AndrewNance
Amateur hour!
- Oct 24, 2011
- Winston-Salem, NC
They aren't bad. I just ordered a set from Summit but what you're using is better for your wheels.
So you have it lowered about 2" ? Any noticleble changes in handling with that and the new wheel/tire combo?
Andrew, you were getting away with like 17x8" et20 TSW's on your 122, right? did you need spacers to keep them off the sway bar? I'm looking at running either 17x8 et0's or 18x8.5 et-6's. If my maths are correct this would be almost the same OD as stock if I ran 215:50 series, but as far as backspace to keep them off the sway bar, I'd need to push them out about 20-30mm.
With 205/50s I had to roll the fenders and they did rub the sway bar at full lock. Et 0-10 would have been a lot better in the front with just 1* of camber. Et20 works great in the back even with an 8" wheel and a 205 or 215. Even a 225 would probably fit just fine.
Finally got the wheels and tires on!
[/URL][/IMG]
I finally have my suspension sorted out on my wagon. 40 mm lowering springs from ClassicSwede up front and 5" x 13" 150lb springs in the back. Car sits nice and level, I love the way it handles. I have tried several combinations of stiffer springs int he back and did not like the way the car handled. Any mid-corner bump would disturb the rear end causing loss of grip. Running Bilstiens and IPD sways front and back.
I've been reading up until my eyeballs fall out.. your setup looks great!
Were the rear coils from ClassicSwede as well?
