Jack
junkman
- Jul 7, 2011
- The Ass Cheek Of History
please help me before I lose my mind completely....problems started before I went parts cannon on this
1975 Volvo b20 with M40 original Kjet.
car came with a some random China fuel pump. I just installed a new fuel pump from VP thinking that may be it (china pump ran loud for months)
line pressure reads 4.6 (spec is between 4.6-5.3)
rest pressure is was about 30 psi (spec is min 24 max 51)
^That all seems normal
control pressure is where I found some issues, all but one WUR seemed bad
all WURs were setting the control pressure at 4.6 right away (max I believe is 3.7 aka 50-55psi)
one WUR started at 1.9 after I messed around with it (which seems to high) then after 3 min it does go to 3.7 as per test
car will every once in a while run for about 2 seconds then dies and sometimes with throttling it will run rough but as soon as you let go of throttle it dies
the other weird part is that sometimes the cold start injector will spray when starting and then most of the time it does not, when it does it sometimes seems to spray for few seconds and other times just very briefly
what does the plugged in sensor at the air flow meter do? the mechanism inside the air flow meter is mechanical, so what is this sensing? I also cant find any tests for it.
How do you test a thermal time switch?
We have ruled out:
fuel pump (replaced with brand new one)
fuel pump relay (tried multiple relays)
main relay (tried multiple relays)
fuel distributor (plunger checked, works smoothly; pressure test is correct)
cap and rotor (10k miles)
spark plugs (new)
spark wires (fairly new)
intake accordion (checked for holes, none)
starter (turns over fine)
ignition coil (spark is strong)
wiring from starter to cold start injector (continuity exists)
At this point it seems like we have two separate issues:
cold start injector mostly doesn't turn on upon crank
injectors do not inject fuel into engine unless gas pedal is depressed a lot or air flow sensor is manually held up (cannot maintain idle)
I need some help please
We have ruled out:
spark plugs (new)
