Old 02-08-2020, 04:14 PM   #1
dkrause
Default B234 - 16 valve revs?
What is the factory redline for a 234 - 16 valve engine?
For those with built 16v engines what RPM limits are you using (based on usable power) both Turbo and NA? I am planning a project and looking at transmission and rear end ratio's now. Thanks
dkrause is offline   Reply With Quote
Old 02-08-2020, 05:29 PM   #2
GTJordan
Been here for too long
GTJordan's Avatar
For the SloVO?!
Old 02-09-2020, 12:24 AM   #3
dkrause
Originally Posted by GTJordan View Post
For the SloVO?!
I was thinking you would lend me your motor for Slovo
Old 02-09-2020, 12:45 AM   #4
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
it's relative to a number of things. stock intake manifold? I probably wouldn't turn it up much past 7k cause it's already choking at that point.
Currently I turn the gold car out to about 8100 or so. may experiment with raising that number, because the power keeps going up.. but... it's not exactly stock either.
Megasquirt Tuning!
Old 02-13-2020, 05:32 PM   #5
poulrais
poulrais's Avatar
Understatement of the year?
1990, Volvo 740 16v +T
Old 02-13-2020, 05:37 PM   #6
JohnMc
JohnMc's Avatar
I think you'd probably want some stiffer springs if you want to go much above the stock redline.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 02-13-2020, 05:42 PM   #7
culberro
culberro's Avatar
With some mild NA cams and slightly stiffer valve springs they willingly rev past 8k without any issues. I never used a completely stock intake, so I can’t comment on the choke point on that.
I know Harlard is looking to go to about 8500 rpm with his 16v turbo, as it just keeps making power as Kenny mentioned.
Old 02-13-2020, 05:43 PM   #8
JohnMc
JohnMc's Avatar
Do you have a dogdish flywheel? Lol.
Old 02-13-2020, 07:39 PM   #9
Another issue with revs much above about 7.5k or so is gonna be the accessories. The water pump, power steering don't like being revved too high all the time.
Old 02-13-2020, 07:45 PM   #10
culberro
culberro's Avatar
100% correct. If the engine is going to see sustained revs over ~5k, then an underdrive crank pulley is needed. Your PS pump will thank you.
Old 02-20-2020, 10:09 AM   #11
linuxman51
linuxman51's Avatar
it's just got manifolds, intercooler, turbo, cams, springs, retainers, 'street port' job on the head, and H-beam stock replacement rods... it's still got OEM NA pistons and all that. Your big limiter to turning rpms is the relatively awful intake manifold and restrictive port inlet on the head.. you can open up (on the car head) just the first couple of inches before the divider and probably pick up a fairly significant amount of flow potential without really greatly changing how it behaves. I've turned stock cams past 7k with just springs and a better intake coupled with that level of "porting" (really more like gasket matching to a larger runner intake manifold) and they don't fall off nearly as bad.. this was on a turbo car though, so YMMV I reckon
oh yeah, don't have PS on the gold car. This, and the alleged water pump cavitation situation should be considered if one is going to be roadracing at high rpms
Old 02-24-2020, 12:40 PM   #12
klr142
Turbo, what?
klr142's Avatar
The factory redline is 6500rpm from what I remember. We ran one in the General Leif a couple years and I expect we ran it up to 6800. It was all stock with a shortened intake manifold and removed balance shafts. People have said that the stock valve springs aren't good for anything other than stock revs and camshafts.
The stock bottom end, once balanced, is fine to higher rpm. Erland says he recommends a 7,000rpm max for the stock balancer. We are keeping our cap at 7,000rpm with the 8V now as we don't want to run into issues with the lightened factory harmonic balancer, valvetrain, transmission and/or water pump. Hah
