Old 12-30-2020, 02:11 PM   #1
sideways242
Default Microsquirt PWM idle valve wiring
Hey y’all,
So here’s my weird question... When wiring a Volvo 940 Bosch 2-wire IAC to a microsquirt, does one need to include a 1N4001 diode in order to get things to respond in a normal fashion? Ive tried three different IAC’s out of the car and they all respond the same. When using the IAC test mode output in tunerstudio they clatter around and only open from the values 80-95% intermittently...makes tuning WUE on a cold start a real pain. Anyone got any experience with microsquirt and idle valve wiring?
Any input would be awesome, Cheers!
sideways242 is offline   Reply With Quote
Old 12-30-2020, 09:26 PM   #2
sideways242
solution found! Microsquirt requires a diode (1n4001) to be soldered into the two wires with the banded side to the 12 signal wire. The pwm 2 wire valve now works as it should and cold start tuning is possible!
Old 12-31-2020, 02:35 AM   #3
culberro
culberro's Avatar
Gotta like the "recommended" diode on page 32. I bet this is the reason I could never get the IAC to behave properly.
(no virus)https://www.google.com/url?sa=i&url=...AAAAAdAAAAABAa
Old 01-06-2021, 09:18 AM   #4
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
yeah it needs that. I've gotten them to work without it, but they work a lot better with it.
Megasquirt Tuning!
Old 01-06-2021, 09:32 AM   #5
Beep beep zip tang
I gave up and plumbed the k- jet thermo valve in. It doesn't seem to work either though, maybe I need to try another one.
Old 01-10-2021, 09:23 AM   #6
WillettRun?
†John3:16
WillettRun?'s Avatar
1n4001 diode. Freq 100-120, duty about 25min 60 max. Use open loop to find the min/max and then set your closed loop accordingly. Make sure to use idle initial value x CLT and idle spark advance as well to help control surges.
I still love Jesus and He still loves me.
MaxxECU Dealer/Tuner
WillettRun Automotive, LLC
WillettRun? is offline   Reply With Quote
Old 01-10-2021, 03:54 PM   #7
OttoB
Diode lives easy happy life in connectors rubber boot.
