Old 06-14-2021, 09:01 PM   #1
HiSPL
Fanking Champion 1993
HiSPL's Avatar
Default Anyone built their own NA downpipe?
Would like to see pics or hear about what you done did.
I want to upsize the entire exhaust but will be keeping the stock manifold.
Beets taste like buttfeet.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
88 244
06 XC90 V8
03 V70
Old 06-15-2021, 01:00 AM   #2
woodenpudden
lacks goats
woodenpudden's Avatar
mikep is building one for an L28 or 26 or whatever it is. Oooooooobviously not the same cylinder count, pipe routing and all that but it's a sight to behold, plus it might give you ideas
Originally Posted by DMFWallace View Post
Flunt delivers!
Got my second dose yesterday, after a few hours I felt horrible, I imagine the only thing that feels worse is driving a 7/900
woodenpudden is offline   Reply With Quote
Old 06-15-2021, 08:11 AM   #3
Swedbrick
Swedbrick's Avatar
I just increased the size of the j-pipe with the original flange ported for the new tubes, to a 2.5 inch turbo exhaust. It worked out pretty good, 135whp with a k-cam on a untouched 530 head
Volvo 745 - IPD springs, 25mm/19mm swaybars, T-cam, LH2.4, M90 swap, 3.54 \w racingdiff lsd, track/daily
Old 06-15-2021, 12:30 PM   #4
OttoB
Yes, i built a Y-pipe to B30E and it killed low end torque. After several simulations I will try smaller and longer tube, have merge collector and megaphone to adapt collector to exhaust pipe.
Old 06-26-2021, 11:36 AM   #5
thelostartof
unbalanced chemical
thelostartof's Avatar
Why not replace the stock manifold at the same time?
Get a cheapo pair of SBC headers and cut them up. Way back when I did a 4-2-1 and then converted it back to a 4-1, ugly but it worked and still lives on to this day.
Old 07-06-2021, 06:22 PM   #6
FROSTED_BVTTS
FROSTED_BVTTS's Avatar
What did you use for the manifold flange to mate them to the redblock head?
FROSTED_BVTTS is offline   Reply With Quote
Old 07-06-2021, 06:30 PM   #7
HiSPL
HiSPL's Avatar
For me, it's just not needed. I'm staying NA and the stock manifold flows good enough. It's the rest of the exhaust that is restrictive.
Old 07-06-2021, 07:49 PM   #8
patrickstar
patrickstar's Avatar
I think Yoshifab cuts a manifold flange, you can buy it from his website
1983 242 - 4.8/AR5
1980 242 - Shell
@beige242 on instagram
patrickstar is offline   Reply With Quote
Old 07-07-2021, 05:26 AM   #9
dalek
Benchracer Tribe
dalek's Avatar
That reminds me of a Teutonics manifold I had in a Jetta many moons ago
Feedback!
Old 07-08-2021, 08:36 AM   #10
volvowagoon
volvowagoon's Avatar
Do you by chance mean SBF? The SBCs unevenly spaced exhaust ports would make for a ton of hacking.
1986 Buick Grand National - Restored to stock™
2002 Camaro V6 T5 +T - The trashy car that's fun to drive
2010 C30 T5 - The boring but trusty daily - 199k
1989 245 DL - The boring but not trusty daily - 233k
IG: @v6buick
Old 07-08-2021, 03:38 PM   #11
daijoubanai
waste of skin and blood
daijoubanai's Avatar
Either that or its for a LS/LQ, I unfortunately don't remember. I used to have the other half of these headers as I was going to do the same modification but for my Nissan. Though I think I threw it away because I can't find it and I don't want to look very hard.
daijoubanai is offline   Reply With Quote
Old 07-10-2021, 04:27 PM   #12
mikep
The MP
mikep's Avatar
Old 07-14-2021, 01:35 AM   #13
122power
dude
122power's Avatar
Was another thread on here for a cheapo one from a sbf or the 2.3l ford also.
Ls passenger side might be pretty close also.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 07-24-2021, 07:31 PM   #14
klr142
Turbo, what?
klr142's Avatar
Agreed! We have over 150whp in our B230 based racecar and it's still using the factory exhaust manifold with a little bit of port work. The factory downpipe isn't horrible, either. Depending on what you want to do, you may want to shorten it or leave it full length, but you ABSOLUTELY want to make the 2-1 merge exit into a larger diameter exhaust than stock. At least 2 1/4" or even 2 1/2".
https://pbase.com/mperry/image/171783471.jpg
Nice! Right now we are looking into building a new downpipe for our setup that isn't basically stock sized with our almost double factory HP goals for the race car and want to go up to 1 7/8" or 2" diameter piping. The 1 7/8" pipe will work better with reusing the original downpipe's flange and should be enough for 200whp with the right supporting mods, Erland Cox suggests, so we'll stick with that for ease of building. We're still trying to find a place to make us the 2-1 merge, though. I couldn't find one online that was reasonably priced. We may have a local fabricator that'll do it, but I like what you're doing here anyway.
EDIT: Thanks for the www.coneeng.com link whoever posted that somewhere that apparently wasn't this thread!
