justlie
- Jul 17, 2009
- Chicago, IL
Rich went golfing down south...he isn't doing anything.
Tom, we could attempt to rebracket the brace and move it up a little bit as well if you want. The other option is Rich can mill out some aluminum spacers as well.
Odyssey PC680 mounted and other bits
What are you going to do if you need to jumpstart the car?
when you did your sound deadening (i'm sure you said it, but I'm too lazy to look) did you also use any foam padding, or MLV?
I haven't done all of it yet, but in addition to the rattle trap sound deadening, I am also using 1/8" closed-cell foam as a decoupler and 1 lb per sq ft MLV as a sound barrier.
