Old 12-05-2020, 10:50 AM   #1
Mazazish
Question Ecu
Hello guys, im new here, so i finally make a account here
So i have some questions about Ecus what u use, i have a garret t03/t04 replica turbo, and siemens 687cc injectors, ecu is standart with chip, but its not running good!
Myb someone can help, and give some info.
And sorry for my english guys
Mazazish is offline   Reply With Quote
Old 12-05-2020, 01:45 PM   #2
Jussi Alanko
Could you reconsider to change to an aftermarket ECU, example microsquirt or similar???
Jussi Alanko is offline   Reply With Quote
Old 12-05-2020, 02:42 PM   #3
sbabbs
sbabbs's Avatar
THe stock turbo lh2.4 cars the injector size must match the AMM size or you need to change the injector constant in the ECU bin program to match up.
If your running gasoline 550cc injectors match up good with 3 inch AMM and stock injector constants. Maybe make your AMM size 3.5 inches to match the 687cc injectors. But 3 might work.
I know 750cc injectors and 3 inch AMM work good with E85 fuel.
Or try a modified bin for those sized injectors, let me see what I got here..
Try this in 967 or 954 or similar ECU. Might not work in 984 ecu cause immobilizer.
Old 12-05-2020, 06:35 PM   #4
WillettRun?
†John3:16
WillettRun?'s Avatar
I make an LH 2.4 MaxxECU Mini plug and play.
I still love Jesus and He still loves me.
MaxxECU Dealer/Tuner
WillettRun Automotive, LLC
WillettRun? is offline   Reply With Quote
Old 12-07-2020, 09:48 AM   #5
Mazazish
I have 3 inch AMM, thr problem is, when i driving and take out from gear, engines shuts off, when i start it again, everything runs good, previous owner said, myb ecu trys to correct AFR, thats why this happen, and he never solved this problem, in my ming easier is to change ecu to programming, myb this solvs problem, and engine works better
Old 12-07-2020, 09:49 AM   #6
Mazazish
Maxx ecu sounds good, but they are very expensive, i get info something for 200€ can buy new one
Old 12-07-2020, 12:13 PM   #7
Mazazish
Yes,im reading about megasquirt, thats also are good
