Old 04-28-2021, 10:35 PM   #1
Jack
junkman
Jack's Avatar
Default Crusty turbo hot side turbine —- how to clean ?
Doing a turbo rebuild
Looking for suggestions on what to use on the hot side turbine. I used brass bristle dermal before it was ok
Any chemical that will loosen that crud up?
I love you even more Jack.
Old 04-29-2021, 02:19 AM   #2
Jack
junkman
Jack's Avatar
Try dyi soda blaster
Old 04-29-2021, 02:20 AM   #3
Jack
junkman
Jack's Avatar
Good idea
Old 04-29-2021, 02:57 AM   #4
Otto Mattik
board member
Otto Mattik's Avatar
Good idea
'Chinese water Torture" (Sea Foam) ?
Old 04-29-2021, 01:16 PM   #5
OttoB
I'm dipping my stuff in citric acid. 10% mixture with water. Nice stuff.
Old 04-29-2021, 01:25 PM   #6
If you have a gas powered pressure washer, or a GOOD electric one, there are some liquid media blasting kits. This is what I'd use, ghetto vapor honing.
https://www.eastwood.com/liquid-medi...UaAo9sEALw_wcB
https://www.amazon.com/Selkie-Pressu...a-900488581190
Old 04-29-2021, 01:26 PM   #7
PCH
Evapo-Rust. Have not done any turbine housings but couple exhaust manifolds. Harbor Freight has it or you can order online cheaper.
Old 04-29-2021, 01:31 PM   #8
Evapo Rust is legit.
Old 04-29-2021, 02:20 PM   #9
Acke
Acke's Avatar
This (+heat to speed the process up) or sandblasting. Phosphoric acid is also nice, but I don't have experience with it on parts that have endure more heat.
e: Whoops. I was also thinking hot side housing, not turbine...
Last edited by Acke; 05-01-2021 at 02:48 PM.. Reason: Didn't read the question carefully.
Acke is offline   Reply With Quote
Old 04-29-2021, 08:01 PM   #10
Brontes II
+1 for Evapo-Rust. It's reusable and has a long shelf-life, so it's nice to have around for general purpose rust removal chores. Soaking old hardware, brackets, etc. Krud Kutter is good stuff too. But it's more expensive than Evapo-Rust. And I don't think you can store and re-use it over and over again.
That said, if you really want to do it right (and don't want to do any scrubbing): 1 hour submerged in muriatic acid will probably make it look like new. Just keep an eye on it because it'll go after good metal once all the rust is gone.
Newbie Lurker Since Oct 2007
Brontes II is offline   Reply With Quote
Old 04-29-2021, 08:35 PM   #11
Jack
junkman
Jack's Avatar
Interesting on citric acid, have you used it on exhaust turbines?
I have access to a 25x10ft blasting room… but sand would I be too rough IMO …( we actually use iron media) http://turbobricks.com/forums/showpo...7&postcount=24
Gas powered pressure washer from Costco ftw here … I use it almost daily for the last few years
But it’s not rust. I have used evapo rust many times
Those would be too abrasive
I’m sticking to my soda blasting because the turbine wheel is so delicate
Old 04-30-2021, 05:28 AM   #12
OttoB
Sorry Jack, didn't read your topic carefully. I was thinking turbine housing.
For turbine, try owen cleaner?
Old 04-30-2021, 06:45 PM   #13
HRPufNStuf
HRPufNStuf's Avatar
I use a glass bead blaster but tape over the shaft.
Then a light coat of oil till Im ready to put it together.
Patrick
HRPufNStuf is offline   Reply With Quote
Old 08-05-2021, 12:54 PM   #14
PCH
So what did you end up using and to what result? I want to clean the exhaust wheel on a 16T I just picked up. Soak the blades in oven cleaner? Evapo-Rust didn't do anything to the baked on deposits.
Old 08-05-2021, 01:11 PM   #15
Duder
Comes with a free Frogurt
Duder's Avatar
Jack, were you asking about the turbine wheel (not housing)? Glass bead blasting is the way to go as HRPufNStuf said above.
We use glass bead blasting on our fancy racing turbo rebuilds here at work. You do have to be very careful with the shaft. Mask it very securely starting where it necks down just under the larger hub behind the turbine wheel. The hub (with piston ring groove) can be blasted clean. But you don't want the beads to touch the bearing journals at all.
Old 08-09-2021, 07:33 AM   #16
white855T
Nothing really works except sand blasting/bead blasting. Takes about 1 min to get it clean. I don't blast the compressor wheel(I soaked that in Berryman chem dip for a day). I've been sucessful in cleaning the turbine housing with the smallest wire wheel you can find for a drill or a die grinder.
