Old 11-26-2020, 11:58 AM   #1
spock345
spock345's Avatar
Default Differences between B18D versions
Does anyone know the difference between the 95hp and 100hp B18D motors? I have tried looking through the spec sheets and I am not sure what the difference is.
Is it a dual port exhaust manifold over the single port? Different needle in the SUs?
1967 122s, B20F, M40
Old 11-26-2020, 01:38 PM   #2
c1800
I think it’s a cam change.
AFAIK, the dual port exhaust manifold on B18’s only came on the B18B, for the 1800 series, and the 123GT.
http://www.volvoamazonpictures.se/po...powertrain.php
As I recall the early P1800 with B18B motor was 100hp.
Old 11-26-2020, 01:56 PM   #3
A standard 67 122S model would have the dual down pipe cast iron manifold. It is the main reason the power went up a bit without any other changes.
Old 11-26-2020, 02:28 PM   #4
c1800
You are correct. My error.
From this website for 1967, “ Engine improvements through new carburetors, new airfilter, manifold (with twin outlets) and front part of exhaust pipe”.
http://www.volvoamazonpictures.se/mo...modelyears.php
Old 11-26-2020, 06:55 PM   #5
The new carbs were the change from two bolt air filters to three bolt air filters.
Old 11-27-2020, 05:43 PM   #6
spock345
spock345's Avatar
What is the reason for going to the three bolt filters? Do the two bolt ones like to leak? My HS6s are both two bolt setups.
Old 11-27-2020, 06:30 PM   #7
It's a taller air filter that flows more air. By then the B18B was up to 115hp. So they added a bit more aiflow since the engines were also using that dual outlet cast manifold.
Old 11-27-2020, 07:39 PM   #8
c1800
I’ve seen a few references to increased flow as in this link.
Carb CFM Flow Rate
HS6 210
HIF6 240
http://www.mgbmga.com/tech/mgb19.htm
Old 11-29-2020, 03:02 PM   #9
The carb is still an HS6 model carb in 67. Volvo HS6 carbs are a performance upgrade for an MGB.
Old 11-30-2020, 06:30 PM   #10
spock345
spock345's Avatar
Carb CFM Flow Rate
HS6 210
HIF6 240
The B18D never got HIF carbs. Although I doubt there would be a significant difference in performance if you swap HIFs onto a B18D. I plan to try a set of HIF6s from a '72 B20 on my B18D just to see how it runs. I haven't been able to find any information about whether it works well so might as well try it.
