- Jan 1, 2006
- Southern Maryland
Okay I've had all this stuff for years and I'm finally getting around to doing something with them.
Question #1. Will the lower timing cover off an 8v fit? I'm trying to figure out the easiest way to check ignition timing and the such. I've seen pictures with it fitted, but don't really know if someone had to modify or space it out.
Question #2. Since I don't have the rear portion of the timing cover for the head, I assume the marks on the valve cover are for my cam gears? Just draw an imaginary line?
Question #3. What is the tensioning procedure for the yoshifab tensioner? I see how it spins and moves to tension, but how do I decide what is 'tight enough' for the setup?
