Old 01-12-2021, 12:59 AM   #1
SLOVOLO240
Default Rear right side fog lamp issue
1Does anyone have suggestions on how to narrow down why my rear fog lamp isn’t working in a ‘93 240? I just put new tail assemblies in and a brake light switch due to brake light issues. Now that I fixed that, the fog lamp stopped coming on. Thanks in advance.
Last edited by SLOVOLO240; 01-12-2021 at 04:45 PM.. Reason: Spelling correction / added car model
SLOVOLO240 is offline   Reply With Quote
Old 01-12-2021, 04:27 AM   #2
James M
Bored member
James M's Avatar
Did it come on before? Both or just the one?
Trace voltage until you find/don't find it. Might also check fuses I'm case you blew one installing stuff
Old 01-12-2021, 12:36 PM   #3
SLOVOLO240
It came on when I put the assembly in! Itís just the right side thatís having the issues. I put a new fuse in as well, the whole tail light assembly works off of the one fuse, no? Iíll double check that! Iíll do a voltage test as well.
Old 01-12-2021, 04:01 PM   #4
c1800
No idea what you’re driving, but in a lot of cases only the driver side fog lamp is energized so as not to be confused with the brake lights when driving in the fog.
Old 01-12-2021, 04:45 PM   #5
SLOVOLO240
Ohhh how dumb of me not to include that. My apologies. A 1993 240!
Interesting! Why would the assemblies come with a bulb in that slot then?
Old 01-12-2021, 05:37 PM   #6
The 85-90 car used both rear fog lights. In 91-93 only the left side fog light works.
Old 01-12-2021, 05:38 PM   #7
Khrrck
Professional Amateur
Maybe the assembly factory doesn't know how the cars are wired? They probably make dozens of different models.
I wired my uppermost positions on both sides of my wagon as additional brake lights. You could do the same, run extra wiring to energize rear fogs on both sides, or just keep the stock configuration.
See this older thread for some reference:
http://www.forums.turbobricks.com/sh....php?p=6126749
'87 240 budget wagon.
Old 01-12-2021, 07:23 PM   #8
SLOVOLO240
Thanks for all of the information, everyone!
Old 01-13-2021, 12:07 PM   #9
vwblue1967
vwblue1967's Avatar
I had the same issue after installing new taillight assemblies and hard wiring them. I found out here like another member said, its not supposed to work on a 93.
Theres even a wire there it just doesnt have power going to it but you can connect it to the other side to power it.
85 245 - ipd sport springs and sway bars yoshifab torque rods, kaplhenke bne strut mounts and TAB's. Poly bushings Bilstein tourings. B cam +4. 2.25 exhaust.
93 244 stockish.
vwblue1967 is offline   Reply With Quote
