Old 05-21-2021, 08:12 PM   #1
BeaverMeat
BeaverMeat's Avatar
Default Fuel flowing back into tank after shutdown
Don’t know if it’s the return line or what but, when it shuts down I can hear fuel flowing back into the tank.
Pressure regulator, pump or check valve?
She’s built like a steakhouse but, she handles like a bistro.
Old 05-21-2021, 08:20 PM   #2
apachechef
Burnt Sierra Madre
consider normal operation
Dammit, Lummert.
Old 05-21-2021, 08:25 PM   #3
BeaverMeat
BeaverMeat's Avatar
Never did it before...
Old 05-21-2021, 09:05 PM   #4
cosbySweater
cosbySweater's Avatar
What pumps are you using?
1995 Porsche 993
2013 VW Passat TDI
cosbySweater is online now   Reply With Quote
Old 05-21-2021, 09:09 PM   #5
BeaverMeat
BeaverMeat's Avatar
OE fuel (external) pump. Oh... the engine is a 302EFI with a vacuum operated fuel pressure regulator.
Old 05-21-2021, 09:27 PM   #6
TestPoint
TestPoint's Avatar
Gee, that is an interesting piece of information.
Ford V8 Conversion Manual -
Old 05-21-2021, 09:45 PM   #7
BeaverMeat
BeaverMeat's Avatar
What?
It’s just the regular ‘81 vintage type external fuel pump. Or the was it the pressure regulator? Still learning the ins-and-outs of this thing.
Perhaps it’s normal and I never noticed it before? The return line emptying out? I thought the whole system should be pressured.
Old 05-21-2021, 10:11 PM   #8
2 old for this
Oe pumps have a check valve which keeps the system pressurized
Old 05-21-2021, 10:58 PM   #9
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Originally Posted by BeaverMeat View Post
What?
81 K-jet cars had a pulse damper mounted on the bracket underneath next to the main (external) pump. The (control) pressure regulator was mounted under the intake
Old 05-21-2021, 11:18 PM   #10
BeaverMeat
BeaverMeat's Avatar
Well. This is a 5.0L swapped car where the Diesel fuel components were swapped for gas ones. I’ll check if there is even a check valve.
Other cause could be a faulty regulator/vacuum leak.
I’m starting think this may actually be the problem with my misfire issues
Old 05-22-2021, 05:11 PM   #11
My car is fun hp club
It's normal to have fuel emptying to the tank after shutdown. The check valve slows down the decay of fuel pressure for easier hot starting. But it's normal for the system to empty out after shutdown. it just should take awhile like about 20 minutes to a half hour. It's called the rest pressure in a kjet system.
Old 05-22-2021, 05:50 PM   #12
BeaverMeat
BeaverMeat's Avatar
Yup. It flows back immediately after shutdown and there is zero pressure in the line.
Old 05-23-2021, 07:31 PM   #13
gsellstr
gsellstr's Avatar
Think about this for a minute guys.
The check valve is on the pressure side, the outlet of the pump.
The fuel pressure regulator determines how much fuel is returned to the tank, after fuel has run thru the rail.
There's no restriction on the return line to the tank once fuel leaves the regulator, never was, shouldn't be in this setup.
There's no way to have pressure in the return line without a restriction.
If the PRESSURE side is losing pressure, that's a different story. A quick check of fuel pressure with the engine running, then shut it off, see what happens will tell you if there's an issue on the pressure side.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 05-25-2021, 12:59 PM   #14
Just to clarify what I wrote. The fuel pressure decay after shut down is slowed down by the check valve in the fuel pump. This is happening in the area between the fuel pump and the fuel pressure regulator. However, as Gary wrote, the fuel system after the regulator has now restriction so it will empty out quickly after shutdown.
Old 05-27-2021, 01:12 PM   #15
BeaverMeat
BeaverMeat's Avatar
I did the complete Fox 5.0 pulsing idle/3000rpm+ check list and ran the codes. Got a code 67 and 95.
67 is the neutral safety switch (which isn’t connected). Code 95 which is “fuel pump secondary circuit” fuel pump error. Meaning the relay didn’t kick-in the pump when the ECU told it to do so.
The car uses the Ford pump relay to run the Volvo duel pumps. So... I don’t know if it’s the swap that throws the code or of the ECU is doing it’s job.
The car primes as it should... I can hear the line pump. Perhaps my tank pump isn’t working and is throwing the code.
