Old 01-02-2018, 02:49 PM   #1
dkrause
Default Alternant Steering Racks for Quicker Steering?
I would like to replace the stock 240 power steering rack with a quicker rack e.g. less than 3.0 turns (prefer 2.5) L to L with a stock rack from a different car (PnP special). I can make mods to accommodate alternate mounting brackets if required.
I have found custom aftermarket units but the $$ are a bit much.
What make, model and year might fit our Volvo's?
dkrause is offline   Reply With Quote
Old 01-02-2018, 03:00 PM   #2
pat244ti
pat244ti's Avatar
XR4Ti racks fit with modification.
Sellholm sells the guts to convert a ZF manual rack to quick steer, but good luck sourcing a core.
We used a steering quickener in conjunction with the stock rack on my rally car
- Patrick
83 244ti - rally
73 1800es - resto mod cruiser
83 244ti - road race
79 262c - road race in the works
08 c30 T5 - daily recce car - M66, Lifted 1.5'', 215/65/16 Falken All Terrains on Method MR502's, iPD skid plate
97 Dodge Dakota 5.2 4x4
70 Ford F100 2WD 351M/C6
pat244ti is offline   Reply With Quote
Old 01-02-2018, 03:44 PM   #3
dkrause
What ratio of quickener do you use?
Old 01-02-2018, 03:52 PM   #4
tjanson
tjanson's Avatar
You can also get BNE / Kaplhenke roll correction ball joint holders to speed up the steering, but car should be lowered 1.5-2" for correct steering geometry.
1993 245 DL; LH2.4, M47 - DD & Winter Beater
1978 242 GT - To Be Restored, someday
1993 245 DL - OEM+ Project
tjanson is offline   Reply With Quote
Old 01-02-2018, 03:53 PM   #5
pat244ti
pat244ti's Avatar
I'm using a 1.5:1 but 2:1 is fine
Old 01-02-2018, 04:50 PM   #6
2:1 is fun.
Old 01-02-2018, 04:50 PM   #7
A hydraulic quick rack from Sellholm is ~$1k if you want the fancy stuff.
Old 01-05-2018, 07:35 AM   #8
DET17
Reformed SAABaholic
The lowest cost solution.... but as stated, don't use UNLESS lowered (roll center).
Old 01-05-2018, 01:19 PM   #9
You can drop a quickener in place of the steering shaft in the engine bay. Probably $175 in parts and a half days work.
I'd also be curious as to how a car handles with the ball joint dropped that far and at stock ride height. Anyone done this?
Old 01-07-2018, 06:54 PM   #10
euro-trash97
euro-trash97's Avatar
Get the keplhenke roll center correctors, work great and easy to install.
Originally Posted by Captain Bondo View Post
If by "can't drive a manual", you mean "refuse to drive like a pussy", then yeah, I can't drive for sh8t.
euro-trash97 is offline   Reply With Quote
Old 01-08-2018, 01:05 AM   #11
940wagon
Many people including me drive with stock arms and what not in the front end with a 3" extended strut on 2/7/9 series without any real noticeable negative effects with daily/normal street driving. I'd imagine the effects of the QSRC on a stock ride height car would be the same, but I'm far from an expert on suspension geometry. Probably notice it on a track/rally car.
940wagon is offline   Reply With Quote
Old 01-08-2018, 07:31 AM   #12
DET17
Reformed SAABaholic
I'm curious about this device.... please link into this thread.
Kaplhenke states in his product description, NOT to use unless with lowered vehicles (I think he said 30-45mm, but I've not studied it lately).
If the OP wants stock ride height, then the QSRCs are not the answer.
Old 01-08-2018, 03:08 PM   #13
dkrause
This is for our race car, I have the Kaplhenke roll correctors and the car is lowered. They work fantastic to provide proper geometry and bump steer correction. Using the shorter holes do cause some angularity errors versus the stock location, therefore that's why I am looking for a better rack.
These roll correctors are designed to return the steering geometry to the ideal case when lowered and would only screw up a high (stock) ride car.
Old 01-08-2018, 03:11 PM   #14
dkrause
Thanks, looks like a XR4Ti power rack is available at a reasonable price from remanufacturers too.
Old 01-08-2018, 04:37 PM   #15
GTJordan
Been here for too long
GTJordan's Avatar
Dkrause? SlowVo?
Old 01-08-2018, 04:48 PM   #16
John V, outside agitator
You're welcome.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 01-08-2018, 04:48 PM   #17
https://www.summitracing.com/search/...ng%20quickener
Old 01-08-2018, 04:51 PM   #18
tjanson
tjanson's Avatar
Here's a rally anarchy thread on putting the xratty rack in a 240. Poster made some progress but then bought a X4RTi to rally instead. Seems like there some unresolved length issues on actual rack (ie the moving piece) and/or the housing.
Rally anarchy thread
I'm tempted to buy one just to try and figure something out...
Edit: Any known completed swaps? John?
Old 01-08-2018, 05:05 PM   #19
tjanson
tjanson's Avatar
Here's a tbricks thread 'bout the Xratty rack from 2014. No definitive answers there either.
Old 01-08-2018, 05:09 PM   #20
I wouldn't recommend the QSRC for cars that aren't lowered.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 01-09-2018, 06:21 AM   #21
dkrause
Originally Posted by GTJordan View Post
Dkrause? SlowVo?
yup
