Old 03-12-2021, 02:48 PM   #1
tomwas
Oldbie
tomwas's Avatar
Default CEL reset, 90 780tic
Just came on , cel not service light... How is reset accomplished.. Search function not working.
tomwas is offline   Reply With Quote
Old 03-12-2021, 03:15 PM   #2
Disconnect the battery
Old 03-12-2021, 03:39 PM   #3
2manyturbos
No, read the codes using the on board code reader to find out what is causing the CEL, then, clear the system.
https://www.brickboard.com/FAQ/700-9...neOBDCodes.htm
Old 03-13-2021, 12:38 AM   #4
tomwas
Oldbie
tomwas's Avatar
Was okay previously, installed a new front under bumper spoiler and to access screws had to remove the battery on the left side and air intake box on the right side.. Came on after that... Weather turning back to cold again, once it warms up again a bit I'll pull the intake assembly and connections to recheck... Has the turbo plus on the side of the box with additional connectivity..sure enjoyed these last three day in ny, a spring teaser... No garage so only can work in my driveway... Will be selling it shortly... Thought the car needed saving, not making any more, needs more than I can fulfill... Cali car until 03, sarts, stops, runs , drives... Needs work... Good solid base.
