fuel lets see when i register the car if he still wants to race me he thinks mine only has 170hp but thats a stock b230f and 7.5 psi
Old 10-03-2020, 06:26 PM   #25
Beep beep zip tang
I would have a backup plan for transportation if you're racing for pinks
