Old 05-05-2021, 09:04 PM   #1
spock345
spock345's Avatar
Default J type output flange compatibility
I've got an M410 with the larger output flange on the overdrive and a smaller flange on the driveshaft half I found.
Can I swap the flange from the M40 currently sitting in my car or do I need to find another flange?
1998 S70, grandma-mobile
Old 05-05-2021, 09:05 PM   #2
No it's different.
how psi stock cna sprout?
Old 05-05-2021, 09:31 PM   #3
spock345
spock345's Avatar
No it's different.
Damn
Old 05-05-2021, 11:11 PM   #4
Originally Posted by spock345 View Post
Damn
You need a 3.5" le-cock-de-norman-villan OD output flange.
The fixing nut is 1 & 1/8" btw.
Old 05-05-2021, 11:35 PM   #5
planetman
planetman's Avatar
And it has to come from a "J" overdrive. A flange from a "D " overdrive won't work.
We do have a used "J" output flange if needed.
New ones are still available, but they ain't cheap!!
Eric
Torrance, CA 90502
Old 05-06-2021, 01:15 AM   #6
OttoB
There might be short cut, a joint with different size caps. Think they are called "conversion joints".
Old 05-06-2021, 02:18 AM   #7
carver
Involvoed
carver's Avatar
I think i have a small flange from a j type somewhere in my stash. Let me know if you need it.
carver is offline   Reply With Quote
