Old 02-08-2021, 02:56 PM   #2326
EFbI4
EFbI4's Avatar
Finally I'm tryed to live tune LH ECU and... There is something wrong basically.
I disable lambda regulation, upload my firmware, adjust AFR on idle, low loads and high load. But how to adjust medium loads? I can't find a good recipe for it. Maybe you there can give me some advices?
In TunerPro I can't find a logging for RPM/LOAD table (mail fuel map) and I have no idea how to log tracing (and as we know trace is slow and sometime wrong).
- Custom Jetronic chips (faster than you try before)
- TPS adapter plates (for ECU conversion)
- Megasquirt 2 cheap custom build
- AW71 shift kit
- 46/38 valves for 530/531 head
PM me!
EFbI4 is offline   Reply With Quote
Old 02-09-2021, 03:52 AM   #2327
mrjaybeeze
Team Jetronic.info
Hi
LH can absolutely not be "live tuned" per se !
You can actually fry the ECU by changing parameters with engine running.
It is not possible to log the tracing in Tunerpro until someone makes a plugin for that.
Tuning of medium loads is same as all other LH tuning, it is primarily done in the main fuelmap.
YS
Jaybee
ipdown.net/jetronic.info/tiki-index.php
Site open in "lame mode"
If you have some issues
just send me a message
mrjaybeeze is offline   Reply With Quote
Old 02-09-2021, 01:12 PM   #2328
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Perhaps I'm misunderstanding, but I've been able to live tune using the Ostrich, and upload the tune to the ostrich while the engine is running.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-09-2021, 01:15 PM   #2329
esmth
I have been able to do it most of the time too, but 0.01% of the time the car will royally **** itself and flood or crash the computer or go into weird unknown states. I don't do it anymore
1991 244 LH2.4 M46 360k miles
Old 02-09-2021, 01:37 PM   #2330
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
I've had it crash the ECU but not anything weirder than that.
I sell chips for LH 2.4!
Old 02-11-2021, 09:14 AM   #2331
sUbZeRo_DE
Just a quick Update!
Sometimes things are not as they seem... I found the Issue. The FPR was faulty and it pumped fuel right in the Intake... Fixed that, and now it is running like it should! Thank you all!
And yes TÜV is only once all 2 years =)
sUbZeRo_DE is offline   Reply With Quote
Old 03-02-2021, 04:33 PM   #2332
Swedbrick
Swedbrick's Avatar
Finally got my junk on the dyno, using kyle's (klr142) every day mapping as part of the setup, in a later bin file with the e-fan compatibility. I also updated to include the later lambda constants, as I made a comparison sheet for those. The tune got put in a 984 casing and ran on the dyno for a cool 135whp@190Nm. 1500-2000 rpm needs some sorting, possibly some idle enrichment deal that could be improved, in general I'm happy.
To repeat a small summary of the setup for reference:
10.3:1 b230k with stock 530 head
kg004 aka k camshaft
buchka wasted spark
218cc ev6 injectors
bigger J-pipe with turbo exhaust system
Chipped lh2.4 (own tune)
Old 04-03-2021, 12:41 PM   #2333
EFbI4
EFbI4's Avatar
Anyone has 597 and 578 xdf? Ipdown is down and don't take a chance to download. ASAP!
Old 04-03-2021, 01:33 PM   #2334
^^^ seems OK now: https://ipdown.net/jetronic.info/tik...Id=13&offset=0
Old 04-06-2021, 08:55 AM   #2335
esmth
his website has been up and down a ton recently. definitely make a backup of the bins/xdfs. The jetronic part his site is borked right now but the rest of it works. The cert is about to expire as well.
Old 07-15-2021, 02:28 PM   #2336
midnight_man
Have anybody files from author of this topic? I have almost same car and want to play with ecu little... thanks!
midnight_man is offline   Reply With Quote
Old 07-16-2021, 02:32 PM   #2337
Swedbrick
Swedbrick's Avatar
If your referring to beepee, this is an old thread, he might not check as often any more. Jetronic.info appears to be down permanently, but if you tell me which ECU you have I might be able to provide on of the xdf files for looking at your bin.
Do you have a chip burner/ostrich to play around with stuff? Getting a wideband is also a good idea, given the nature of tuning on a old ECU that is partly understood
Old 07-16-2021, 03:54 PM   #2338
midnight_man
Yeah I am working with race cars and tuning softwares I have ostrich, cobra RTP...licensed tunerpro...all what is need.
Old 07-16-2021, 06:50 PM   #2339
Swedbrick
Swedbrick's Avatar
What car are you trying to tune, turbo/na, 8v/16v? There's heaps of subtile differences between ecu's and thus their memory locations so there is not a generic thing file that will work
Old 07-18-2021, 12:49 PM   #2340
michask
Folks, as jetronic.info and the mirror on ipdown are n/a...can anybody help me out with some BIN and XDF Files for having fun with ostrich and tunerpro?
michask is offline   Reply With Quote
Old 07-19-2021, 06:24 AM   #2341
midnight_man
guys where I can found bins for:
0280 000 549 or
0280 000 562 or
0280 000 571
thanks!
Old 07-19-2021, 08:54 AM   #2342
Swedbrick
Swedbrick's Avatar
Originally Posted by klr142 View Post
As promised, here's the 933 XDF v.50 attached amongst a bunch of other stuff I'm going to add to my NA tuning how-to thread. I also included my 951 BIN and notes from it stating what the setup is for fun if you'd like to see it.
This post a bit back in this thread should have a similar xdf, that will work with some tweaking;)
Old 07-31-2021, 07:00 PM   #2343
klr142
Turbo, what?
klr142's Avatar
https://i.imgur.com/jg3AhOYl.png
buchka wasted spark
218cc ev6 injectors
Awesome!! Congrats and nice work! I’m glad it’s been a decent starting point for you and you got it on the dyno. Do you have a chart that shows the air/fuel ratio as well?
The low rpm stuff is tricky, for sure. Some of the problems there have to do with airflow through the intake and exhaust. I have Lambda feedback turned back on in my 244 so it helps with it from going super rich in my car under 2000rpm near full throttle.
Old 07-31-2021, 07:03 PM   #2344
klr142
Turbo, what?
klr142's Avatar
0280 000 549 or
0280 000 562 or
0280 000 571
thanks!
Those are 16V computers, correct? I think I have some bin files(if they’re not already in the attachment I posted previously that Swedbrick mentioned), but I don’t have any XDFs to actually tune them. Let me know if you still want something and I’ll see if I can dig them up.
I do have a bunch of bins and xdfs saved on my computers but they’re mostly for 8V n/a applications.
Old 08-02-2021, 06:25 AM   #2345
Swedbrick
Swedbrick's Avatar
Thumbs down
Unfortunately no air fuel on this run, I still had not replaced the S shaped exhaust tip, so we couldn't get the lambda installed. The engine is now going to be living on in a local rally 142, so with a bit of luck it might see the Dyno again when I can be there.
Old 08-05-2021, 06:38 PM   #2346
klr142
Turbo, what?
klr142's Avatar
0280 000 549 or
0280 000 562 or
0280 000 571
thanks!
I have a 562 and 954 bin as well as a basic 954 xdf attached. I don't have a bin file for the other two ECUs and no xdf for any of them.
Old 08-09-2021, 01:08 PM   #2347
michask
Great, thank you!
Old 08-30-2021, 03:05 AM   #2348
mrjaybeeze
Team Jetronic.info
Hi all
Vlad has upgraded the Jetronic site so things should work again :-)
New URL: https://jetronic.ipdown.net/tiki-ind...?page=HomePage
YS
JB
Old 08-31-2021, 07:52 PM   #2349
Great, glad that the Jetronic site and all the bins/xdfs are back.
From the home page:
News:Dec 2018
During 2018 there have been good communication with a former Volvo development engineer and several myths and other lore regarding EZK and LH has been busted.
That's very interesting -- is there a write-up somewhere of what was learned?
TIA,
Bob
